dnbass Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 [root@localhost ~]# yum install kernel-module-ntfs ( tu wyszukiwał w repezytoriach ) Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kernel-module-ntfs-2.6.13-1.1526_FC4 i686 2.1.22-0.lvn.3.4 livna 101 k Installing for dependencies: kernel i686 2.6.13-1.1526_FC4 updates-released 16 M Transaction Summary ============================================================================= Install 2 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 16 M Is this ok [y/N]: y Downloading Packages: (1/1): kernel-module-ntfs 100% |=========================| 101 kB 00:01 warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID a109b1ec public key not available for kernel-module-ntfs-2.6.13-1.1526_FC4-2.1.22-0.lvn.3.4.i686.rpm Retrieving GPG key from http://rpm.livna.org/RPM-LIVNA-GPG-KEY-i386 Importing GPG key 0xA109B1EC "Livna.org rpms <[email protected]>" Is this ok [y/N]: y Key imported successfully Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: kernel ######################### [1/2] Installing: kernel-module-ntfs-2.6.13-1. ######################### [2/2] Installed: kernel-module-ntfs-2.6.13-1.1526_FC4.i686 0:2.1.22-0.lvn.3.4 Dependency Installed: kernel.i686 0:2.6.13-1.1526_FC4 Complete! [root@localhost ~]# mount /dev/hda1 mount: unknown filesystem type 'ntfs' A a f stab wyglada tak # This file is edited by fstab-sync - see 'man fstab-sync' for details /dev/VolGroup00/LogVol00 / ext3 defaults 1 1 LABEL=/boot1 /boot ext3 defaults 1 2 /dev/devpts /dev/pts devpts gid=5,mode=620 0 0 /dev/shm /dev/shm tmpfs defaults 0 0 /dev/proc /proc proc defaults 0 0 /dev/sys /sys sysfs defaults 0 0 /dev/VolGroup00/LogVol01 swap swap defaults 0 0 /dev/hda1 /mnt/windows ntfs ro,umask=0222 0 0 /dev/fd0 /media/floppy auto pamconsole,exec,noauto,managed 0 0 /dev/hdb /media/cdrecorder auto pamconsole,exec,noauto,managed 0 0 /dev/hda /media/cdrom auto pamconsole,exec,noauto,managed 0 0 moze ktos mi powiedziec co jest nie tak ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Faust_ Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 A punkt montowania?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
grs_84pl Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 a zrobiłeś reseta?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 Możliwe, że nie załadowałeś modułu. Zobacz czy zwraca ci coś to polecenie: lsmod | grep ntfs Jeżli nic nie zwróci, to znaczy że moduł ntfs jest nie załadowany. modprobe ntfs To powinno załatwić sprawe Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dnbass Napisano Październik 4, 2005 Autor Zgłoszenie Share Napisano Październik 4, 2005 [root@localhost ~]# lsmod | grep ntfs ntfs 115312 0 [root@localhost ~]# modprobe ntfs [root@localhost ~]# mkdir /mnt/windows/ mkdir: nie można utworzyć katalogu `/mnt/windows/': Plik istnieje [root@localhost ~]# punkt montowania ..... to /mnt/windows ktory utowrzyłem i jest restarta zrobiłem i nic .... po poleceniu modprobe ntfs tez nic nie było Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
grs_84pl Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 w ten sposób tylko sprwdziłeś ze wszytko dziala [root@localhost ~]# modprobe ntfs to zaladowalo ci moduł ntfs teraz spróbuj zamontować ! mount /mnt/windows Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
asasyn Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 mount -t ntfs /dev/hda1 /mnt/windows Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dnbass Napisano Październik 4, 2005 Autor Zgłoszenie Share Napisano Październik 4, 2005 ok wszytko trybi ...... ale musiałem jeszcze raz zrestartowac kompa... a te polecenie do mod..... musze zawsze wpisywac czy tylko raz wystarczy? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Zuk87 Napisano Październik 4, 2005 Zgłoszenie Share Napisano Październik 4, 2005 a te polecenie do mod..... musze zawsze wpisywac czy tylko raz wystarczy? Nie musisz. Jedno jest do sprawdzania odpalonego modułu (lsmod | grep ntfs) a drugi do ładowania (modprobe ntfs) ale w przypadku gdy go system nie wczyta. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wisniadnb Napisano Październik 6, 2005 Zgłoszenie Share Napisano Październik 6, 2005 a co zrobic by zapisywac dane ? bo nawet jako root nie moge Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Październik 7, 2005 Zgłoszenie Share Napisano Październik 7, 2005 Jest na to chyba kilka sposobów. Możesz przekompilować jajko z obsługą ntfs i możliwością zapisu, tylko w wypadku jajek w rpmach, to byś musiał jakiś inny moduł doinstalować, ale nie wiem czy w ogóle jest. A tak ogólnie nie zaleca się stosowania ntfs w tybie zapisu, bo można stracić dane, ten moduł nie działa zbyt dobrze, chyba że już to zminili. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
!Ci Napisano Październik 8, 2005 Zgłoszenie Share Napisano Październik 8, 2005 Jest tez wyjscie pewniejsze tyle ze kosztowniejsze. Taki modul firmy paragon. Niestety tak jak wspomnialem to juz jest komercja. No w sumie jest jeszcze darmowy program do tego typu rzeczy (wymaga jedynie bibliotek windy) ale mam "alchajmera" i zapomnialem nazwe. Z tymze pisalem juz o nim (zreszta nie tylko ja pisalem) wiec wystarczy tylko poszukac... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
