Dziwny Bład :(
MitS
Witam!
Po raz pierwszy spotykam taki błąd:
[mits@ozyrys Desktop]$ mplayer bjj_vs_jj.wmv -fs
Using GNU internationalization
Original domain: messages
Original dirname: /usr/share/locale
Current domain: mplayer
Current dirname: /usr/share/locale
MPlayer 1.0pre7-4.0.2 (C) 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Athlon MP/XP Thoroughbred (Family: 6, Stepping: 1)
Detected cache-line size is 64 bytes
CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0 : No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing bjj_vs_jj.wmv.
ASF file format detected.
VIDEO:  [WMV2]  320x240  24bpp  1000.000 fps    0.0 kbps ( 0.0 kbyte/s)
Clip info:
name:
author:
copyright:
comments:
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16le, 64.0 kbit/4.54% (ratio: 8005->176400)
Selected audio codec: [ffwmav2] afm:ffmpeg (DivX audio v2 (FFmpeg))
vo: X11 running at 1280x1024 with depth 24 and 32 bpp (":0.0" => local display)
vo_xvmc: X-Video extension 2.2
vo_xvmc: X-Video MotionCompensation Extension version 1.0
Opening video decoder: [dshow] DirectShow video codecs
Win32 LoadLibrary failed to load: wmv8ds32.ax, /usr/lib/win32/wmv8ds32.ax, /usr/local/lib/win32/wmv8ds32.ax
Warning: DS_Filter() could not open DirectShow DLL.  (DLL=wmv8ds32.ax, r=0x847720c)
Failed to create DirectShow filter
ERROR: Could not open required DirectShow codec wmv8ds32.ax.
You need to upgrade/install the binary codecs package.
Go to http://mplayerhq.hu/homepage/dload.html
VDecoder init failed :(
Opening video decoder: [dmo] DMO video codecs
Win32 LoadLibrary failed to load: wmvdmod.dll, /usr/lib/win32/wmvdmod.dll, /usr/local/lib/win32/wmvdmod.dll
IMediaObject ERROR: 0x84d53e9  could not open DMO DLL (0x0 : 0)
Failed to create DMO filter
ERROR: Could not open required DirectShow codec wmvdmod.dll.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffwmv2] vfm:ffmpeg (FFmpeg M$ WMV2/WMV8)
Checking audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le...
AF_pre: 44100Hz/2ch/s16le
AO: [oss] 44100Hz 2ch s16le (2 bps)
Building audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le...
Starting playback...
[wmv2 @ 0x85d4630]I7:0/
VDec: vo config request - 320 x 240 (preferred csp: Planar YV12)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
mplayer: vf.c:250: vf_get_image: Assertion `vf->w > 0' failed.
MPlayer interrupted by signal 6 in module: decode_video
- MPlayer crashed. This shouldn't happen.
 It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
 gcc version. If you think it's MPlayer's fault, please read
 DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
 won't help unless you provide this information when reporting a possible bug.
Kodeki mam wgrane ...co mam zrobić ?
