uosiu Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 witam, mam problem z ustawieniem programu kino kak, aby mozna bylo zgrac film z kamery? garsc informacji kino ustawione na sterownik dv1394 urzadzenie /dev/dv1394/0 kamere wykrywa wysylanie na to samo urzadzenie co zgrywanie. pod sterownikiem raw1394 to samo. cos mowil o niezaladowanym module 1394 wiec zaladowalem ---- garsc plikow [uosiu@localhost ~]$ kino > Kino Common being built > Creating page editor > Creating Capture Page > Creating Export Page > Creating Export1394 Page > Creating ExportAVI Page > Creating ExportStills Page > Creating ExportAudio Page > Creating ExportMJPEG Page > Creating ExportPipe Page /usr/share/kino/scripts/exports/extract_chapters /usr/share/kino/scripts/exports/ffmpeg_mp3.sh /usr/share/kino/scripts/exports/ffmpeg_flv.sh /usr/share/kino/scripts/exports/ffmpeg_mp4.sh /usr/share/kino/scripts/exports/ffmpeg2theora.sh which: no ffmpeg2theora in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) /usr/share/kino/scripts/exports/ffmpeg_divx.sh /usr/share/kino/scripts/exports/ffmpeg_dvd_dual.sh which: no mplex in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) which: no dvdauthor in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) /usr/share/kino/scripts/exports/ffmpeg_dvd.sh which: no mplex in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) which: no dvdauthor in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) /usr/share/kino/scripts/exports/ffmpeg_3gp.sh which: no MP4Box in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) /usr/share/kino/scripts/exports/rawplay.sh which: no rawplay in (/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/uosiu/bin:/home/uosiu/bin) /usr/share/kino/scripts/exports/ffmpeg_divx_dual.sh /usr/share/kino/scripts/exports/ffmpeg_vcd.sh /usr/share/kino/scripts/exports/mencoder.sh > Creating page trim >> image creator repository created >>> Image Create: Fixed Colour >>> Image Create: Random noise >>> Image Create: Colour Range >>> Image Create: Gradiant >>> Image Create: Create From File >> image filter repository created >>> Image Filter: No Change >>> Image Filter: Black & White >>> Image Filter: Sepia >>> Image Filter: Reverse Video >>> Image Filter: Mirror >>> Image Filter: Kaleidoscope >>> Image Filter: Swap >> image transition repository created >>> Image Transition: No Change >>> Image Transition: Switch >>> Image Transition: Fade >>> Image Transition: Push Wipe >>> Image Transition: Barn Door Wipe >>> Image Transition: Differences >> audio filter repository created >>> Audio Filter: No Change >>> Audio Filter: Silence >>> Audio Filter: Fade In >>> Audio Filter: Fade Out >> audio transition repository created >>> Audio Transition: No Change >>> Audio Transition: Cross Fade >>> Audio Transition: Dub >>> Audio Transition: Mix > Creating Magick Page >> Searching /usr/lib/kino-gtk2 for plugins >> Starting Editor >> Kino Common newFile >> Creating undo/redo buffer >>> Received playlist to store at position 0 >>>> Adding to end >> on_main_window_map_event >> Leaving Editor >> Left Editor >> Starting Capture >>> Using dv1394 capture >> Trying XVideo at 720x576 >>> XvQueryAdaptors count: 4 >>> Xv: NV17 Video Overlay: ports 222 - 222 >>> formats supported: 4 >>> 0x32595559 (YUY2) packed >>> 0x32315659 (YV12) planar >>> 0x59565955 (UYVY) packed >>> 0x30323449 (I420) planar >>> 0: XV_IMAGE, 2046x2046 rate = 1/1 [uosiu@localhost ~]$ [root@localhost dv1394]# lsmod Module Size Used by raw1394 29741 2 dv1394 20749 0 nvidia 4090000 12 ppp_async 12353 1 crc_ccitt 2241 1 ppp_async ppp_generic 30293 5 ppp_async slhc 7233 1 ppp_generic ppdev 9157 0 parport_pc 27909 1 lp 12937 0 parport 35593 3 ppdev,parport_pc,lp autofs4 19653 1 ip_conntrack_ftp 8113 0 ipt_REJECT 5953 1 ipt_state 1985 8 ip_conntrack 52717 2 ip_conntrack_ftp,ipt_state nfnetlink 6617 1 ip_conntrack iptable_filter 3137 1 ip_tables 20033 3 ipt_REJECT,ipt_state,iptable_filter nls_utf8 2241 5 ntfs 225168 4 dm_mod 57177 0 video 16197 0 button 6737 0 battery 9541 0 ac 4933 0 eagle_usb 125352 0 ipv6 252577 14 usblp 13633 0 ohci1394 35593 1 dv1394 ieee1394 298009 3 raw1394,dv1394,ohci1394 uhci_hcd 32721 0 i2c_i801 9037 0 i2c_core 21697 1 i2c_i801 emu10k1_gp 3905 0 gameport 15689 2 emu10k1_gp snd_emu10k1_synth 7233 0 snd_emux_synth 35009 1 snd_emu10k1_synth snd_seq_virmidi 7489 1 snd_emux_synth snd_seq_midi_emul 6977 1 snd_emux_synth snd_emu10k1 114021 1 snd_emu10k1_synth snd_rawmidi 24801 2 snd_seq_virmidi,snd_emu10k1 snd_ac97_codec 88161 1 snd_emu10k1 snd_seq_dummy 3781 0 snd_seq_oss 31809 0 snd_seq_midi_event 7105 2 snd_seq_virmidi,snd_seq_oss snd_seq 49617 8 snd_emux_synth,snd_seq_virmidi,snd_seq_midi_emul,snd_seq_dummy,snd_seq_oss,snd_seq_midi_event snd_seq_device 9037 7 snd_emu10k1_synth,snd_emux_synth,snd_emu10k1,snd_rawmidi,snd_seq_dummy,snd_seq_oss,snd_seq snd_pcm_oss 50545 0 snd_mixer_oss 17985 1 snd_pcm_oss snd_pcm 86981 3 snd_emu10k1,snd_ac97_codec,snd_pcm_oss snd_timer 24901 3 snd_emu10k1,snd_seq,snd_pcm snd_ac97_bus 2497 1 snd_ac97_codec snd_page_alloc 10697 2 snd_emu10k1,snd_pcm snd_util_mem 4929 2 snd_emux_synth,snd_emu10k1 snd_hwdep 9185 2 snd_emux_synth,snd_emu10k1 snd 54309 13 snd_emux_synth,snd_seq_virmidi,snd_emu10k1,snd_rawmidi,snd_ac97_codec,snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer,snd_hwdep soundcore 9889 1 snd floppy 62085 0 ext3 129993 1 jbd 57941 1 ext3 [root@localhost dev]# ls admmidi dv1394 hdc loop4 midi parport3 ram14 root tty11 tty23 tty35 tty47 tty59 urandom vcs6 XOR adsp event0 hde loop5 mixer port ram15 rtc tty12 tty24 tty36 tty48 tty6 usb vcs7 zero agpgart fd hde1 loop6 net ppp ram2 sequencer tty13 tty25 tty37 tty49 tty60 usbdev1.1 vcs8 amidi fd0 hde2 loop7 null ptal-printd ram3 sequencer2 tty14 tty26 tty38 tty5 tty61 usbdev1.2 vcsa audio floppy hpet lp0 nvidia0 ptmx ram4 shm tty15 tty27 tty39 tty50 tty62 usbdev1.3 vcsa1 bus full initctl lp1 nvidia1 pts ram5 snd tty16 tty28 tty4 tty51 tty63 usbdev2.1 vcsa2 cdrom gpmctl input lp2 nvidia2 ram ram6 stderr tty17 tty29 tty40 tty52 tty7 usbdev2.2 vcsa3 cdwriter hda kmsg lp3 nvidia3 ram0 ram7 stdin tty18 tty3 tty41 tty53 tty8 vcs vcsa4 console hda1 log MAKEDEV nvidiactl ram1 ram8 stdout tty19 tty30 tty42 tty54 tty9 vcs1 vcsa5 core hda2 loop0 mapper par0 ram10 ram9 tty tty2 tty31 tty43 tty55 ttyS0 vcs2 vcsa6 disk hda5 loop1 md0 parport0 ram11 ramdisk tty0 tty20 tty32 tty44 tty56 ttyS1 vcs3 vcsa7 dmmidi hda6 loop2 mem parport1 ram12 random tty1 tty21 tty33 tty45 tty57 ttyS2 vcs4 vcsa8 dsp hda7 loop3 mice parport2 ram13 raw1394 tty10 tty22 tty34 tty46 tty58 ttyS3 vcs5 X0R [root@localhost dev]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
