dextroyer Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Czesc, po zripowaniu z dvd chce przerobic na *.avi i biore transcode poczym wyswietla sie okno z wiadomoscia: Wed Jan 18 18:43:57 2006 Starting job (1): Determine number of titles Wed Jan 18 18:43:57 2006 Executing command: dr_exec tcprobe -H 10 -i /dev/dvd && echo DVDRIP_SUCCESS Wed Jan 18 18:43:57 2006 Job has PID 3074 Wed Jan 18 18:43:59 2006 Successfully finished job (1): Determine number of titles Wed Jan 18 18:43:59 2006 Starting job (2): Probing - title #1 Wed Jan 18 18:43:59 2006 Executing command: dr_exec tcprobe -H 10 -i /dev/dvd -T 1 && echo DVDRIP_SUCCESS; dr_exec dvdxchap -t 1 /dev/dvd 2>/dev/null Wed Jan 18 18:43:59 2006 Job has PID 3076 Wed Jan 18 18:43:59 2006 Probing - title #1: 90% done. Wed Jan 18 18:43:59 2006 Set container format to 'mpeg' Wed Jan 18 18:43:59 2006 Successfully probed title #1 Wed Jan 18 18:43:59 2006 Successfully finished job (2): Probing - title #1 Wed Jan 18 18:43:59 2006 Copying IFO files to /mnt/xp_d/dvd/data/kruk/tmp/ifo Wed Jan 18 18:43:59 2006 Project file saved to '/mnt/xp_d/dvd/data/kruk/tmp/backup.rip' Wed Jan 18 18:44:25 2006 This task needs about 6 MB, 7864 MB are free. Wed Jan 18 18:44:25 2006 Starting job (1): Ripping - title #1 Wed Jan 18 18:44:25 2006 Executing command: rm -f /mnt/xp_d/dvd/data/kruk/vob/001/kruk-???.vob && dr_exec tccat -t dvd -T 1,-1,1 -i /dev/dvd | dr_splitpipe -f /mnt/xp_d/dvd/data/kruk/tmp/kruk-001-nav.log 1024 /mnt/xp_d/dvd/data/kruk/vob/001/kruk vob | tcextract -a 1 -x ac3 -t vob | tcdecode -x ac3 | tcscan -x pcm && echo DVDRIP_SUCCESS Wed Jan 18 18:44:25 2006 Job has PID 3086 Wed Jan 18 18:45:59 2006 Ripping - title #1: 10% done. Wed Jan 18 18:47:09 2006 Ripping - title #1: 20% done. Wed Jan 18 18:48:07 2006 Ripping - title #1: 30% done. Wed Jan 18 18:49:00 2006 Ripping - title #1: 40% done. Wed Jan 18 18:49:53 2006 Ripping - title #1: 50% done. Wed Jan 18 18:50:46 2006 Ripping - title #1: 60% done. Wed Jan 18 18:51:30 2006 Ripping - title #1: 70% done. Wed Jan 18 18:52:14 2006 Ripping - title #1: 80% done. Wed Jan 18 18:52:53 2006 Ripping - title #1: 90% done. Wed Jan 18 18:53:37 2006 Program stream units calculated Wed Jan 18 18:53:37 2006 Successfully finished job (1): Ripping - title #1 Wed Jan 18 18:53:37 2006 This task needs about 0 MB, 4033 MB are free. Wed Jan 18 18:53:37 2006 Starting job (1): Grabbing preview - title #1, frame #61683 Wed Jan 18 18:53:37 2006 Executing command: mkdir -m 0775 /tmp/dvdrip3030.ppm; cd /tmp/dvdrip3030.ppm; dr_exec transcode -H 10 -z -k -o snapshot -y ppm,null -x vob,null -i /mnt/xp_d/dvd/data/kruk/vob/001 -c 3-4 -L 1020850 && dr_exec convert -size 720x576 /tmp/dvdrip3030.ppm/snapshot*.ppm /mnt/xp_d/dvd/data/kruk/tmp/kruk-001-preview-orig.jpg && dr_exec convert -size 720x576 /tmp/dvdrip3030.ppm/snapshot*.ppm gray:/mnt/xp_d/dvd/data/kruk/tmp/kruk-001-preview-orig.raw && rm -r /tmp/dvdrip3030.ppm && echo DVDRIP_SUCCESS Wed Jan 18 18:53:38 2006 Project file saved to '/mnt/xp_d/dvd/data/kruk/tmp/backup.rip' Wed Jan 18 18:53:38 2006 Job has PID 3215 Wed Jan 18 18:53:39 2006 Job has PID 3227 Wed Jan 18 18:53:40 2006 Job has PID 3228 Wed Jan 18 18:53:41 2006 Successfully finished job (1): Grabbing preview - title #1, frame #61683 Wed Jan 18 18:53:58 2006 This task needs about 1399 MB, 4032 MB are free. Wed Jan 18 18:53:58 2006 Starting job (1): Transcoding video - title #1, pass 1 Wed Jan 18 18:53:58 2006 Executing command: mkdir -m 0775 -p '/mnt/xp_d/dvd/data/kruk/tmp' && cd /mnt/xp_d/dvd/data/kruk/tmp && dr_exec transcode -H 10 -a 1 -x vob,null -i /mnt/xp_d/dvd/data/kruk/vob/001 -w 2251 -F mpeg4 -b 128,0,0 -s 1.794 --a52_drc_off -V -f 25 -Y 8,8,8,8 -B 12,10,8 -R 1 -y ffmpeg,null -o /dev/null --print_status 20 && echo DVDRIP_SUCCESS Wed Jan 18 18:53:58 2006 Job has PID 3249 Wed Jan 18 18:53:59 2006 Aborting command. Sending signal 1 to PID 3249... Wed Jan 18 18:53:59 2006 Aborting job: Transcoding video - title #1, pass 1 Wed Jan 18 18:53:59 2006 You should analyze the last output of this job to see what's going wrong here: Wed Jan 18 18:53:59 2006 ---- job output start ---- *** WARNING: The option -V is deprecated. *** *** Transcode internal frame handling is now in YV12 / YUV420 *** *** format by default because most codecs can only handle this format, *** *** otherwise leading to unnecessary time and quality wasting conversions. *** *** If you want to have to "old" behaviour (RGB24 as internal format), *** *** then please use the new -1/--use_rgb option *** transcode v1.0.0 (C) 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg libdvdread: Using libdvdcss version 1.2.9 for DVD access libdvdread: Couldn't find device name. libdvdread: Can't open file VIDEO_TS.IFO. tc_memcpy: using sse for memcpy [import_null.so] v0.2.0 (2002-01-19) (video) null | (audio) null [import_vob.so] v0.6.0 (2003-10-02) (video) MPEG-2 | (audio) MPEG/AC3/PCM | (subtitle) [export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null [export_ffmpeg.so] v0.3.13 (2004-08-03) (video) Lavc49.0.0 | (audio) MPEG/AC3/PCM [export_ffmpeg.so] Using FFMPEG codec 'mpeg4' (FourCC 'DIVX', MPEG4 compliant video). [export_ffmpeg.so]: WARNING: Interlacing parameters unknown, use --encode_fields [export_ffmpeg.so]: INFO: No profile selected [export_ffmpeg.so] Neither './ffmpeg.cfg' nor '~/.transcode/ffmpeg.cfg' [export_ffmpeg.so] found. Default settings will be used instead. [export_ffmpeg.so]: INFO: Starting 1 thread(s) [export_ffmpeg.so]: INFO: Set display aspect ratio to input [mpeg4 @ 0x7423f0]removing common factors from framerate tc_memcpy: using sse for memcpy [decode_mpeg2.c] libmpeg2 0.4.0b loop decoder [decode_mpeg2.c] libmpeg2 acceleration: mmxext sh: line 1: 3249 Naruszenie ochrony pamięci dr_exec transcode -H 10 -a 1 -x vob,null -i /mnt/xp_d/dvd/data/kruk/vob/001 -w 2251 -F mpeg4 -b 128,0,0 -s 1.794 --a52_drc_off -V -f 25 -Y 8,8,8,8 -B 12,10,8 -R 1 -y ffmpeg,null -o /dev/null --print_status 20 Wed Jan 18 18:53:59 2006 ---- job output end ---- Co to znaczy i co ewentualnie zrobic zeby to dzialalo ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Daniello Napisano Styczeń 18, 2006 Zgłoszenie Share Napisano Styczeń 18, 2006 Wystąpiło naruszenie ochrony pamięci. Jest to błąd programisty, który tworzył tą grę, lub jądra. Nie wiem dokładnie co jest przyczyną tego błędu, ale najprawdopodobniej to, że jest to stara wersja programu. O ile jest nowsza wersja tego dvd::rip'a to wypróbuj ją i sprawdź czy nie będzie tego błędu. A propo jakie masz jądro ?? Fedory czy ręcznie kompilowane?? Spróbuj upgrade systemu. Na innym nowszym jądrze może pójdzie. Ale najpierw spróbuj tego pierwszego sposobu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dextroyer Napisano Styczeń 18, 2006 Autor Zgłoszenie Share Napisano Styczeń 18, 2006 Jadro fedory bez zadnych wlasnych poprawek niedawno robilem yum update , a swoja droga program powinien byc w miare nowy bo tez przez yuma sciagany chyba z freshrpms dzisiaj po poludniu . Czekam na pomysly ewentualnie jakis inny program do ripowania filmow dvd. Ten nosi nazwe DvD::Rip i dziala z transcode Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
