wookash_x Napisano Lipiec 17, 2004 Zgłoszenie Share Napisano Lipiec 17, 2004 Witam Mam taki problem, wczoraj zainstalowałem gmplayer'a: [root@localhost root]# rpm -Uvh mplayer-common-1.0pre4-3.i386.rpm mplayer-gui-1.0pre4-3.i386.rpm mplayer-skin-default-1.0-2.noarch.rpm lame-libs-3.95.1-1.i386.rpm wszystko poszło ok, żaqadnych błędów i gmplayer działał. Dziś niestety przy próbie uruchomienia tego programu wyskakuje taki oto błąd i mplayer się nie uruchamia : [wookash@localhost wookash]$ gmplayer MPlayer 1.0pre4-RPM-3.2.2 ? 2000-2004 MPlayer Team CPU: Intel Pentium 4/Xeon Willamette 1704 MHz (Family: 8, Stepping: 3) Detected cache-line size is 64 bytes CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection - WARNING - this is not optimal! To get best performance, recompile MPlayer with --disable-runtime-cpudetection. Reading config file /etc/mplayer/mplayer.conf Reading config file /home/wookash/.mplayer/config [cfg] read config file: /home/wookash/.mplayer/gui.conf Reading config file /home/wookash/.mplayer/gui.conf vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display) xscreensaver_disable: Could not find xscreensaver window. Reading /home/wookash/.mplayer/codecs.conf: Can't open '/home/wookash/.mplayer/codecs.conf': Nie ma takiego pliku ani katalogu Reading /etc/mplayer/codecs.conf: 66 audio & 176 video codecs Font /home/wookash/.mplayer/font/font.desc loaded successfully! (233 chars) Linux RTC init error in ioctl (rtc_irqp_set 1024): Brak dostępu Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts. Using usleep() timing Can't open input config file /home/wookash/.mplayer/input.conf: Nie ma takiego pliku ani katalogu Input config file /etc/mplayer/input.conf parsed: 53 binds MPlayer interrupted by signal 11 in module: unknown - MPlayer crashed by bad usage of CPU/FPU/RAM. Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash. - MPlayer crashed. This shouldn't happen. It can be a bug in the MPlayer code _or_ in your drivers _or_ in your gcc version. If you think it's MPlayer's fault, please read DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and won't help unless you provide this information when reporting a possible bug. Czy ktoś z Was spotkał się z czymś takim już, jeśli tak to jak to naprawić? Dodam że wcześniej miałem mplayer'a ale go usunąłem "rpm -e mplayer" Dzięki za pomoc pozdro: wookash p.s. próbowałem też ponownej instalacji ale wtedy robi sie jeszcze ciekawiej, przy próbie odinstalowania: [root@localhost mplayer]# rpm -e mplayer-common-1.0pre4-3.i386.rpm mplayer-gui-1.0pre4-3.i386.rpm mplayer-skin-default-1.0-2.noarch.rpm lame-libs-3.95.1-1.i386.rpm błąd: pakiet mplayer-common-1.0pre4-3.i386.rpm nie jest zainstalowany błąd: pakiet mplayer-gui-1.0pre4-3.i386.rpm nie jest zainstalowany błąd: pakiet mplayer-skin-default-1.0-2.noarch.rpm nie jest zainstalowany błąd: pakiet lame-libs-3.95.1-1.i386.rpm nie jest zainstalowany a gdy chce go zainstalwoać raz jeszcze: [root@localhost mplayer]# rpm -Uvh mplayer-common-1.0pre4-3.i386.rpm mplayer-gui-1.0pre4-3.i386.rpm mplayer-skin-default-1.0-2.noarch.rpm lame-libs-3.95.1-1.i386.rpm ostrzeżenie: mplayer-common-1.0pre4-3.i386.rpm: Sygnatura V3 DSA: NOKEY, key ID 75aa026a Przygotowywanie... ########################################### [100%] pakiet lame-libs-3.95.1-1 jest już zainstalowany pakiet mplayer-common-1.0pre4-3 jest już zainstalowany pakiet mplayer-gui-1.0pre4-3 jest już zainstalowany pakiet mplayer-skin-default-1.0-2 jest już zainstalowany teraz już nic z tego nie rozumiem to jest czy go nie ma ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
McGiwer Napisano Lipiec 17, 2004 Zgłoszenie Share Napisano Lipiec 17, 2004 Dla informacji podam ze ten temat byl juz na forum poruszany, wiec chyba nie szukales To moj opis instalacji Mplayera: http://www.fedora.pl/site/forum/index.php?...p?showtopic=838 Odinstaluj to co zainstalowles i zainstaluj tak jak tam opisalem. Co do problemu z odinstalowywaniem to podales nazwe pakietu costam-wersja.rpm, a pownienes podac costam-wersja Wiec pakiety sa zainstalowane, ale Ty podajesz zla nazwe przy ich usuwaniu Powodzenia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wookash_x Napisano Lipiec 17, 2004 Autor Zgłoszenie Share Napisano Lipiec 17, 2004 dzięki ale neta mam po proxy i jakoś do tej pory nie udało mi się go dobrze skonfigurować tzn działa mi tylko www i ftp w konuerorze i mozilli więc instalacja za pomocą (_yum'a_ → yuma) ORT odpada ale spróbuje jeszcze z tym powalczyć za kilka dni bedzie znów serwer i wtedy nie bedzie problemów z yum'em dzieki za pomoc pozdro: wookash Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Lipiec 30, 2004 Zgłoszenie Share Napisano Lipiec 30, 2004 Linux RTC init error in ioctl (rtc_irqp_set 1024): Brak dostępu Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts. Trochę OT, ale zobacz jeszcze to: http://www.fedora.pl/site/forum/index.php?...findpost&p=4560 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
