O Co W Tym łazi Pomocy!
Kamills
O to mój problem
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal-1.4... found
checking for working autoconf... found
checking for working automake-1.4... found
checking for working autoheader... found
checking for working makeinfo... found
checking for strerror in -lcposix... no
checking for gawk... gawk
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking how to run the C preprocessor... gcc -E
checking host system type... i686-pc-linux-gnu
checking build system type... i686-pc-linux-gnu
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking for a sed that does not truncate output... /bin/sed
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for object suffix... o
checking for executable suffix... no
checking command to parse /usr/bin/nm -B output... ok
checking for dlfcn.h... yes
checking for ranlib... ranlib
checking for strip... strip
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions... yes
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether -lc should be explicitly linked in... no
creating libtool
checking for gcc option to accept ANSI C... none needed
checking whether make sets ${MAKE}... (cached) yes
checking GCC version... 4.0.0
*** Please downgrade/upgrade C compiler to gcc-2.95.x or gcc-3.x version! ***
DO *NOT* REPORT BUGS unless you can reproduce them after recompiling with 2.95.x
or 3.0.x version!
Note for gcc 2.96 users: some versions of this compiler are known to miscompile
programs.  If you get compile errors, first upgrade to the latest 2.96 release
(but minimum 2.96-85) and try again. If the problem still exists, try with
gcc 3.0.x (or 2.95.x) *BEFORE* reporting bugs!
Press return to resume configuration (CTRL-C to abort).
