Transcode
butek
transcode -i kasztelania.avi -y ffmpeg -F mpeg2vi deo -Z 704x480 --export_frc 3 -E 44100 -b 128 -o k1-dvd
transcode v0.6.14 © 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg
[transcode] (probe) suggested AV correction -D 0 (0 ms) | AV 0 ms | 0 ms
[transcode] auto-probing source kasztelania.avi (ok)
[transcode] V: import format | Digital Video RIFF data, AVI (V=dv|A=avi)
[transcode] V: import frame | 720x576 1.25:1
[transcode] V: zoom | 704x480 1.47:1 (Lanczos3)
[transcode] V: bits/pixel | 0.213
[transcode] V: decoding fps,frc | 25.000,3
[transcode] V: Y'CbCr | YV12/I420
[transcode] A: import format | 0x1 PCM [32000,16,2] 1024 kbps
[transcode] A: export format | 0x55 MPEG layer-3 [44100,16,2] 128 kbps
[transcode] V: encoding fps,frc | 25.000,3
[transcode] A: bytes per frame | 5120 (5120.000000)
[transcode] A: adjustment | 0@1000
[transcode] V: IA32 accel mode | sse3 (sse3 sse2 sse mmxext mmx asm C)
tc_memcpy: using mmxext for memcpy
[transcode] V: video buffer | 10 @ 720x576
[import_avi.so] v0.4.2 (2002-05-24) (video) * | (audio) *
[import_dv.so] v0.3.1 (2003-10-14) (video) DV | (audio) PCM
[export_ffmpeg.so] v0.3.13 (2004-08-03) (video) FFmpeg0.4.9-pre1b4730 | (audio) MPEG/AC3/PCM
[import_avi.so] format=0x1, rate=32000 Hz, bits=16, channels=2, bitrate=1024
[import_dv.so] tcextract -x dv -i "kasztelania.avi" -d 0 | tcdecode -x dv -y yv1 2 -d 0 -Q 5
[export_ffmpeg.so] Using FFMPEG codec 'mpeg2video' (FourCC 'mpg2', MPEG2 complia nt video).
[export_ffmpeg.so]: WARNING: Interlacing parameters unknown, use --encode_fields
[export_ffmpeg.so]: INFO: No profile selected
[export_ffmpeg.so] Neither './ffmpeg.cfg' nor '~/.transcode/ffmpeg.cfg'
[export_ffmpeg.so] found. Default settings will be used instead.
[export_ffmpeg.so]: INFO: Starting 1 thread(s)
[export_ffmpeg.so]: INFO: Set display aspect ratio to input
[mpeg2video @ 0x6328330]removing common factors from framerate
Audio: using new version
sh: line 1: 6239 Przerwany potok tcextract -x dv -i "kasztelania.avi" - d 0
6240 Naruszenie ochrony pamięci | tcdecode -x dv -y yv12 -d 0 -Q 5
Audio: using lame-3.96.1
clean up | frame threads | unload modules | cancel signal | internal threads | d one
[transcode] encoded 0 frames (0 dropped, 0 cloned), clip length 0.00 s
Co robić ?
Reinstalowałem transcode i nic to nie daje
