Błąd Yuma
spyro
witam
ochrzańcie mnie jak źle trafiłem z temamatem, ale mam taki problem bo wyświetla mi coś takiego
[root@p11 spyro]# yum install mplayer
Setting up Install Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
updates-released          100% |=========================|  951 B    00:00
extras                    100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
freshrpms                 100% |=========================|  951 B    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for mplayer to pack into transaction set.
mplayer-1.0-0.16.pre7.2.f 100% |=========================|  25 kB    00:00
---> Package mplayer.i386 0:1.0-0.16.pre7.2.fc4 set to be updated
--> Running transaction check
--> Processing Dependency: libdvdread.so.3 for package: mplayer
--> Processing Dependency: libfribidi.so.0 for package: mplayer
--> Processing Dependency: liblzo.so.1 for package: mplayer
--> Processing Dependency: mplayer-fonts for package: mplayer
--> Restarting Dependency Resolution with new changes.
---> Downloading header for fribidi to pack into transaction set.
fribidi-0.10.4-8.i386.rpm 100% |=========================| 4.0 kB    00:00
---> Package fribidi.i386 0:0.10.4-8 set to be updated
---> Downloading header for mplayer-fonts to pack into transaction set.
mplayer-fonts-1.1-3.fc.no 100% |=========================|  14 kB    00:00
---> Package mplayer-fonts.noarch 0:1.1-3.fc set to be updated
---> Downloading header for lzo to pack into transaction set.
lzo-1.08-4.i386.rpm       100% |=========================| 3.2 kB    00:00
---> Package lzo.i386 0:1.08-4 set to be updated
---> Downloading header for libdvdread to pack into transaction set.
libdvdread-0.9.4-7.2.fc4. 100% |=========================| 4.9 kB    00:00
---> Package libdvdread.i386 0:0.9.4-7.2.fc4 set to be updated
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Installing:
mplayer                 i386       1.0-0.16.pre7.2.fc4  freshrpms         3.5 MInstalling for dependencies:
fribidi                 i386       0.10.4-8         base               48 k
libdvdread              i386       0.9.4-7.2.fc4    freshrpms          55 k
lzo                     i386       1.08-4           extras             59 k
mplayer-fonts           noarch     1.1-3.fc         freshrpms         1.0 M
Transaction Summary
Install      5 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 4.7 M
Is this ok [y/N]: y
Downloading Packages:
(1/5): fribidi-0.10.4-8.i 100% |=========================|  48 kB    00:00
(2/5): mplayer-1.0-0.16.p 100% |=========================| 3.5 MB    00:20
(3/5): mplayer-fonts-1.1- 100% |=========================| 1.0 MB    00:03
(4/5): lzo-1.08-4.i386.rp 100% |=========================|  59 kB    00:01
(5/5): libdvdread-0.9.4-7 100% |=========================|  55 kB    00:00
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
 Installing: libdvdread                   ######################### [1/5]
/sbin/ldconfig: File /usr/lib/libkdeinit_kolf.so.#prelink#.AOhZuS is empty, not checked.
 Installing: lzo                          ######################### [2/5]
 Installing: mplayer-fonts                ######################### [3/5]
 Installing: fribidi                      ######################### [4/5]
 Installing: mplayer                      ######################### [5/5]
Installed: mplayer.i386 0:1.0-0.16.pre7.2.fc4
Dependency Installed: fribidi.i386 0:0.10.4-8 libdvdread.i386 0:0.9.4-7.2.fc4 lzo.i386 0:1.08-4 mplayer-fonts.noarch 0:1.1-3.fc
Complete!
nie żeby to uniemożliwiało instalacje pakietów, ale ten komunikat troche mnie denerwuje
prosze o pomoc w usunięciu tego komunikatu
a i jeszcze jedno nie chce mi sie zainstalować paczka xmms-feed2 wypluwa taki komunikat
---> Package xmms-faad2.i386 0:2.0-0.lvn.4.4 set to be updated
--> Processing Dependency: faad2 = 0:2.0-0.lvn.4.4 for package: xmms-faad2
--> Finished Dependency Resolution
Error: Missing Dependency: faad2 = 0:2.0-0.lvn.4.4 is needed by package xmms-faad2
Po pierwsze: O jakim "denerwującym" komunikacie mówisz? To normalne, że yum informuje cię o wszystkim, co właśnie robi (wyszukiwanie pakietów i zależności, pobieranie, instalowanie), a na koniec wypluwa dokładne informacje o tym, co zrobił... :o
Po drugie: Zdaje się, że nie wkleiłeś całego komunikatu. Ale z tego, co tu widać, to brakuje ci pakietu faad2 i yum nie może go zainstalować (bo albo go nie ma w repozytoriach albo może jest jakiś konflikt zależności).
tak konkretnie to mnie denerwuje ten komunikat
występuje on po instalacji większości pakietów za pomocą yuma albo z rpmów
da sie to jakoś zlikwidować ???
rpm.livna.org i freshrpms nie sa ze sobą kompatybilne, więc stąd ten problem. W obu znajduje się wiele takich samych paczek (w tym przypadku faad2), więc spodziewaj się częściej takich problemów.
Jeśli w tym czasie działa Ci prelink, to nie masz się czym przejmować. Jak skończy swoją robotę, to te problemy znikną.
Jeśli jednak przerwałeś jego działanie, to uruchom go jeszcze raz (opis w wątku o naruszeniu ochrony pamięci).
wywaliłem repo freshrpms i wywaliłem wszystkie pakiety które kożystały z faad2 a potem wszystko od nowa zainstalowałem i działa
a co do tego drugiego to zrobiłem tak jak tam pisało i narazie nie pojawiał się ten komunikat
jak się będzie dalej pojawiał to jeszcze napisze
dzięki za pomoc
robiłem teraz update systemu yumem i dalej wychodzi mi ten błąd:
Edytowane przez spyro
odpalałem go tak jak tam pisało, ale teraz już sie nie pokazuje bo po update systemu coś sie spieprzyło i sie (_linuks_ → Linux) ORT nie chciał odpalać więc sie wkurzyłem i zainstalowałem go jeszcze raz i teraz wszystko dobrze chodzi
Gość
