uosiu Napisano Listopad 18, 2005 Zgłoszenie Share Napisano Listopad 18, 2005 mam pytanie: jak uruchomic stacje dokujaca (dss-25) dolaczona do telefonu sony-ericssona P910i? ewentyualnie: jak wyglada sprawa z bluetooth? powinien przyjsc z allegro na dniach... dodam tylko ze pod WinXP nie udalo mi sie jej uruchomic (jest w menadzerze urzadzen, nie ma w bezpiecznym usuwaniu sprzetu i nie widzi telefonu) // znalazlem gdzies soft do symbiana zeby go odpalic http://www.koeniglich.de/p3nfs/usb.linux INSRUKCJA [uosiu@localhost ~]$ su - Password: [root@localhost ~]# cd ~uosiu [root@localhost uosiu]# cd p3nfs-5.18/p3nfs-5.18/ [root@localhost p3nfs-5.18]# ./configure checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for gcc... /usr/bin/gcc checking for AIX... no checking for strerror... yes checking for additional libraries... checking for socket in -lsocket... no checking for gethostbyname in -lnsl... yes checking for svcudp_create in -lrpcsoc... no checking how to run the C preprocessor... gcc -E checking for egrep... grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking sys/ioctl.h usability... yes checking sys/ioctl.h presence... yes checking for sys/ioctl.h... yes checking sys/errno.h usability... yes checking sys/errno.h presence... yes checking for sys/errno.h... yes checking sys/ttold.h usability... no checking sys/ttold.h presence... no checking for sys/ttold.h... no checking for stdlib.h... (cached) yes checking for mount table... /etc/mtab checking for default serial line... /dev/ttyS0 checking Psion SDK... missing checking Series80 SDK... missing checking Series60 SDK... missing checking UIQ SDK... missing configure: creating ./config.status config.status: creating Makefile config.status: creating nfsd/Makefile config.status: creating utils/p3nfs.spec config.status: creating epoc32/nfsapp/Makefile config.status: creating epoc32/nfsapp/version config.status: creating doc/p3nfsd.1 config.status: creating nfsd/config.h [root@localhost p3nfs-5.18]# make cd nfsd; make all make[1]: Entering directory `/home/uosiu/p3nfs-5.18/p3nfs-5.18/nfsd' gcc -O2 -Wall -I. -c -o mp_main.o mp_main.c gcc -O2 -Wall -I. -c -o mp_mount.o mp_mount.c mp_mount.c: In function ‘dosystem’: mp_mount.c:243: warning: missing sentinel in function call gcc -O2 -Wall -I. -c -o nfs_prot_svc.o nfs_prot_svc.c gcc -O2 -Wall -I. -c -o nfs_prot_xdr.o nfs_prot_xdr.c gcc -O2 -Wall -I. -c -o mp_pfs_ops.o mp_pfs_ops.c gcc -O2 -Wall -I. -c -o mp_serial.o mp_serial.c gcc -O2 -Wall -I. -c -o mp_inode.o mp_inode.c gcc -O2 -Wall -I. -c -o mp_xmit.o mp_xmit.c mp_xmit.c: In function ‘dump_data’: mp_xmit.c:133: warning: pointer targets in passing argument 1 of ‘sprintf’ differ in signedness mp_xmit.c:144: warning: pointer targets in passing argument 1 of ‘puts’ differ in signedness mp_xmit.c:151: warning: pointer targets in passing argument 1 of ‘puts’ differ in signedness mp_xmit.c: In function ‘getbyte’: mp_xmit.c:349: warning: pointer targets in passing argument 1 of ‘dump_data’ differ in signedness gcc -O2 -Wall -I. -c -o crc.o crc.c gcc -O2 -Wall -I. -c -o pty.o pty.c pty.c: In function ‘init_pty’: pty.c:201: warning: missing sentinel in function call gcc -O2 -Wall -I. -c -o tcp.o tcp.c tcp.c: In function ‘init_tcp’: tcp.c:65: warning: pointer targets in passing argument 3 of ‘getsockname’ differ in signedness tcp.c:77: warning: pointer targets in passing argument 3 of ‘accept’ differ in signedness gcc -lnsl -o p3nfsd mp_main.o mp_mount.o nfs_prot_svc.o nfs_prot_xdr.o mp_pfs_ops.o mp_serial.o mp_inode.o mp_xmit.o crc.o pty.o tcp.o make[1]: Leaving directory `/home/uosiu/p3nfs-5.18/p3nfs-5.18/nfsd' cd epoc32/nfsapp; make all make[1]: Entering directory `/home/uosiu/p3nfs-5.18/p3nfs-5.18/epoc32/nfsapp' make[1]: Nie nic do roboty w `all'. make[1]: Leaving directory `/home/uosiu/p3nfs-5.18/p3nfs-5.18/epoc32/nfsapp' [root@localhost p3nfs-5.18]# make install mkdir -p //usr/bin install -o root -m 04755 nfsd/p3nfsd //usr/bin mkdir -p //usr/share/man/man1 cp doc/p3nfsd.1 //usr/share/man/man1 mkdir -p //usr/share/doc/p3nfs-5.18 cp README CHANGES LICENCE //usr/share/doc/p3nfs-5.18 cp doc/Epoc16 doc/Epoc32_R5 doc/Epoc32_R6 //usr/share/doc/p3nfs-5.18 cp doc/usb.linux doc/bluetooth.linux //usr/share/doc/p3nfs-5.18 cp bin/*.sis */opl/*.opl epoc16/nfsc/nfsc.app //usr/share/doc/p3nfs-5.18 [root@localhost p3nfs-5.18]# nano /etc/named.conf [root@localhost p3nfs-5.18]# cd /var/named/ [root@localhost named]# nano [root@localhost named]# cd /etc/ppp/peers/ [root@localhost peers]# nano [root@localhost peers]# nano [root@localhost peers]# /usr/sbin/pppd call p800-usb [root@localhost peers]# /etc/init.d/named start Starting named: Error in named configuration: zone localdomain/IN: loaded serial 42 zone localhost/IN: loaded serial 42 zone 0.0.127.in-addr.arpa/IN: loaded serial 1997022700 zone 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/IN: loaded serial 1997022700 zone 255.in-addr.arpa/IN: loaded serial 42 zone 0.in-addr.arpa/IN: loaded serial 42 mrouter:4: no current owner name mrouter:5: no current owner name mrouter:12: no current owner name dns_master_load: mrouter:14: unexpected end of line dns_master_load: mrouter:13: unexpected end of input dns_rdata_fromtext: mrouter:15: near '169.254.1.68': extra input text mrouter:16: unknown RR type 'wsockhost' zone mrouter/IN: loading master file mrouter: no owner _default/mrouter/IN: no owner [ZAWIÓDŁ] [root@localhost peers]# p3nfsd -UIQ -tcp p3nfsd: version 5.18, using tcp port 13579, mounting on /mnt/psion /mnt/psion: No such file or directory [root@localhost peers]# to jest moja zabawa od poczatku z programikiem. jak widac nie dziala Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
