jiliew Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 Po zakończeniu sesji w KDE następuje wyświetlenie komunikatu o błędzie spowodowanym przez kicker. Proszę o pomoc. (no debugging symbols found) Using host libthread_db library "/lib/libthread_db.so.1". (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1208346144 (LWP 4552)] (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [KCrash handler] #4 0x028228cd in QGList::find () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #5 0x02d3b9eb in KGlobal::registerStaticDeleter () from /usr/lib/libkdecore.so.4 #6 0x0342b9e5 in KDirWatch::self () from /usr/lib/libkio.so.4 #7 0x0347b402 in KDirListerCache::KDirListerCache () from /usr/lib/libkio.so.4 #8 0x0347b4bc in KDirListerCache::self () from /usr/lib/libkio.so.4 #9 0x0347bee5 in KDirLister::stop () from /usr/lib/libkio.so.4 #10 0x0347e1d0 in KDirLister::~KDirLister () from /usr/lib/libkio.so.4 #11 0x00c25266 in SystemMenu::~SystemMenu$delete () from /usr/lib/kde3/kickermenu_systemmenu.so #12 0x0308690e in QPtrList<QObject>::deleteItem () from /usr/lib/libkdeui.so.4 #13 0x02823a8d in QGList::clear () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #14 0x02d463c3 in KLibrary::~KLibrary$delete () from /usr/lib/libkdecore.so.4 #15 0x02d476fd in KLibLoader::close_pending () from /usr/lib/libkdecore.so.4 #16 0x02d47b23 in KLibLoader::~KLibLoader$delete () from /usr/lib/libkdecore.so.4 #17 0x02d4548d in KLibLoader::cleanUp () from /usr/lib/libkdecore.so.4 #18 0x02ca6dbb in KApplication::~KApplication$base () from /usr/lib/libkdecore.so.4 #19 0x02d4979d in KUniqueApplication::~KUniqueApplication$base () from /usr/lib/libkdecore.so.4 #20 0x00cd19f8 in Kicker::~Kicker () from /usr/lib/libkdeinit_kicker.so #21 0x00cd14c1 in kdemain () from /usr/lib/libkdeinit_kicker.so #22 0x001976e0 in kdeinitmain () from /usr/lib/kde3/kicker.so #23 0x0804decd in ?? () #24 0x0804e545 in ?? () #25 0x0804eb2d in ?? () #26 0x0804fba9 in ?? () #27 0x00434d5f in __libc_start_main () from /lib/libc.so.6 #28 0x0804b951 in ?? () Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Faust_ Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 Zapomnijo kde z rpm. Albo zaistaluj sobie ze zrodel (trwa to przecietnie tydzien), albo przesiadz sie na lzejsze i lepsze środowisko np. xfce lub fluxbox Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 Po zakończeniu sesji w KDE następuje wyświetlenie komunikatu o błędzie spowodowanym przez kicker. Nie napisałes jaka wersja KDE, jaka wersja Fedory, nic co mogłoby innym pomóc rozwiązac ten problem. Na koncie nowego użytkownika jest to samo? Jesli nie, to skopały Ci się ustawienia. Poszukaj w katalogu ~/.kde KDE dystrybucyjne czy z repo kde-redhat? Zapomnijo kde z rpm. Niby dlaczego? Używam cały czas od FC1 i nie mam z nim w ogóle problemów. Żadnych zwisów, zacinania się i tym podobnych wianków :] Albo zaistaluj sobie ze zrodel (trwa to przecietnie tydzien) ...i potem wszystkie aplikacje wymagające kde samemu kompilować? Dziękuję, postoję. Fajnie by mi wtedy system wyglądał po kilku tygodniach używania... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
