Blurp Napisano Marzec 5, 2006 Zgłoszenie Share Napisano Marzec 5, 2006 NA swieżo zainstalowanej i uaktualnionej za pomocą yuma fedorce 4 nie udaje mi się odpalić samby: service smb start Uruchamianie usług SMB: /etc/init.d/functions: line 83: 1942 Przerwane $nice $* W logach otrzymuje następujący komunukat [2006/03/06 00:22:54, 0] smbd/server.c:main(798) smbd version 3.0.14a-2 started. Copyright Andrew Tridgell and the Samba Team 1992-2004 [2006/03/06 00:22:54, 0] passdb/secrets.c:secrets_init(64) Failed to open /etc/samba/secrets.tdb (...) [2006/03/06 00:22:54, 0] passdb/machine_sid.c:pdb_generate_sam_sid(176) pdb_generate_sam_sid: Failed to store generated machine SID. [2006/03/06 00:22:54, 0] lib/util.c:smb_panic2(1517) PANIC: Could not generate a machine SID [2006/03/06 00:22:54, 0] lib/util.c:smb_panic2(1525) BACKTRACE: 7 stack frames: #0 smbd(smb_panic2+0x8a) [0x7c507c] #1 smbd(smb_panic+0x19) [0x7c52c2] #2 smbd(get_global_sam_sid+0x2bc) [0x77d84c] #3 smbd(init_guest_info+0x65) [0x80b6be] #4 smbd(main+0x2a7) [0x846fb3] #5 /lib/libc.so.6(__libc_start_main+0xdf) [0x2f3d5f] #6 smbd [0x6454f1] Dodam że plik "/etc/samba/secrets.tdb" jest obecny w systemie -rw------- 1 root root 8192 mar 5 21:41 secrets.tdb Plik konfiguracyjny weryfikuje się poprawnie. Przy dodaniu konta do samby tez jakiś dziwny komunikat smbpasswd -a zosia New SMB password: Retype new SMB password: account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0 account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0 Added user zosia. Szukam od kilku godzin i nic nie mogę zanależć. W F3 wszystko działało. Znalazłem grupy na których zgłaszono taki problem ale nigdzie nie był rozwiązania. Bardzo proszę o pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Marzec 5, 2006 Zgłoszenie Share Napisano Marzec 5, 2006 strzelam na ślepo trochę i bardzo możliwe, że już próbowałęś tego ale wyłącz selinux dla samby i pozostałych demonów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
