Kicker
mysio
Mam kicker-a i podczas zamykania sys. wywala się:
(no debugging symbols found)
Using host libthread_db library "/lib64/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread 46912496348992 (LWP 3295)]
[KCrash handler]
#3  0x0000003edd4e456a in QGList::find ()
  from /usr/lib64/qt-3.3/lib/libqt-mt.so.3
#4  0x0000003edf37717c in KGlobal::registerStaticDeleter ()
  from /usr/lib64/libkdecore.so.4
#5  0x0000003ee05edce8 in KDirWatch::self () from /usr/lib64/libkio.so.4
#6  0x0000003ee0635556 in KDirListerCache::KDirListerCache ()
#7  0x0000003ee06355e7 in KDirListerCache::self () from /usr/lib64/libkio.so.4
#8  0x0000003ee0635e9f in KDirLister::stop () from /usr/lib64/libkio.so.4
#9  0x0000003ee0637e7e in KDirLister::~KDirLister ()
#10 0x00002aaaae3a9f98 in SystemMenu::~SystemMenu$delete ()
  from /usr/lib64/kde3/kickermenu_systemmenu.so
#11 0x0000003edd4e5536 in QGList::clear ()
#12 0x0000003edf380282 in KLibrary::~KLibrary$delete ()
#13 0x0000003edf381442 in KLibLoader::close_pending ()
#14 0x0000003edf3817c6 in KLibLoader::~KLibLoader$delete ()
#15 0x0000003edf37f726 in KLibLoader::cleanUp ()
#16 0x0000003edf2f236a in KApplication::~KApplication$base ()
#17 0x0000003136f82caf in kdemain () from /usr/lib64/libkdeinit_kicker.so
#18 0x0000000000406e55 in ?? ()
#19 0x0000000000407483 in ?? ()
#20 0x0000000000407b15 in ?? ()
#21 0x0000000000408a9e in ?? ()
#22 0x0000003ed9d1c3cf in __libc_start_main () from /lib64/libc.so.6
#23 0x0000000000404b59 in ?? ()
#24 0x00007fffff87a528 in ?? ()
#25 0x0000000000000000 in ?? ()
System aktualizowałem yum-em (cały) #yum update
atrpms.repo
dag.repo
dries.repo
fedora-devel.repo
fedora-extras-devel.repo
fedora-extras.repo
fedora.repo
fedora-updates.repo
fedora-updates-testing.repo
flash.repo
freshrpms.repo
jpackage.repo
kde-redhat.repo
livna.repo
newrpms.repo
Jak w danym pliku jest enabled ustawione na 1 to jest włączone:
[y4kk0@X rpm]$ grep 'enabled=1' -r /etc/yum.repos.d/
/etc/yum.repos.d/fedora.repo:enabled=1
/etc/yum.repos.d/fedora-updates.repo:enabled=1
/etc/yum.repos.d/fedora-updates-testing.repo:enabled=1
/etc/yum.repos.d/fedora-extras.repo:enabled=1
/etc/yum.repos.d/rpm.livna.repo:enabled=1
[y4kk0@X rpm]$
Zawsze też możesz dać yum update i na początku będzie napisane z jakich repozytoriów czyta.
[root@localhost ~]# grep 'enabled=1' -r /etc/yum.repos.d/
/etc/yum.repos.d/livna.repo:enabled=1
  • 3 weeks later...
