Amule "bierze" Wszystko
beatl68
z FAQ aMule (zawsze uderzaj do zrodla)
What is the real point on setting up Line Capacities in Preferences? Shouldn't aMule only care for the Bandwidth Limits?
aMule really only cares for the Bandwidth Limits. Line Capacities are only set for the Statics display. Let's see: Imagine you have a 100KBps connection, imagine you want to set the Limit at 40KBps because you have a web server which needs a minimum of 60KBps to serve all the petitions. Now imagine you download rare indonesian free songs. You most surely never download at more than 3KBps ever. So, you could set Line Capacities at 5KBps so that the graph at Statics has some meaning, since if you set it up as a 100KBps connection, the graph will show an horizontal line with no meaning at all.
albo iptables i porty (chyba da sie?) chyba nawet bylo o tym na forum, ale ja Ci nie podpowiem bo nie wiem. Muła nie uzywam:)
