System-config-network
mysio
Po odpaleniu system-config-network wyskakójewyskakuje :
Component: system-config-network
Version: 1.3.26
Summary: TB40cc7661 ConfPAP.py:86:initvars:IndexError: list index out of range
File "/usr/sbin/system-config-network-gui", line 166, in main
window = mainDialog()
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 262, in __init__
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 294, in load
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 302, in loadDevices
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 294, in getDeviceList
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 80, in load
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/plugins/NCDevADSL.py", line 35, in load
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDialup.py", line 199, in load
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDialup.py", line 127, in load
File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NC_functions.py", line 297, in getPAPConf
File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 33, in __init__
Conf.Conf.__init__(self, filename, '#', ' \t', ' \t')
File "/usr/lib64/python2.4/site-packages/rhpl/Conf.py", line 181, in __init__
self.read()
File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 38, in read
self.initvars()
File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 86, in initvars
self.vars[var[0]][var[1]] = var[2]
Local variables in innermost frame:
var: ['PEERDNS=yes']
self: <rhpl.ConfPAP.ConfPAP instance at 0x2aaab027b5f0>
Z jakich repozytoriów korzystasz?
Sory ale jestem początkujący i nie bardzo wiem o co chodzi można jaśniej.
[root@localhost ~]# rpm -qa | grep python
gnome-python2-2.10.0-1
python-sqlite-1.1.6-1
libxml2-python-2.6.20-1.FC4
python-2.4.1-2
python-urlgrabber-2.9.6-1
gnome-python2-canvas-2.10.0-1
rpm-python-4.4.1-22
gnome-python2-gnomevfs-2.10.0-1
gnome-python2-extras-2.10.0-2.1
python-devel-2.4.1-2
gnome-python2-gtkhtml2-2.10.0-2.1
dbus-python-0.33-3
python-ldap-2.0.6-4
python-elementtree-1.2.6-4
gnome-python2-bonobo-2.10.0-1
[root@localhost ~]# rpm -q system-config-network
system-config-network-1.3.26-1
[root@localhost ~]# rpm -V system-config-network
[root@localhost ~]# rpm -qa | grep python | xargs rpm -V
..?......  /usr/lib64/python2.4/bsddb/test/__init__.py
..?......  /usr/lib64/python2.4/email/test/__init__.py
[root@localhost ~]# package-cleanup --problems
Setting up yum
Reading local RPM database
Processing all local requires
Missing dependencies:
Package gnome-python2-bonobo requires bonobo-activation >= 1.0.0
Package subversion requires perl(Getopt::Long) >= 2.25
Package mx4j requires jce >= 1.2.2
Package redhat-artwork requires redhat-logos >= 1.1.22
Package eel2 requires bonobo-activation >= 1.0.3
Package eel2-devel requires bonobo-activation-devel >= 1.0.3
Package docbook-utils requires perl(Getopt::Long) >= 2.01
Package bmp-extra-plugins requires libcrypto.so.4()(64bit)
Package bmp-extra-plugins requires libmusicbrainz.so.2()(64bit)
Package bmp-extra-plugins requires libssl.so.4()(64bit)
Package libgnomeprint22-devel requires bonobo-activation-devel >= 1.0.0
[root@localhost ~]#
Gość
