nachiel Napisano Listopad 7, 2005 Zgłoszenie Share Napisano Listopad 7, 2005 hej! Co chwile wysypuje mi sie kGuitar, a ostatnio dolaczyl do niego apollon. W obydwu przypadkch raport bledow jest podobny: (no debugging symbols found) Using host libthread_db library "/lib/libthread_db.so.1". (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1208612384 (LWP 6187)] . . . (no debugging symbols found) (no debugging symbols found) [KCrash handler] #4 0x000000e1 in ?? () #5 0x0808accb in QValueList<QCString>::detachInternal () #6 0x0808ad08 in QValueList<QCString>::detachInternal () #7 0x080b7bba in QListView::removeItem () #8 0x033e5db4 in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #9 0x0375a796 in QSignal::signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #10 0x03403633 in QSignal::activate () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #11 0x034fa582 in QPopupMenu::mouseReleaseEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #12 0x03424127 in QWidget::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #13 0x0338108d in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #14 0x03381fef in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #15 0x00b02661 in KApplication::notify () from /usr/lib/libkdecore.so.4 #16 0x03318b0d in QETWidget::translateMouseEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #17 0x03316eb3 in QApplication::x11ProcessEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #18 0x0332afc8 in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #19 0x03399732 in QEventLoop::enterLoop () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #20 0x03399656 in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #21 0x03380a59 in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #22 0x08095082 in non-virtual thunk to KTabBar::~KTabBar() () #23 0x00e12de6 in __libc_start_main () from /lib/libc.so.6 #24 0x08064081 in ?? () Co zrobic?? czy blad jest w biblotekach qt? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Listopad 8, 2005 Zgłoszenie Share Napisano Listopad 8, 2005 Co chwile wysypuje mi sie kGuitar, a ostatnio dolaczyl do niego apollon. Skoro się wysypuje, to znaczy, że w programie jest błąd. Być może zrobił błędnego konfiga - spróbu go usunąć i sprawdź czy to pomaga. Jeśli masz czas i chęci, to doinstaluj paczkę debuginfo http://wiki.fedora.pl/Administracja/RPM#nazewnictwo i przetestuj paczkę w gdb. http://fedoraproject.org/wiki/StackTraces Jeśli się na tym nie znasz, to zgłoś problem deweloperom danego programu. Czasami takie problemy mogą robić binarne sterowniki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
