Problem Z Instalacja Radeona 9500
Lord_JABA
Jestem zielony jezeli chodzi o fedore, Linuksa jako takiego trohe znam(przyspieszony kurs zawdzieczam Gentoo). Sterowniki sciagnolem ze strony ati, w formie skryptu sh(ati-driver-installer-8.16.20-i386.run) uruhomilem go, potem uruchomilem fglrxconfig ale 3d dalej nie dziala i nie wiem co dalej(przegladam różne fora od 3 godzin ale nie znalazlem nic co by poskutkowalo umnie.)
Wyniki fglrxinfo:
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.2.1
i mój xorg.conf
# File: xorg.conf
Section "dri"
   Mode 0666
EndSection
Section "Module"
   Load        "dbe"      # Double buffer extension
   SubSection  "extmod"
     Option    "omit xfree86-dga"   # don't initialise the DGA extension
   EndSubSection
   Load        "type1"
   Load        "freetype"
   Load        "glx"   # libglx.a
   Load        "dri"   # libdri.a
EndSection
Section "Files"
   RgbPath    "/usr/X11R6/lib/X11/rgb"
   FontPath   "/usr/X11R6/lib/X11/fonts/local/"
   FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
   FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
   FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
   FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
   FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
   FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "ServerFlags"
EndSection
Section "InputDevice"
   Identifier    "Keyboard1"
   Driver    "kbd"
   Option "AutoRepeat" "500 30"
   Option "LeftAlt"    "Meta"
   Option "XkbRules"    "xfree86"
   Option "XkbModel"    "pc101"
   Option "XkbLayout"    "us"
EndSection
   Identifier    "Mouse1"
   Driver "mouse"
   Option "Protocol"   "ImPS/2"
   Option "ZAxisMapping"   "4 5"
   Option "Device"     "/dev/mice"
EndSection
Section "Monitor"
   Identifier  "Monitor0"
EndSection
Section "Device"
   Identifier  "Standard VGA"
   VendorName  "Unknown"
   BoardName   "Unknown"
#    Chipset     "generic"
   Driver      "vga"
#    BusID       "PCI:0:10:0"
#    VideoRam    256
#    Clocks      25.2 28.3
EndSection
# === ATI device section ===
Section "Device"
   Identifier                          "ATI Graphics Adapter"
   Driver                              "fglrx"
# ### generic DRI settings ###
# === disable PnP Monitor  ===
   #Option                              "NoDDC"
# === disable/enable XAA/DRI ===
   Option "no_accel"                   "no"
   Option "no_dri"                     "no"
# === misc DRI settings ===
   Option "mtrr"                       "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
   Option "DesktopSetup"               "(null)"
   Option "ScreenOverlap"              "0"
   Option "GammaCorrectionI"           "0x00000000"
   Option "GammaCorrectionII"          "0x00000000"
# === OpenGL specific profiles/settings ===
   Option "Capabilities"               "0x00000000"
   Option "CapabilitiesEx"             "0x00000000"
# === Video Overlay for the Xv extension ===
   Option "VideoOverlay"               "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
#       will be disabled automatically
   Option "OpenGLOverlay"              "off"
# === Center Mode (Laptops only) ===
   Option "CenterMode"                 "off"
# === Pseudo Color Visuals (8-bit visuals) ===
   Option "PseudoColorVisuals"         "off"
# === QBS Management ===
   Option "Stereo"                     "off"
   Option "StereoSyncEnable"           "1"
# === FSAA Management ===
   Option "FSAAEnable"                 "no"
   Option "FSAAScale"                  "1"
   Option "FSAADisableGamma"           "no"
   Option "FSAACustomizeMSPos"         "no"
   Option "FSAAMSPosX0"                "0.000000"
   Option "FSAAMSPosY0"                "0.000000"
   Option "FSAAMSPosX1"                "0.000000"
   Option "FSAAMSPosY1"                "0.000000"
   Option "FSAAMSPosX2"                "0.000000"
   Option "FSAAMSPosY2"                "0.000000"
   Option "FSAAMSPosX3"                "0.000000"
   Option "FSAAMSPosY3"                "0.000000"
   Option "FSAAMSPosX4"                "0.000000"
   Option "FSAAMSPosY4"                "0.000000"
   Option "FSAAMSPosX5"                "0.000000"
   Option "FSAAMSPosY5"                "0.000000"
# === Misc Options ===
   Option "UseFastTLS"                 "0"
   Option "BlockSignalsOnLock"         "on"
   Option "UseInternalAGPGART"         "yes"
   Option "ForceGenericCPU"            "no"
   BusID "PCI:2:0:0"    # vendor=1002, device=4144
   Screen 0
EndSection
Section "Screen"
   Identifier  "Screen0"
   Device      "ATI Graphics Adapter"
   Monitor     "Monitor0"
   DefaultDepth 24
   #Option "backingstore"
   Subsection "Display"
       Depth       24
       Modes       "1024x768" "800x600"
       ViewPort    0 0  # initial origin if mode is smaller than desktop
#        Virtual     1280 1024
   EndSubsection
EndSection
Section "ServerLayout"
   Identifier  "Server Layout"
   Screen "Screen0"
   InputDevice "Mouse1" "CorePointer"
   InputDevice "Keyboard1" "CoreKeyboard"
EndSection
### EOF ###
z gory dzieki za wszystkie sugestie
rpm -qa | grep fglrx
daje :
ati-fglrx-8.16.20.1-0.lvn.1.4
kernel-module-fglrx-2.6.11-1.1369_FC4-8.14.13.1-0.lvn.5.4
kernel-module-fglrx-2.6.11-1.1369_FC4smp-8.14.13.1-0.lvn.5.4
no i nic dziwnego ze akceleracja nie pracuje poprawnie, poniewaz masz zke zainstalowane sterowniki,
widac juz na pierwszy rzut oka ze nie postepowales tak jak w faq <_< (http://faq.fedora.pl), poniewaz yum pobralby Ci sterowniki po pierwsze do pary po drugie do architektury
dobrze, koniec karcenia ;) oto rozwiazanie:
> odinstaluj istniejace sterowniki, w tym celu wydaj polecenie:
rpm -e --nodeps ati-fglrx kernel-module-fglrx-2.6.11-1.1369_FC4 kernel-module-fglrx-2.6.11-1.1369_FC4smp
> nastepnie skonfiguruj yuma tak jak jest w faqu (czyli skopiuj plik yum.conf do katalogu /etc/ oraz zainstaluj klucze publiczne dlaa serwerow, wszytko opisane w faqu)
> teraz mozesz przystapic do instalowania sterownikow:
yum install ati-fglrx kernel-module-fglrx-$(uname -r)
> uruchom ponownie kompa (lub zrob restart X'ow)
> zobacz czy wszystko poszlo dobrze za pomoca polecenia fglrxinfo
UWAGA! ostatnio ludzie narzekaja na sterowniki wersji 8.16.20.1, pomimo iz poprawnie sa zainstalowane nie sa stabilne, wtedy pobierz recznie z livny plik ze sterownikami wersji 8.14.13.1 i zainstaluj przy pomocy polecenia:
rpm -Uvh ati-fglrx-<numer wersji>.rpm kernel-module-fglrx-$(uname -r)<numer wersji>.rpm
Zwroc uwage na numer jadra ktore posiadasz, musi on byc zgodny oprogramowaniem ktore pobierzesz, polecenie pokazujace numer jadra to:
uname -r
Dodać jeszcze warto, że ludzie narzekali na słabą wydajność na niezaktualizowanym systemie. Jądro 2.6.11-1.1369 do najnowszych nie nalezy, więc wklep w terminalu:
yum update
true... true... B)
najlepiej najpierw odinstaluj te pakiety ktore napisalem wyzej, potem skonfiguruj yuma, potem zrob to co radzi Ci gajownik, a potem zainstaluj poprawne sterowniki
wazna jest inforamacja ze przy kazdej zmianie/aktualizacji jadra systemu bedziesz musial aktualizowac sterowniki (do odpowiedniego modulu jadra)
