Yum Update
Karlik
Więc uruchomiłem yum update, sciagnelo 603MB paczek, instalowalo sie i nagle zatrzymalo. Wydalem ponownie polecenie yum update, to wywalalo jakies dziwne bledy, po kolejnym pokazalo:
--> Running transaction check
--> Processing Dependency: net-snmp = 5.2.1-12 for package: net-snmp-libs
--> Processing Dependency: perl(DCOP) for package: kdesdk
--> Processing Dependency: dhcdbd for package: NetworkManager
--> Processing Dependency: libhpip.so.0 for package: hpijs
--> Processing Dependency: python-numeric for package: pygtk2
--> Restarting Dependency Resolution with new changes.
--> Populating transaction set with selected packages. Please wait.
---> Package dhcdbd.i386 0:1.9-1.FC4 set to be updated
---> Package libsane-hpaio.i386 0:0.9.8-3.2 set to be updated
---> Package kdebindings.i386 0:3.5.1-0.1.fc4 set to be updated
---> Package python-numeric.i386 0:23.7-2 set to be updated
--> Processing Dependency: libruby.so.1.8 for package: kdebindings
--> Processing Dependency: ruby >= 1.8 for package: kdebindings
---> Package ruby.i386 0:1.8.4-1.fc4 set to be updated
---> Package ruby-libs.i386 0:1.8.4-1.fc4 set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: net-snmp = 5.2.1-12 is needed by package net-snmp-libs
probowalem restatu systemu, ale nie pomoglo. Pojawia sie:
[root@localhost Karlik]# yum update
Setting up Update Process
Setting up repositories
livna                    100% |=========================|  951 B    00:00
updates-released          100% |=========================|  951 B    00:00
kadu                      100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
extras                    100% |=========================| 1.1 kB    00:00
primary.xml.gz            100% |=========================| 230 kB    00:07
livna    : ################################################## 775/775
Added 100 new packages, deleted 193 old in 7.32 seconds
Resolving Dependencies
---> Package audit.i386 0:1.0.14-1.fc4 set to be updated
i dalej jest poprzedni cytat
Proszę, pomóżcie
Nie ma sensu, naprawdę. Jak już tak bardzo chcesz to polecam:
yum dist-update
Chyba pomyliło Ci się z apt-get...
Po co (_wogóle_ → w ogóle) ORT to uaktualniasz ?? Widać że to nie są paczki na FC5, tylko nowsze na FC4
@Karlik w zasadzie to można poczekać te 2 tyg i wgrać FC 5, a nie aktualizować FC 4.
Masz problemy z zależnościami, możliwe że instalowałeś coś ze źródeł i Ci się skopały lub nie włączyłeś jakiegoś repo. Poszukaj brakujących pakietów na rpm.pbone.net i zobacz w jakim repo są.
