Patt Napisano Sierpień 18, 2005 Zgłoszenie Share Napisano Sierpień 18, 2005 Czy te wszystkie procesy sa potrzebne, a jesli nie to jak je wylaczyc ? [patt@localhost ~]$ su - Password: [root@localhost ~]# netstat Active Internet connections (w/o servers) Proto Recv-Q Send-Q Local Address Foreign Address State Active UNIX domain sockets (w/o servers) Proto RefCnt Flags Type State I-Node Path unix 14 [ ] DGRAM 5985 /dev/log unix 2 [ ] DGRAM 4089 @udevd unix 2 [ ] DGRAM 7006 @/var/run/hal/hotplug_socket2 unix 3 [ ] STREAM CONNECTED 215906 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 215905 unix 3 [ ] STREAM CONNECTED 215900 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 215899 unix 3 [ ] STREAM CONNECTED 215898 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 215897 unix 3 [ ] STREAM CONNECTED 212300 /tmp/ksocket-patt/klauncherHRTJha.slave-socket unix 3 [ ] STREAM CONNECTED 212295 unix 3 [ ] STREAM CONNECTED 17064 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 17063 unix 3 [ ] STREAM CONNECTED 17058 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 17057 unix 3 [ ] STREAM CONNECTED 17056 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 17055 unix 2 [ ] STREAM CONNECTED 17051 /tmp/ksocket-patt/kdeinit__0 unix 3 [ ] STREAM CONNECTED 16988 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 16987 unix 3 [ ] STREAM CONNECTED 16977 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 16976 unix 3 [ ] STREAM CONNECTED 16952 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 16951 unix 3 [ ] STREAM CONNECTED 16950 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 16949 unix 3 [ ] STREAM CONNECTED 16946 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 16945 unix 3 [ ] STREAM CONNECTED 15852 /tmp/mcop-patt/localhost_localdomain-0aec-43041c4f unix 3 [ ] STREAM CONNECTED 15851 unix 3 [ ] STREAM CONNECTED 15821 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 15820 unix 3 [ ] STREAM CONNECTED 15819 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 15818 unix 3 [ ] STREAM CONNECTED 15815 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 15814 unix 2 [ ] DGRAM 9988 unix 3 [ ] STREAM CONNECTED 9758 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9757 unix 3 [ ] STREAM CONNECTED 9737 @/tmp/fam-patt- unix 3 [ ] STREAM CONNECTED 9736 unix 3 [ ] STREAM CONNECTED 9669 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 9668 unix 3 [ ] STREAM CONNECTED 9667 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9666 unix 3 [ ] STREAM CONNECTED 9665 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9664 unix 3 [ ] STREAM CONNECTED 9653 @/tmp/fam-patt- unix 3 [ ] STREAM CONNECTED 9652 unix 3 [ ] STREAM CONNECTED 9642 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 9641 unix 3 [ ] STREAM CONNECTED 9640 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9639 unix 3 [ ] STREAM CONNECTED 9638 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9637 unix 3 [ ] STREAM CONNECTED 9623 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 9622 unix 3 [ ] STREAM CONNECTED 9621 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9620 unix 3 [ ] STREAM CONNECTED 9609 /tmp/.ICE-unix/2810 unix 3 [ ] STREAM CONNECTED 9608 unix 3 [ ] STREAM CONNECTED 9607 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9606 unix 3 [ ] STREAM CONNECTED 9601 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9600 unix 3 [ ] STREAM CONNECTED 9595 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9594 unix 3 [ ] STREAM CONNECTED 9588 /tmp/ksocket-patt/kdeinit__0 unix 3 [ ] STREAM CONNECTED 9587 unix 3 [ ] STREAM CONNECTED 9582 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9581 unix 3 [ ] STREAM CONNECTED 9578 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9577 unix 3 [ ] STREAM CONNECTED 9538 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9537 unix 4 [ ] STREAM CONNECTED 9503 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9502 unix 3 [ ] STREAM CONNECTED 9494 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9493 unix 3 [ ] STREAM CONNECTED 9470 @/tmp/fam-patt- unix 3 [ ] STREAM CONNECTED 9468 unix 3 [ ] STREAM CONNECTED 9447 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9446 unix 3 [ ] STREAM CONNECTED 9445 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9444 unix 3 [ ] STREAM CONNECTED 9427 /tmp/.ICE-unix/dcop2785-1124342858 unix 3 [ ] STREAM CONNECTED 9426 unix 3 [ ] STREAM CONNECTED 9424 unix 3 [ ] STREAM CONNECTED 9423 unix 3 [ ] STREAM CONNECTED 9345 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 9344 unix 3 [ ] STREAM CONNECTED 9343 unix 3 [ ] STREAM CONNECTED 9342 unix 2 [ ] DGRAM 9236 unix 2 [ ] DGRAM 8800 unix 3 [ ] STREAM CONNECTED 8080 /tmp/.font-unix/fs7100 unix 3 [ ] STREAM CONNECTED 8079 unix 4 [ ] STREAM CONNECTED 8084 /tmp/.X11-unix/X0 unix 3 [ ] STREAM CONNECTED 8013 unix 3 [ ] STREAM CONNECTED 7225 /var/run/dbus/system_bus_socket unix 3 [ ] STREAM CONNECTED 7224 unix 3 [ ] STREAM CONNECTED 7206 @/tmp/hald-local/dbus-j8pfg5C3IP unix 3 [ ] STREAM CONNECTED 7203 unix 3 [ ] STREAM CONNECTED 7149 /var/run/acpid.socket unix 3 [ ] STREAM CONNECTED 7148 unix 3 [ ] STREAM CONNECTED 7160 @/tmp/hald-local/dbus-j8pfg5C3IP unix 3 [ ] STREAM CONNECTED 7147 unix 3 [ ] STREAM CONNECTED 6897 /var/run/dbus/system_bus_socket unix 3 [ ] STREAM CONNECTED 6896 unix 3 [ ] STREAM CONNECTED 6880 unix 3 [ ] STREAM CONNECTED 6879 unix 2 [ ] DGRAM 6745 unix 2 [ ] DGRAM 6732 unix 2 [ ] DGRAM 6721 unix 2 [ ] DGRAM 6707 unix 2 [ ] DGRAM 6196 unix 2 [ ] DGRAM 6195 unix 3 [ ] STREAM CONNECTED 6177 unix 3 [ ] STREAM CONNECTED 6176 unix 2 [ ] DGRAM 6066 unix 2 [ ] DGRAM 6022 unix 2 [ ] DGRAM 5988 Pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mynus Napisano Sierpień 18, 2005 Zgłoszenie Share Napisano Sierpień 18, 2005 posprawdzaj jakie usługi masz powłączane: netstat -a | grep LISTEN możesz je powyłączać tak: najpierw ustal poziom runlevela, który masz uruchomiony: who -r dostaniesz np coś takiego: run-level 5 Aug 18 21:56 ostatni=S widzisz że używasz run-levela 5, wtedy, albo wchodzisz do katalogu: /etc/rc5.d/ patrzysz jakie uruchamiane są tam demony (te zaczynające się na SXXnazwa) i tym których nie potrzebujesz zmieniasz nazwy na: no_SXXnazwa (po resecie te usługi nie wstaną) albo (jeśli nie lubisz konsoli) możesz zrobić to samo przy pomocy programów: setup (z konsoli) - i tam usługi systemowe K->ustawienia systemowe -> service management (usługi) Jak to wykonasz to czas zająć się programem xinetd.d w katalogu /etc/xinetd.d/ są pliki do poszczególnych usług wystarczy pozmieniać opcje disable=yes Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 22, 2005 Autor Zgłoszenie Share Napisano Sierpień 22, 2005 dzieki, konsola pomogla juz wszystko chodzi cacy Pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
