Ati, O Co Chodzi?!
exoticbird
Kwaka już nie mam-wywaliłem. Mogę napisać, co deno dooma3 wypisuje. Uruchamia się i widać czarny ekran, słychać jedynie dźwięk. Naciskam więc tyldę i wpisuję exit, żeby wyjść z gry.
[mimichaa@localhost doom3-demo]$ ./doom3-demo
DOOM 1.1.1286 linux-x86 Nov 28 2004 20:09:31
Hostname: localhost.localdomain
Alias: localhost
local IP: 127.0.0.1
------ Initializing File System ------
Loaded pk4 /usr/doom3-demo/demo/demo00.pk4 with checksum 0xfe75bbef
Current search path:
/home/mimichaa/.doom3-demo/demo
/usr/doom3-demo/demo/demo00.pk4 (12234 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
Running in restricted demo mode.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5151 strings read from strings/english.lang
Couldn't open journal files
couldn't exec editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Setup X display connection
dlopen(libGL.so.1)
Initializing OpenGL display
Using XFree86-VidModeExtension Version 2.2
Xlib: extension "XFree86-DGA" missing on display ":0.0".
Failed to detect DGA DirectVideo Mouse
Free86-VidModeExtension Activated at 640x480
Using 8/8/8 Color bits, 8 Alpha bits, 24 depth, 8 stencil display.
GL_RENDERER: RADEON 9200 Series DDR Generic
GL_EXTENSIONS: GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_bufferGL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
------- Input Initialization -------
XKB extension: compile time 0x1:0x0, runtime 0x1:0x0: OK
XKB extension present on server ( 0x1:0x0 )
dlopen(libasound.so.2)
asoundlib version: 1.0.10rc3
Alsa is available
------ Alsa Sound Initialization -----
opened Alsa PCM device default for playback
device buffer size: 15052 frames ( 60208 bytes )
allocated a mix buffer of 16384 bytes
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
X..GL_ARB_texture_non_power_of_two not found
...using GL_ARB_texture_compression
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_EXT_texture_lod
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
...using GL_ATI_fragment_shader
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
X..GL_ARB_fragment_program not found
X..EXT_depth_bounds_test not found
---------- R_NV20_Init ----------
Not available.
----------- R200_Init -----------
GL_NUM_FRAGMENT_REGISTERS_ATI: 6
GL_NUM_FRAGMENT_CONSTANTS_ATI: 8
GL_NUM_PASSES_ATI: 2
GL_NUM_INSTRUCTIONS_PER_PASS_ATI: 8
GL_NUM_INSTRUCTIONS_TOTAL_ATI: 16
GL_COLOR_ALPHA_PAIRING_ATI: 1
GL_NUM_LOOPBACK_COMPONENTS_ATI: 3
GL_NUM_INPUT_INTERPOLATOR_COMPONENTS_ATI: 3
FPROG_FAST_PATH
---------- R_ARB2_Init ----------
Not available.
---------- R_Exp_Init -----------
Disabled at compile time.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp: GL_FRAGMENT_PROGRAM_ARB not available
glprogs/interaction.vfp
glprogs/interaction.vfp: GL_FRAGMENT_PROGRAM_ARB not available
glprogs/bumpyEnvironment.vfp
glprogs/bumpyEnvironment.vfp: GL_FRAGMENT_PROGRAM_ARB not available
glprogs/ambientLight.vfp
glprogs/ambientLight.vfp: GL_FRAGMENT_PROGRAM_ARB not available
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
glprogs/environment.vfp: GL_FRAGMENT_PROGRAM_ARB not available
using ARB_vertex_buffer_object memory
using R200 renderSystem
glGetError() = 0x500
--------- Initializing Game ----------
gamename: baseDOOM-1
gamedate: Nov 28 2004
Initializing event system
...472 event definitions
Initializing class hierarchy
...141 classes, 381376 bytes for event callbacks
Initializing scripts
/proc/cpuinfo CPU frequency: 1585.97 MHz
Compiled 'weapon_handgrenade::Lower': 4180.9 ms
---------- Compile stats ----------
Memory usage:
Strings: 79, 12656 bytes
Statements: 67783, 1355660 bytes
Functions: 2108, 250452 bytes
Variables: 147320 bytes
Mem used: 2476308 bytes
Static data: 2277552 bytes
Allocated: 3283404 bytes
Thread size: 7068 bytes
...6 aas types
game initialized.
-------- Initializing Session --------
session initialized
--- Common Initialization Complete ---
terminal support enabled ( use +set in_tty 0 to disabled )
pid: 2734
1264 MB System Memory
guessing video ram ( use +set sys_videoRam to force ) ..
96 MB Video Memory
Async thread started
snd_pcm_writei short write: 3760 out of 4096
snd_pcm_writei short write: 1880 out of 2048
snd_pcm_writei short write: 940 out of 1024
idAudioHardwareALSA::Write: 4096 frames overflowed and dropped
]exit
--------- Game Map Shutdown ----------
Shutting down sound hardware
----------- Alsa Shutdown ------------
close pcm
dlclose
idRenderSystem::Shutdown()
------------ Game Shutdown -----------
Shutdown event system
shutdown terminal support
Dobra a quake 3 wypisuje:
[mimichaa@localhost quake3]$ ./quake3
ioQ3 1.33 linux-i386 Nov 14 2005
----- FS_Startup -----
/home/mimichaa/.q3a/baseq3
/usr/games/quake3/baseq3/pak0.pk3 (3539 files)
./baseq3/pak0.pk3 (3539 files)
./baseq3
7078 files in pk3 files
execing default.cfg
couldn't exec q3config.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Joystick is not active.
...loading libGL.so.1: Calling SDL_Init(SDL_INIT_VIDEO)...
SDL_Init(SDL_INIT_VIDEO) passed.
...setting mode 3: 640 480
Using 8/8/8 Color bits, 24 depth, 0 stencil display.
Initializing OpenGL extensions
...ignoring GL_S3_s3tc
...ignoring GL_EXT_texture_env_add
...using GL_EXT_compiled_vertex_array
GL_VENDOR: ATI Technologies Inc.
GL_VERSION: 1.3.1030 (X4.3.0-8.20.8)
GL_EXTENSIONS: GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 6
PIXELFORMAT: color(24-bits) Z(24-bit) stencil(0-bits)
MODE: 3, 640 x 480 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU:
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: disabled
compressed textures: disabled
Initializing Shaders
...loading 'scripts/base.shader'
...loading 'scripts/base_button.shader'
...loading 'scripts/base_floor.shader'
...loading 'scripts/base_light.shader'
...loading 'scripts/base_object.shader'
...loading 'scripts/base_support.shader'
...loading 'scripts/base_trim.shader'
...loading 'scripts/base_wall.shader'
...loading 'scripts/common.shader'
...loading 'scripts/ctf.shader'
...loading 'scripts/eerie.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/gothic_block.shader'
...loading 'scripts/gothic_floor.shader'
...loading 'scripts/gothic_light.shader'
...loading 'scripts/gothic_trim.shader'
...loading 'scripts/gothic_wall.shader'
...loading 'scripts/hell.shader'
...loading 'scripts/liquid.shader'
...loading 'scripts/menu.shader'
...loading 'scripts/models.shader'
...loading 'scripts/organics.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/shrine.shader'
...loading 'scripts/skin.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/test.shader'
----- finished R_Init -----
------- sound initialization -------
SDL Audio driver initializing...
Calling SDL_Init(SDL_INIT_AUDIO)...
Received signal 11, exiting...
----- CL_Shutdown -----
RE_Shutdown( 1 )
  • 2 weeks later...
@exoticbird
Hej!
To chyba ten sam problem co u mnie. sad.gif Przeczytaj mój topic: my topic
Znalazłem coś takiego: Bugzilla
Chyba coś jest nie tak z tymi sterownikami... (
Pozdrawiam,
Piotr
PS. Znalazłem jeszcze to: Link
Chyba spróbuję starszych sterów bo teraz mam problem nie tylko z Q3 ale też z GL-117 a przedtem GL-117 u mnie działało (chyba na sterach 8.16 ale oczywiście nie jestem pewien).
  • 3 weeks later...
exoticbird Composite to rozszerzenie do standardowych opcji wizualnych smile.gif
Czy masz włączone sprawdzasz:
xdpyinfo | head -n 60
Niestety przy kartach ATI nie da się go osiągnać nie tracąc dri, więc jego używanie tutaj mija się z celem.
Sugerowałem że być może miałeś dodaną do xorg.conf sekcję:
Section "Extensions"
  Option "Composite" "Enable"
EndSection
U mnie z tą opcją, system przy odpalaniu jakiejkolwiek gierki z akceleracją 3d, wykrzaczał się wydajnościowo oraz wizualnie, objawy były podobne jak u Ciebie więc to zasugerowałem.
Pozdro
