Dekorator Rpm....
mysio
Podczas tworzenia rpm-a wyskakuje błąd:
checking for perl... /usr/bin/perl
checking for Qt... configure: error: Qt (>= Qt 3.3 and < 4.0) (library qt-mt) not found. Please check your installation!
For more details about this problem, look at the end of config.log.
Make sure that you have compiled Qt with thread support!
to mam:
[root@m2free mysio]# rpm -qa | grep gcc
gcc-gnat-4.0.2-8.fc4
libgcc-4.0.2-8.fc4
gcc-c++-4.0.2-8.fc4
gcc-gfortran-4.0.2-8.fc4
libgcc-4.0.2-8.fc4
compat-libgcc-296-2.96-132.fc4
gcc-4.0.2-8.fc4
gcc-java-4.0.2-8.fc4
gcc-objc-4.0.2-8.fc4
[root@m2free mysio]# rpm -qa qt*
qt-3.3.4-15.4
qt-designer-3.3.4-15.4
qtparted-0.4.5-1.fc4
qt-3.3.4-15.4
qt-config-3.3.4-15.4
qt-devel-3.3.4-15.4
qt.x86_64                                1:3.3.4-14             base
Matched from:
/usr/lib64/qt-3.3/lib/libqt-mt.so.3
/usr/lib64/qt-3.3/lib/libqt-mt.so.3.3.4
libqt-mt.so.3()(64bit)
qt.i386                                  1:3.3.4-14             base
Matched from:
/usr/lib/qt-3.3/lib/libqt-mt.so.3.3.4
libqt-mt.so.3
qt.x86_64                                1:3.3.4-15.4           updates-released
Matched from:
qt.i386                                  1:3.3.4-15.4           updates-released
Matched from:
libqt-mt.so.3
Matched from:
qt-devel.x86_64                          1:3.3.4-14             base
Matched from:
/usr/lib64/qt-3.3/lib/libqt-mt.prl
/usr/lib64/pkgconfig/qt-mt.pc
/usr/lib64/qt-3.3/lib/pkgconfig/qt-mt.pc
Matched from:
Matched from:
Matched from:
libqt-mt.so.3
Matched from:
qt-devel.x86_64                          1:3.3.4-15.4           updates-released
Matched from:
Matched from:
Matched from:
Matched from:
libqt-mt.so.3
qt.i386                                  1:3.3.4-15.4           installed
Matched from:
libqt-mt.so.3
qt.x86_64                                1:3.3.4-15.4           installed
Matched from:
qt-devel.x86_64                          1:3.3.4-15.4           installed
Matched from:
Lipa mam wszystkie te paczki i dalej ten sam błąd
Edytowane przez mysio
Być może chodzi o to ,że QT masz skompilowane ale bez obsługi wątków... ktoś kto tworzył paczkę którą masz zainstalowaną widocznie zapomniał dodać do ./configure coś w stylu:
--enable-threads
przy ręcznej kompilacji programów często mam ten problem. z tym samym plikiem, muszę wtedy dorzucić do ./configure parametr ze ścieżką /usr/lib64/qt-3.3/lib/ u Ciebie to moze być ścieżka /usr/lib/qt-3.3/lib/libq
..... dodaj ją przy robieniu paczki
