booge Napisano Wrzesień 11, 2005 Zgłoszenie Share Napisano Wrzesień 11, 2005 Witam. Mam mały problem. Od jakiegoś czasu wywalają mi się programy napisane w QT. Nie wszystkie, ale np Krusader i kTorrent. Prawdopodobnie coś poszło nie tak przy aktualizacji. (Mieszałem nieco z repozytoriami (_yum'a_ → yuma) ORT). Poniżej jest wyplówka jaką podaje kcrash: (no debugging symbols found) Using host libthread_db library "/lib/libthread_db.so.1". (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1208547664 (LWP 3058)] (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [KCrash handler] #4 0x00ac23f9 in _X11TransWrite () from /usr/X11R6/lib/libX11.so.6 #5 0x00aa779b in _XError () from /usr/X11R6/lib/libX11.so.6 #6 0x00aa78b6 in _XReply () from /usr/X11R6/lib/libX11.so.6 #7 0x00a9060a in _XGetWindowAttributes () from /usr/X11R6/lib/libX11.so.6 #8 0x00a90764 in XGetWindowAttributes () from /usr/X11R6/lib/libX11.so.6 #9 0x011584a1 in _XimLocalSetICValues () from /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2 #10 0x01159235 in _XimSetICDefaults () from /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2 #11 0x011592cb in _XimSetICDefaults () from /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2 #12 0x011562db in _XimLocalCreateIC () from /usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2 #13 0x00abf25a in XCreateIC () from /usr/X11R6/lib/libX11.so.6 #14 0x00d7f653 in QXIMInputContext::setHolderWidget () from /usr/lib/qt-3.3/plugins/inputmethods/libqxim.so #15 0x04a38730 in QInputContextFactory::create () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #16 0x00d6eed5 in QMultiInputContext::changeInputMethod () from /usr/lib/qt-3.3/plugins/inputmethods/libqimsw-multi.so #17 0x00d6f086 in QMultiInputContext::slave () from /usr/lib/qt-3.3/plugins/inputmethods/libqimsw-multi.so #18 0x00d6f321 in QMultiInputContext::setHolderWidget () from /usr/lib/qt-3.3/plugins/inputmethods/libqimsw-multi.so #19 0x04a38730 in QInputContextFactory::create () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #20 0x0479a326 in QWidget::createInputContext () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #21 0x0479a482 in QWidget::unfocusInputContext () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #22 0x04875a5d in QWidget::clearFocus () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #23 0x04877ec0 in QWidget::~QWidget$base () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #24 0x0494e017 in QPopupMenu::~QPopupMenu$base () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #25 0x0084409b in KPopupMenu::~KPopupMenu$base () from /usr/lib/libkdeui.so.4 #26 0x008452e3 in KPanelMenu::~KPanelMenu$base () from /usr/lib/libkdeui.so.4 #27 0x00241e9a in PanelServiceMenu::~PanelServiceMenu$base () from /usr/lib/libkdeinit_kicker.so #28 0x00241f78 in PanelKMenu::~PanelKMenu$delete () from /usr/lib/libkdeinit_kicker.so #29 0x0020906b in MenuManager::~MenuManager$delete () from /usr/lib/libkdeinit_kicker.so #30 0x0483c04c in QObject::~QObject$base () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #31 0x047dc095 in QApplication::~QApplication$base () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #32 0x0103f258 in KApplication::~KApplication$base () from /usr/lib/libkdecore.so.4 #33 0x0103f401 in KUniqueApplication::~KUniqueApplication$base () from /usr/lib/libkdecore.so.4 #34 0x001fb406 in Kicker::~Kicker () from /usr/lib/libkdeinit_kicker.so #35 0x00214085 in kdemain () from /usr/lib/libkdeinit_kicker.so #36 0x0293d49f in __libc_start_main () from /lib/libc.so.6 #37 0x0804854d in ?? () Czy ktoś z Was ma jakiejolwiek pomysły? Ja już nie mam siły... ps. W tym wypadku wyplówka tyczy się kicker'a. Dzieje się to przy każdym wyjściu z KDE. -- Pozdrawiam, Booge Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Wrzesień 11, 2005 Zgłoszenie Share Napisano Wrzesień 11, 2005 jakie repozytoria masz wlaczone (z ktorych korzystales podczas aktualizacji)? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
booge Napisano Wrzesień 11, 2005 Autor Zgłoszenie Share Napisano Wrzesień 11, 2005 jakie repozytoria masz wlaczone (z ktorych korzystales podczas aktualizacji)? Oto pełna lista repos, których używałem: (heh, nie zbyt to mądre było) file:///home/bartek/YUMOLD/yum.repos.d/atrpm.repo file:///home/bartek/YUMOLD/yum.repos.d/atrpms.repo file:///home/bartek/YUMOLD/yum.repos.d/dag.repo.rpmnew file:///home/bartek/YUMOLD/yum.repos.d/dag.repo.rpmsave file:///home/bartek/YUMOLD/yum.repos.d/dries.repo file:///home/bartek/YUMOLD/yum.repos.d/dries.repo.rpmsave file:///home/bartek/YUMOLD/yum.repos.d/fedora-extras.repo file:///home/bartek/YUMOLD/yum.repos.d/fedora-livina.repo file:///home/bartek/YUMOLD/yum.repos.d/fedora.repo file:///home/bartek/YUMOLD/yum.repos.d/fedora-update.repo file:///home/bartek/YUMOLD/yum.repos.d/flash.repo file:///home/bartek/YUMOLD/yum.repos.d/flash.repo.rpmsave file:///home/bartek/YUMOLD/yum.repos.d/freshrpms.repo file:///home/bartek/YUMOLD/yum.repos.d/freshrpms.repo.rpmsave file:///home/bartek/YUMOLD/yum.repos.d/gstreamer.repo file:///home/bartek/YUMOLD/yum.repos.d/kadu.repo file:///home/bartek/YUMOLD/yum.repos.d/kde-redhat.repo file:///home/bartek/YUMOLD/yum.repos.d/kde-redhat.repo.rpmsave file:///home/bartek/YUMOLD/yum.repos.d/livna.repo file:///home/bartek/YUMOLD/yum.repos.d/livna.repo.rpmnew file:///home/bartek/YUMOLD/yum.repos.d/macromedia-i386.repo file:///home/bartek/YUMOLD/yum.repos.d/newrpms.repo file:///home/bartek/YUMOLD/yum.repos.d/yam-dag.repo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Wrzesień 11, 2005 Zgłoszenie Share Napisano Wrzesień 11, 2005 No toś pokazał ;-) Repa atrpms się w ogóle nie używa, bo podmienia paczki systemowe. Zresztą tak samo, jak kde-redhat. Z kolei freshrpms się gryzie z livna, dlatego najlepiej używać tylko jednego z nich (livny ;-)) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
booge Napisano Wrzesień 11, 2005 Autor Zgłoszenie Share Napisano Wrzesień 11, 2005 No toś pokazał ;-) Repa atrpms się w ogóle nie używa, bo podmienia paczki systemowe. Zresztą tak samo, jak kde-redhat. Z kolei freshrpms się gryzie z livna, dlatego najlepiej używać tylko jednego z nich (livny ;-)) No, mądry Polak po szkodzie :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
