mw72 Napisano Luty 21, 2006 Zgłoszenie Share Napisano Luty 21, 2006 witam mam instalcje 2.6.15-1.1831_FC4 + madwifi-0.9.6.0-19.rhfc4.at.i386.rpm + madwifi-kmdl-2.6.15-1.1831_FC4-0.9.6.0-19.rhfc4.at.i686.rpm sprzet jest widoczny z iwconfig ath0 IEEE 802.11g ESSID:"XXXXXXXXXXXXX" Nickname:"XXXXXXXXXXXXX" Mode:Managed Frequency:2.437 GHz Access Point: 00:11:95:41:65:59 Bit Rate:1 Mb/s Tx-Power:18 dBm Sensitivity=0/3 Retry:off RTS thr:off Fragment thr:off Encryption key:xxxxxxxxxxxxxxxx Security mode:restricted Power Management:off Link Quality=0/94 Signal level=-95 dBm Noise level=-95 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 ifconfig ath0 Link encap:Ethernet HWaddr 00:0D:88:93:2F:3A UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:1556 dropped:0 overruns:0 frame:1556 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:200 RX bytes: 0 (0.0 b ) TX bytes: 0 (0.0 b ) Interrupt:5 Memory:e08c0000-e08d0000 niestety przy probie uruchomienia (podniesienie sieci) mam komunikat : Error for wireless request "Set Mode" (8B06) : SET failed on device ath0 ; Invalid argument. a przy iwlist ath0 scan ath0 Failed to read scan data : Resource temporarily unavailable w /etc/modprobe.conf alias eth0 8139too alias snd-card-0 snd-via82xx options snd-card-0 index=0 options snd-via82xx index=0 remove snd-via82xx { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-via82xx alias usb-controller ehci-hcd alias usb-controller1 uhci-hcd alias ath0 ath_pci ^^^^^^^^^^^^^^^^^^^^ dotychczas pracowalem z 520 i NdisWrapper i dzialalo wszystko gdzie popelniam blad ??!! co nie tak robie ??!! Mariusz ps. dwl-g520 rev A ps2. tworzylem pliki ifcfg-ath0 z konfiguraja - dobra- i nic nie pomoglo TYPE=Wireless DEVICE=ath0 HWADDR= BOOTPROTO=none NETMASK=xxxxxxxxxxxxxxx DHCP_HOSTNAME= IPADDR=xxxxxxxxxxxxxxxxx DOMAIN= IPV6INIT=no ONBOOT=no USERCTL=no PEERDNS=no GATEWAY=xxxxxxxxxxxxxx ESSID=xxxxxxxxxxxxxxx CHANNEL=6 MODE=Auto RATE=11M Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Zuk87 Napisano Luty 22, 2006 Zgłoszenie Share Napisano Luty 22, 2006 http://forum.fedora.pl/index.php?act=Searc...s&highlite=g520 PS. 1 - coś powinno Ci pomóc PS. 2 - sory, że tak długi link ale nie chciało mi się go skracać PS. 3 - wyszukiwarka to podstawa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mw72 Napisano Luty 22, 2006 Autor Zgłoszenie Share Napisano Luty 22, 2006 niestety twój link nie wniósł nic nowego no może poza kilkoma KB w bazie forum większość problemów dotyczy kart 520 bez "G" ale wracając do tematu - udało mi sie problem rozwiązać rozwiązanie trywialne stery madwifi potrzebują konkretnego wskazania i ifcfg musi być MODE=Managed karta obecnie działa bez problemu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
