Kicker
cosmo
Witam mam problem z kickerem. Przy każdym wyłączeniu mam taki błąd że
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
`shared object read from target memory' has disappeared; keeping its symbols.
[KCrash handler]
#5  0x0065a469 in QUnicodeTables::line_break_info ()
  from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#6  0x08dd2aa8 in ?? ()
#7  0x08dd3900 in ?? ()
#8  0x00000010 in ?? ()
#9  0xbfb594f8 in ?? ()
#10 0x0050095f in QGLWidget::QGLWidget$base ()
#11 0x0063f80b in typeinfo name for QPtrQueue<QNetworkOperation> ()
#12 0x08dd2aa8 in ?? ()
#13 0x08dd3900 in ?? ()
#14 0x00000010 in ?? ()
#15 0xbfb59518 in ?? ()
#16 0x0050095f in QGLWidget::QGLWidget$base ()
#17 0x0063f926 in typeinfo name for QPtrQueue<QNetworkOperation> ()
#18 0x08dfda00 in ?? ()
#19 0x00f6c953 in ?? ()
#20 0x004fffcd in QGLWidget::glInit () from /usr/lib/qt-3.3/lib/libqt-mt.so.3
#21 0x0062862a in QSocket::staticMetaObject ()
#22 0x00628784 in QSocket::qt_static_property ()
#23 0x003804a1 in QPtrVector<QListViewPrivate::Column>::~QPtrVector$delete ()
#24 0x00381235 in QMainWindow::setStatusBar ()
#25 0x003812cb in QMainWindow::setStatusBar ()
#26 0x0037e2db in QCheckListItem::QCheckListItem ()
#27 0x006572ca in typeinfo name for QLibrary ()
#28 0x0f43c958 in ?? ()
#29 0x092c9ec8 in ?? ()
#30 0xbfb59888 in ?? ()
#31 0x00bc6225 in ?? () from /usr/lib/qt-3.3/plugins/inputmethods/libqxim.so
#32 0x092c9ec8 in ?? ()
#33 0x00000002 in ?? ()
#34 0xbfb59874 in ?? ()
#35 0x00bcb528 in ?? () from /usr/lib/qt-3.3/plugins/inputmethods/libqxim.so
#36 0x0f43c958 in ?? ()
#37 0x08e6c0b8 in ?? ()
#38 0xbfb598c8 in ?? ()
#39 0x00bc760f in QXIMInputContext::setHolderWidget ()
#40 0x00bc760f in QXIMInputContext::setHolderWidget ()
#41 0x0281ee70 in ?? ()
#42 0x08e6c0b8 in ?? ()
#43 0x08e2c290 in ?? ()
#44 0xbfb598f4 in ?? ()
#45 0x02b96df0 in ?? ()
#46 0x08e698d8 in ?? ()
#47 0x08e6993c in ?? ()
#48 0xbfb59908 in ?? ()
#49 0x009ac7d8 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#50 0xbfb59960 in ?? ()
#51 0x0f44d030 in ?? ()
#52 0x12a02868 in ?? ()
#53 0x009af854 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#54 0xbfb599b8 in ?? ()
#55 0x08e698d8 in ?? ()
#56 0xbfb59938 in ?? ()
#57 0x009abe8d in ?? () from /usr/lib/libartsmodulesmixers.so.0
#58 0xbfb59960 in ?? ()
#59 0x08e2c290 in ?? ()
#60 0xbfb59938 in ?? ()
#61 0x009abdca in ?? () from /usr/lib/libartsmodulesmixers.so.0
#62 0x08e6993c in ?? ()
#63 0x009ae2b1 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#64 0xffffffff in ?? ()
#65 0x0f4414c8 in ?? ()
#66 0x08e698d8 in ?? ()
#67 0x009af854 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#68 0xbfb59968 in ?? ()
#69 0x009ac03e in ?? () from /usr/lib/libartsmodulesmixers.so.0
#70 0x08e698d8 in ?? ()
#71 0xbfb59960 in ?? ()
#72 0xbfb59968 in ?? ()
#73 0x009ac008 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#74 0x009af854 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#75 0x009af854 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#76 0xbfb59978 in ?? ()
#77 0x009ad751 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#78 0x12a02868 in ?? ()
#79 0x009af854 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#80 0xbfb59988 in ?? ()
#81 0x009ac2d9 in ?? () from /usr/lib/libartsmodulesmixers.so.0
#82 0x08e698d8 in ?? ()
#83 0xbfb599b8 in ?? ()
#84 0xbfb59988 in ?? ()
#85 0x009ac2be in ?? () from /usr/lib/libartsmodulesmixers.so.0
#86 0x0f44af60 in ?? ()
#87 0x02b96df0 in ?? ()
#88 0xbfb599c8 in ?? ()
#89 0x0281ee70 in ?? ()
#90 0x08e698d8 in ?? ()
#91 0x08e2c290 in ?? ()
#92 0xbfb599b4 in ?? ()
#93 0x02b96df0 in ?? ()
#94 0x08e2c290 in ?? ()
#95 0x08e2c290 in ?? ()
#96 0xbfb599c8 in ?? ()
#97 0x02544e9e in ?? ()
#98 0xbfb599f8 in ?? ()
#99 0x0f44af30 in ?? ()
#100 0x08d05d40 in ?? ()
#101 0x02b96df0 in ?? ()
#102 0xbfb599f8 in ?? ()
#103 0x08e2c290 in ?? ()
#104 0xbfb59a08 in ?? ()
#105 0x02581526 in ?? ()
#106 0xbfb599f8 in ?? ()
#107 0x08e2c290 in ?? ()
#108 0x005b8428 in QTextCodecFromIOD::QTextCodecFromIOD ()
1. Co to jest kicker i do czego służy?
2. Co może powodować taki blad?
nie mam pojęcia co moze być problemem, po przejżeniu tego co wkleiłes to mogę rozpoznać tam libqt-mt i libqxim oraz dodatkowo jakiś moduł arts. może zaprzągnij google do pracy i poszukaj czegoś o arts i kickerze albo qt i kickerze. system jest po updacie więc update programów nic nie pomoże.
od kiedy masz takie problemy? pojawiły sie po updacie czy były wcześniej?
