cygii Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Mam zainstalowane stery Nvidii po komendzie ./ configure wywala mi cos takeigo [root@localhost tuxracer-0.61]# ./configure loading cache ./config.cache checking for a BSD compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking whether make sets ${MAKE}... yes checking for working aclocal... found checking for working autoconf... found checking for working automake... found checking for working autoheader... found checking for working makeinfo... found checking host system type... i686-pc-linux-gnu checking for gcc... gcc checking whether the C compiler (gcc ) works... yes checking whether the C compiler (gcc ) is a cross-compiler... no checking whether we are using GNU C... yes checking whether gcc accepts -g... yes checking for c++... c++ checking whether the C++ compiler (c++ ) works... yes checking whether the C++ compiler (c++ ) is a cross-compiler... no checking whether we are using GNU C++... yes checking whether c++ accepts -g... yes checking for ranlib... ranlib checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/time.h... yes checking for unistd.h... yes checking for working const... yes checking whether time.h and sys/time.h may both be included... yes checking for getcwd... yes checking for gettimeofday... yes checking for strdup... yes checking for finite... yes checking for isnan... yes checking for _finite... no checking for _isnan... no checking for ieeefp.h... no checking for Win32 platform... no checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include checking for dnet_ntoa in -ldnet... no checking for dnet_ntoa in -ldnet_stub... no checking for gethostbyname... yes checking for connect... yes checking for remove... yes checking for shmat... yes checking for IceConnectionNumber in -lICE... yes checking for main in -ldl... yes checking for main in -lm... yes checking for tcl8.3 library... no checking for tcl83 library... no checking for tcl8.2 library... no checking for tcl82 library... no checking for tcl8.0 library... no checking for tcl80 library... no checking for tcl library... yes checking for tcl.h... yes checking for sdl-config... /usr/bin/sdl-config checking for SDL - version >= 1.0.1... yes checking for SDL_JoystickOpen... yes checking for Mix_OpenAudio in -lSDL_mixer... no *** SDL_mixer not found. Configuring without audio support. checking for GL library... yes checking for glXGetProcAddressARB... yes checking for GLU library... yes checking for GL/gl.h... yes checking for GL/glx.h... yes checking whether glx.h defines glXGetProcAddressARB... no configure: error: Your copy of glx.h is out of date. You can get a more recent copy from the latest Mesa distribution (http://mesa3d.sourceforge.net). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
McGiwer Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Może to nie jest dokładna odpowiedź na Twoje pytanie, ale dlaczego instalujesz przez make? Lepiej ściągnij gotowy pakiet RPM. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Daniello Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Dlaczego niby miałby się zniżać do poziomu pakietów ?? Lepiej żeby rozwinął swój umysł. Po to jest ten Linux, żeby rozwijał korzenie myślenia w człowieku. Nie mówię, że to jest złe rozwiązanie instalować pakiet, ale jaka w tym filozofia ?! Aha, no i jak ci się uda zainstalować (ze źródła), to musisz jeszcze ściągnąć paczkę tuxracer-data dostępną również na stronie tuxracer'a. Wszystkie pliki z tej paczki przegrywasz do katalogu zasobów gry. Czyli jak instalowałeś do /usr, to będziesz musiał przegrać do /usr/share/tuxracer Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Coś mu wersja danego pliku nie pasuje. Weź zainstaluj/zrób upgrade sterów do grafy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Daniello Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 na stronie mesa3d.sourceforge.net ma opisane co musi zrobic. Ściągnąć trzy paczki: MesaGLUT, MesaDemos, MesaLib. ściąga, rozpakowuje. Wchodzi do katalogu Mesa-6.4.1 i wpisuje make platforma W podkatalogu configs ma rózne platformy i wybiera tę która pasuje własnie jemu. Ja wpisałem make linux-x86 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 TUX racer zmienil nazwe na PPacer i jest w repo livna razem z zaleznosciami. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
McGiwer Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Dlaczego niby miałby się zniżać do poziomu pakietów ?? Lepiej żeby rozwinął swój umysł. Po to jest ten Linux, żeby rozwijał korzenie myślenia w człowieku. Nie mówię, że to jest złe rozwiązanie instalować pakiet, ale jaka w tym filozofia ?!Filozofia jest taka, że Fedora Core to system oparty na RPM i jeżeli jest dostępna paczka to zalecana jest instalacja własnie niej, a nie tarballa. Instalacja przez make potrafi nieźle namieszać i czasami ciężko jest później np. dokładnie pousuwać wszystkie pliki stworzone podczas takiej operacji. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
