Instalacja Qemu Pod Fc4
Gość Bielik
Próbuje zainstalować Qemu wraz z kqemu i ./configure wyświetla następujące komunikaty
Install prefix    /usr/local
BIOS directory    /usr/local/share/qemu
binary directory  /usr/local/bin
Manual directory  /usr/local/share/man
ELF interp prefix /usr/gnemul/qemu-%M
Source path       /home/bielik/download/qemu-0.7.2
C compiler        gcc
Host C compiler   gcc
make              make
host CPU          i386
host big endian   no
target list       i386-user arm-user armeb-user sparc-user ppc-user i386-softmmu ppc-softmmu sparc-softmmu x86_64-softmmu mips-softmmu
gprof enabled     no
static build      no
SDL support       yes
SDL static link   yes
mingw32 support   no
Adlib support     no
FMOD support      no
kqemu support     yes
KQEMU Linux module configuration:
kernel sources    /lib/modules/2.6.12-1.1447_FC4/build
kbuild type       2.6
lecz gdy dochodze do make wychodzi mi błąd:
[bielik@localhost qemu-0.7.2]$ make
for d in i386-user arm-user armeb-user sparc-user ppc-user i386-softmmu ppc-softmmu sparc-softmmu x86_64-softmmu mips-softmmu; do \
make -C $d all || exit 1; \
       done
make[1]: Entering directory `/home/bielik/download/qemu-0.7.2/i386-user'
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -mpreferred-stack-boundary=2 -falign-functions=0 -fno-gcse -fno-reorder-blocks -fno-optimize-sibling-calls -I. -I/home/bielik/download/qemu-0.7.2/target-i386 -I/home/bielik/download/qemu-0.7.2 -I/home/bielik/download/qemu-0.7.2/linux-user -I/home/bielik/download/qemu-0.7.2/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/home/bielik/download/qemu-0.7.2/fpu -I/home/bielik/download/qemu-0.7.2/slirp -c -o op.o /home/bielik/download/qemu-0.7.2/target-i386/op.c
/home/bielik/download/qemu-0.7.2/target-i386/ops_sse.h: In function ‘op_pshufw_mmx’:
/home/bielik/download/qemu-0.7.2/target-i386/ops_sse.h:574: error: unable to find a register to spill in class ‘GENERAL_REGS’
/home/bielik/download/qemu-0.7.2/target-i386/ops_sse.h:574: error: this is the insn:
(insn:HI 18 17 19 0 /home/bielik/download/qemu-0.7.2/target-i386/ops_sse.h:569 (set (strict_low_part (subreg:HI (reg/v:DI 63 [ r ]) 0))
       (mem/s/j:HI (plus:SI (mult:SI (reg:SI 64)
                   (const_int 2 [0x2]))
               (reg/v/f:SI 59 [ s ])) [0 <variable>._w S2 A16])) 41 {*movstricthi_1} (insn_list:REG_DEP_TRUE 16 (insn_list:REG_DEP_TRUE 12 (insn_list:REG_DEP_TRUE 53 (nil))))
   (expr_list:REG_DEAD (reg:SI 64)
       (nil)))
/home/bielik/download/qemu-0.7.2/target-i386/ops_sse.h:574: confused by earlier errors, bailing out
make[1]: *** [op.o] Błąd 1
make[1]: Leaving directory `/home/bielik/download/qemu-0.7.2/i386-user'
make: *** [all] Błąd 1
Czy ktoś wie co to jest za błąd i jak go naprawić ??
No to czyli nici z emulacji, to może spytam sie tak zna ktoś jakiś jeszcze emulator pod (_linuxa_ → Linuksa) ORT no bo Quemu odpada z powodu GCC, i VMware także sie o niego rzuca, zna ktoś może jeszcze jakiś emulator, bo potrzebny mi on dość bardzo w Linuxsie
Też (_ściągnołem_ &#8594; ściągnąłem) ORT wersje binarną, ale nie spełnia oczekiwań, za wolno emuluje windows me, i dlatego liczyłem na ten akcelelator :(. Ok nie pozostaje nic innego niz czekac
Gość
