Bosek Napisano Listopad 22, 2005 Zgłoszenie Share Napisano Listopad 22, 2005 Zainstalowalem Azureusa i najnowsza JAVE i nie dziala Podczas uruchomienia wypisuje: [root@auv2 azureus]# ./azureus Starting Azureus... Java exec found in PATH. Verifying... Suitable java version found [java = 1.4.2] Configuring environment... Loading Azureus: java -Xms16m -Xmx128m -cp "/usr/local/azureus/Azureus2.jar:/usr/local/azureus/swt.jar:/usr/local/azureus/swt-mozilla.jar:/usr/local/azureus/swt-pi.jar" -Djava.library.path="/usr/local/azureus" -Dazureus.install.path="/usr/local/azureus" org.gudy.azureus2.ui.swt.Main '' DEBUG::Tue Nov 22 09:43:44 GMT+01:00 2005 java.lang.ClassNotFoundException: com.sun.net.ssl.internal.ssl.Provider not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:/usr/local/azureus/Azureus2.jar,file:./,file:/usr/local/azureus/swt.jar,file:/usr/local/azureus/swt-mozilla.jar,file:./,file:/usr/local/azureus/swt-pi.jar], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}} at java.net.URLClassLoader.findClass(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at java.lang.ClassLoader.loadClass(java.lang.String, boolean) (/usr/lib/libgcj.so.6.0.0) at java.lang.ClassLoader.loadClass(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at java.lang.Class.forName(java.lang.String, boolean, java.lang.ClassLoader) (/usr/lib/libgcj.so.6.0.0) at java.lang.Class.forName(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.initialise() (Unknown Source) at org.gudy.azureus2.core3.security.SESecurityManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationChecker.setSystemProperties() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.getInstance() (Unknown Source) at org.gudy.azureus2.core3.config.COConfigurationManager.initialise() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.AzureusCoreImpl() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.create() (Unknown Source) at com.aelitis.azureus.core.AzureusCoreFactory.create() (Unknown Source) at org.gudy.azureus2.ui.swt.Main.Main(java.lang.String[]) (Unknown Source) at org.gudy.azureus2.ui.swt.Main.main(java.lang.String[]) (Unknown Source) at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0) at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0) DEBUG::Tue Nov 22 09:43:44 GMT+01:00 2005 java.security.KeyStoreException: JKS at java.security.KeyStore.getInstance(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.ensureStoreExists(java.lang.String) (Unknown Source) at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.initialise() (Unknown Source) at org.gudy.azureus2.core3.security.SESecurityManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationChecker.setSystemProperties() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.getInstance() (Unknown Source) at org.gudy.azureus2.core3.config.COConfigurationManager.initialise() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.AzureusCoreImpl() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.create() (Unknown Source) at com.aelitis.azureus.core.AzureusCoreFactory.create() (Unknown Source) at org.gudy.azureus2.ui.swt.Main.Main(java.lang.String[]) (Unknown Source) at org.gudy.azureus2.ui.swt.Main.main(java.lang.String[]) (Unknown Source) at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0) at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0) DEBUG::Tue Nov 22 09:43:45 GMT+01:00 2005 java.security.KeyStoreException: JKS at java.security.KeyStore.getInstance(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.ensureStoreExists(java.lang.String) (Unknown Source) at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.initialise() (Unknown Source) at org.gudy.azureus2.core3.security.SESecurityManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationChecker.setSystemProperties() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.initialise() (Unknown Source) at org.gudy.azureus2.core3.config.impl.ConfigurationManager.getInstance() (Unknown Source) at org.gudy.azureus2.core3.config.COConfigurationManager.initialise() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.AzureusCoreImpl() (Unknown Source) at com.aelitis.azureus.core.impl.AzureusCoreImpl.create() (Unknown Source) at com.aelitis.azureus.core.AzureusCoreFactory.create() (Unknown Source) at org.gudy.azureus2.ui.swt.Main.Main(java.lang.String[]) (Unknown Source) at org.gudy.azureus2.ui.swt.Main.main(java.lang.String[]) (Unknown Source) at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0) at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0) DEBUG::Tue Nov 22 09:43:45 GMT+01:00 2005::com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector::accept_loop()::-1: VirtualServerChannelSelector::access$1(com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector)::-1,VirtualServerChannelSelector$1::runSupport()::-1,AEThread::run()::-1,::GC_start_routine::-1,::__clone::-1 java.lang.NullPointerException at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector.accept_loop() (Unknown Source) at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector.access$1(com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector) (Unknown Source) at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector$1.runSupport() (Unknown Source) at org.gudy.azureus2.core3.util.AEThread.run() (Unknown Source) at .GC_start_routine (/usr/lib/libgcj.so.6.0.0) at .__clone (/lib/libc-2.3.5.so) DEBUG::Tue Nov 22 09:43:46 GMT+01:00 2005::com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector::accept_loop()::-1: VirtualServerChannelSelector::access$1(com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector)::-1,VirtualServerChannelSelector$1::runSupport()::-1,AEThread::run()::-1,::GC_start_routine::-1,::__clone::-1 java.lang.NullPointerException at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector.accept_loop() (Unknown Source) at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector.access$1(com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector) (Unknown Source) at com.aelitis.azureus.core.networkmanager.VirtualServerChannelSelector$1.runSupport() (Unknown Source) at org.gudy.azureus2.core3.util.AEThread.run() (Unknown Source) at .GC_start_routine (/usr/lib/libgcj.so.6.0.0) at .__clone (/lib/libc-2.3.5.so) Exception in thread "main" java.lang.UnsatisfiedLinkError: g_utf16_to_utf8 at org.eclipse.swt.internal.Converter.wcsToMbcs(java.lang.String, char[], boolean) (/usr/lib/eclipse/plugins/org.eclipse.swt.gtk_3.1.0.jar.so) at org.eclipse.swt.internal.Converter.wcsToMbcs(java.lang.String, java.lang.String, boolean) (/usr/lib/eclipse/plugins/org.eclipse.swt.gtk_3.1.0.jar.so) at org.eclipse.swt.widgets.Display.<clinit>() (Unknown Source) at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.6.0.0) at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.SWTThread(org.gudy.azureus2.ui.swt.mainwindow.Initializer) (Unknown Source) at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(org.gudy.azureus2.ui.swt.mainwindow.Initializer) (Unknown Source) at org.gudy.azureus2.ui.swt.mainwindow.Initializer.Initializer(com.aelitis.azureus.core.AzureusCore, org.gudy.azureus2.ui.swt.StartServer, java.lang.String[]) (Unknown Source) at org.gudy.azureus2.ui.swt.Main.Main(java.lang.String[]) (Unknown Source) at org.gudy.azureus2.ui.swt.Main.main(java.lang.String[]) (Unknown Source) at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0) at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0) ./azureus: line 112: 19451 Przerwane ${JAVA_PROGRAM_DIR}java -Xms16m -Xmx128m -cp "${CLASSPATH}" -Djava.library.path="${PROGRAM_DIR}" -Dazureus.install.path="${PROGRAM_DIR}" org.gudy.azureus2.ui.swt.Main "$@" Azureus TERMINATED. Macie jakies pomysly bo jestem poczatkujacy i nie wiem o co chodzi! Instalacje przeprowadzilem ze strony tu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jimmymk Napisano Listopad 22, 2005 Zgłoszenie Share Napisano Listopad 22, 2005 Proste, otworz skrypt azuerus w edytorze jakims, i zmien sciezki do javy. Dokladniej najpierw zmien to ###### CONFIGURE ####### JAVA_PROGRAM_DIR=”/usr/java/j2re1.4.2_04/bin/” # use full path .... (tu znajduje się przykładowa ścieżka do programu java) potem znajdz cos takiego i zmien sciezke, na sciezke do Twojej javy look_for_java() { JAVADIR=/usr/java/j2re1.4.2_04/ IFS=$' Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Sloan Napisano Listopad 22, 2005 Zgłoszenie Share Napisano Listopad 22, 2005 Zainstalowalem Azureusa i najnowsza JAVE i nie dziala Napisz, jak instalowałeś Azureusa i dlaczego robiłeś to koncie roota. Teraz nawet jak uruchomisz go, to wszystkie zmiany w ustawieniach będziesz musiał robić jako root i w ogóle będą same problemy z używaniem programu. Jeżeli instalowałeś javę tak jak jest na faq to w swoim katologu domowym utwórz podkatalog, rozpakuj tam Azureusa i uruchom go. Musi działać. Jak nie to napisz. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Bosek Napisano Listopad 22, 2005 Autor Zgłoszenie Share Napisano Listopad 22, 2005 Instalowałem tak : http://www.linux-newbie.net/modules.php?na...article&sid=216 Czemu na koncie roota? Nie wiem, jestem nowy i się uczę. /////////////////////////////////////////////////////////// Owszem działa ale tylko z konta roota! wiec jeśki jakiś katalog zostanie stworzony w Azureusuie to nie moge go edytować (usunąć) po windą bo musze mieć prawa roota. Gdy przechodzę na konto Bosek to azureus nie uruchamia się!!! [bosek@auv2 azureus]$ ./azureus Starting Azureus... Loading Azureus: /usr/java/jre1.5.0_04/bin/java -Xms16m -Xmx128m -cp "/home/bosek/azureus/Azureus2.jar:/home/bosek/azureus/swt.jar:/home/bosek/azureus/swt-mozilla.jar:/home/bosek/azureus/swt-pi.jar" -Djava.library.path="/home/bosek/azureus" -Dazureus.install.path="/home/bosek/azureus" org.gudy.azureus2.ui.swt.Main '' DEBUG::Thu Jan 01 01:00:00 CET 1970::org.gudy.azureus2.core3.util.FileUtil::renameFile::816: renameFile: target file '/home/bosek/.Azureus/logs/save/0_debug_1.log' already exists, failing AEDiagnostics::startup::134,AzureusCoreImpl::<init>::106,AzureusCoreImpl::create::67,AzureusCoreFactory::create::46,Main::<init>::35,Main::main::100 Xlib: connection to ":1.0" refused by server Xlib: No protocol specified Exception in thread "main" org.eclipse.swt.SWTError: No more handles at org.eclipse.swt.SWT.error(SWT.java:2717) at org.eclipse.swt.SWT.error(SWT.java:2616) at org.eclipse.swt.SWT.error(SWT.java:2587) at org.eclipse.swt.widgets.Display.createDisplay(Display.java:716) at org.eclipse.swt.widgets.Display.create(Display.java:701) at org.eclipse.swt.graphics.Device.<init>(Device.java:113) at org.eclipse.swt.widgets.Display.<init>(Display.java:409) at org.eclipse.swt.widgets.Display.<init>(Display.java:405) at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<init>(SWTThread.java:71) at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(SWTThread.java:55) at org.gudy.azureus2.ui.swt.mainwindow.Initializer.<init>(Initializer.java:106) at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:73) at org.gudy.azureus2.ui.swt.Main.main(Main.java:100) Azureus TERMINATED. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
