Problem Z Grafiką Xorg.conf
wasert
Motam sie juz od kilku dni i powanie nie mam pojecia jakie mam wpisac parametry monitora i karty graficznej zeby wszystko bylo dobrze.
Zainstalowalem sobie Fedore na VirtualPC i caly czas nie mam grafiki tylko jakies paski.
Z tego co doczytalem sie w google to byc moze chodzi o poprawne ustawienia w pliku xorg.conf, ale tez probowalem i nic nie wychodzi.
Czy spotkaliscie sie z czyms podobnym kiedy i wiecie jak to zalatwic ??
Pozdrawiam !
1) zrob kopie pliku
2) masz moj, moze ci pojdzie
# XFree86 4 configuration created by pyxf86config
Section "ServerLayout"
Identifier     "Default Layout"
Screen      0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath      "/usr/X11R6/lib/X11/rgb"
ModulePath   "/usr/X11R6/lib/modules/extensions/nvidia"
ModulePath   "/usr/X11R6/lib/modules"
FontPath     "unix/:7100"
EndSection
Section "Module"
Load  "dbe"
Load  "extmod"
Load  "fbdevhw"
Load  "record"
Load  "freetype"
Load  "type1"
Load  "glx"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#	Option	"Xleds"  "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#	Option	"XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#	Option	"XkbModel"	"pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#	Option	"XkbModel"	"microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#	Option	"XkbLayout"	"de"
# or:
#	Option	"XkbVariant"	"nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#	Option	"XkbOptions"	"ctrl:swapcaps"
# Or if you just want both to be control, use:
#	Option	"XkbOptions"	"ctrl:nocaps"
Identifier  "Keyboard0"
Driver      "kbd"
Option     "XkbModel" "pc105"
Option     "XkbLayout" "pl"
EndSection
Identifier  "Mouse0"
Driver      "mouse"
Option     "Protocol" "IMPS/2"
Option     "Device" "/dev/input/mice"
Option     "ZAxisMapping" "4 5"
Option     "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "CTX PR705F series"
HorizSync    30.0 - 85.0
VertRefresh  50.0 - 160.0
Option     "dpms"
EndSection
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
VendorName  "Prolink"
BoardName   "NVIDIA GeForce 4 (generic)"
Option     "Coolbits" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     24
SubSection "Display"
 Viewport   0 0
 Depth     16
 Modes    "800x600" "640x480"
EndSubSection
 Viewport   0 0
 Depth     24
 Modes    "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "DRI"
Group        0
Mode         0666
EndSection
jezdze w 1152x864 w 85Hz, monitor CTX PR705F
  • 4 weeks later...
