dextroyer Napisano Styczeń 11, 2006 Zgłoszenie Share Napisano Styczeń 11, 2006 Zsinstalwoalem ET plus 2.60 update, internet dziala a serwery sie nie pojawiaja, zrodlo mam ustawione na internet. w konsoli wywala mi to ET 2.60 linux-i386 Mar 10 2005 ----- FS_Startup ----- Current search path: /home/dex/.etwolf/etmain /usr/local/games/enemy-territory/etmain/pak2.pk3 (22 files) /usr/local/games/enemy-territory/etmain/pak1.pk3 (10 files) /usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files) /usr/local/games/enemy-territory/etmain/mp_bin.pk3 (6 files) /usr/local/games/enemy-territory/etmain ---------------------- 3763 files in pk3 files execing default.cfg couldn't exec language.cfg execing profiles/dextroyer/etconfig.cfg couldn't exec autoexec.cfg Hunk_Clear: reset the hunk ok ------- Input Initialization ------- Joystick is not active. ------------------------------------ Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- ...loading libGL.so.1: Initializing OpenGL display ...setting mode 4: 800 600 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 800x600 Using 4/4/4 Color bits, 24 depth, 0 stencil display. GL_RENDERER: RADEON 9550 Generic Initializing OpenGL extensions ...using GL_S3_s3tc ...ignoring GL_EXT_texture_env_add ...using GL_ARB_multitexture ...using GL_EXT_compiled_vertex_array ...GL_NV_fog_distance not found ...ignoring GL_EXT_texture_filter_anisotropic Initializing GLX extensions ... GLX_SGI_swap_control not found ... GLX_SGI_video_sync not found XF86 Gamma extension initialized GL_VENDOR: ATI Technologies Inc. GL_RENDERER: RADEON 9550 Generic GL_VERSION: 1.3.5519 (X4.3.0-8.20.8) GL_EXTENSIONS: GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ARB_draw_buffers GL_ATI_draw_buffers GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_object GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GLX_EXTENSIONS: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_ARB_get_proc_address GLX_ARB_multisample GL_MAX_TEXTURE_SIZE: 2048 GL_MAX_ACTIVE_TEXTURES_ARB: 8 PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits) MODE: 4, 800 x 600 fullscreen hz:N/A GAMMA: hardware w/ 0 overbright bits CPU: rendering primitives: single glDrawElements texturemode: GL_LINEAR_MIPMAP_LINEAR picmip: 0 texture bits: 32 multitexture: enabled compiled vertex arrays: enabled texenv add: disabled compressed textures: enabled anisotropy: 1.0 NV distance fog: disabled Initializing Shaders ----- finished R_Init ----- ------- sound initialization ------- /dev/dsp: Device or resource busy Could not open /dev/dsp ------------------------------------ Sound memory manager started Sys_LoadDll(/home/dex/.etwolf/etmain/ui.mp.i386.so)... Sys_LoadDll(/home/dex/.etwolf/etmain/ui.mp.i386.so) failed: "/home/dex/.etwolf/etmain/ui.mp.i386.so: cannot open shared object file: No such file or directory" Sys_LoadDll(/usr/local/games/enemy-territory/etmain/ui.mp.i386.so)... ok Sys_LoadDll(ui) found **vmMain** at 0x76b4f40 Sys_LoadDll(ui) succeeded! --- Common Initialization Complete --- Opening IP socket: localhost:27960 Started tty console (use +set ttycon 0 to disable) Resolving etmaster.idsoftware.com etmaster.idsoftware.com resolved to 192.246.40.60:27951 Requesting servers from the master... Requesting servers from the master... ^5PunkBuster Client: PunkBuster Client (v1.152 | A0) Enabled ^5PunkBuster Client: Game Version [ET 2.60 linux-i386 Mar 10 2005] ^5PunkBuster Client: Not Connected to a Server ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- ----- CL_Shutdown ----- ----------------------- Shutdown tty console Wie ktos o co chodzi ?? czemu nie laczy z serwerem ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
