Problem Z Zaladowniem Plikow Do Amule
konrad85
Jest tak:
odpalam amule z zwyklego uzytkownika i nie laduje mi plikow temp i incoming chociaz mam wpisane sciezki dostepu i zamontowana partycje vfat.
tak wyglada fstab:
/dev/hda5 /mnt/win_d vfat
codepage=852,iocharset=iso8859-2,rw,umask=000,uid=0,gid=0 1 0
a tak konsola:
[konrad@localhost ~]$ amule
Initialising aMule
Checking if there is an instance already running...
Loading temp files from /mnt/win_d/emule/Temp.
Loading PartFile 1 of 14: Failed to load PartFile '001.part.met'
Loading PartFile 2 of 14: Failed to load PartFile '008.part.met'
Loading PartFile 3 of 14: Failed to load PartFile '010.part.met'
Loading PartFile 4 of 14: Failed to load PartFile '011.part.met'
Loading PartFile 5 of 14: Failed to load PartFile '012.part.met'
Loading PartFile 6 of 14: Failed to load PartFile '019.part.met'
Loading PartFile 7 of 14: Failed to load PartFile '020.part.met'
Loading PartFile 8 of 14: Failed to load PartFile '022.part.met'
Loading PartFile 9 of 14: Failed to load PartFile '025.part.met'
Loading PartFile 10 of 14: Failed to load PartFile '026.part.met'
Loading PartFile 11 of 14: Failed to load PartFile '027.part.met'
Loading PartFile 12 of 14: Failed to load PartFile '033.part.met'
Loading PartFile 13 of 14: Failed to load PartFile '042.part.met'
Loading PartFile 14 of 14: Failed to load PartFile '044.part.met'
All PartFiles Loaded.
ListenSocket: Ok.
External connections disabled in config file
*** Server UDP socket (TCP+3) at 0.0.0.0:4665
*** TCP socket (TCP) listening on 0.0.0.0:4662
*** Client UDP socket (extended eMule) at 0.0.0.0:4672
Empty dir /mnt/ shared
Natomiast jesli zrobie to samo z roota to wszystko jest ok.
Prosze o pomoc w rozwiazaniu problemu.
Nic to nie daje. Na root wszystko pieknie dziala a na userze nie. Wzialem sobie przerzucilem z vfat na dysk z linuxem kilka plikow z tempa z emule i tylko jeden sie zaladowal a reszta nie (oczywiscie na userze). Dlaczego tak jest? Strasznie mnie to denerwuje. Prosze o pomoc.
Pomozcie ludzie bo mnie juz krew zalewa. Caly dzien szukam i nic sensownego nie znalazlem. Generalnie problem wyglada tak ze na userze amule nie widzi plikow z tempa i nie potrafi dodawac nowych plikow do sciagniecia a na root dziala wszystko tylko ze jakos sie troszcze czasami zawiesza program.
Gość
