Radius - Czy Ktoś Już Instalowal ?
blazejwiecha
mam zamiar zainstalować ten pakiecik z strony
http://www.gnu.org/software/radius/radius.pl.html
jest ale jeden problem , po ./configure przychodzi czas na make i make instal, niestety wyskakuje mi taki błąd:
make[3]: Entering directory `/root/radius-1.3/radscm'
test -z "/usr/local/bin" || mkdir -p -- . "/usr/local/bin"
test -z "/usr/local/lib" || mkdir -p -- . "/usr/local/lib"
test -z "/usr/local/share/radius/1.3/scheme" || mkdir -p -- . "/usr/local/share/radius/1.3/scheme"
make  install-data-hook
make[4]: Entering directory `/root/radius-1.3/radscm'
make[4]: Leaving directory `/root/radius-1.3/radscm'
make[3]: Leaving directory `/root/radius-1.3/radscm'
make[2]: Leaving directory `/root/radius-1.3/radscm'
make[1]: Leaving directory `/root/radius-1.3/radscm'
Making install in radiusd
make[1]: Entering directory `/root/radius-1.3/radiusd'
make  install-am
make[2]: Entering directory `/root/radius-1.3/radiusd'
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I../include -I../include -I../include/radius -I../include/radius   -DSYSCONFDIR=\"/usr/local/etc\" -DRADPID_DIR=\"/var/run\" -DRADLOG_DIR=\"/var/log\" -DRADIUS_DATADIR=\"/usr/local/share/radius/1.3\"   -g -O2 -MT log.o -MD -MP -MF ".deps/log.Tpo" -c -o log.o log.c; \
then mv -f ".deps/log.Tpo" ".deps/log.Po"; else rm -f ".deps/log.Tpo"; exit 1; fi
log.c: In function ârun_log_hookâ:
log.c:190: warning: passing argument 4 of ârewrite_invokeâ discards qualifiers from pointer target type
log.c: In function âchannel_format_prefixâ:
log.c:200: error: invalid lvalue in unary â&â
log.c: In function âchannel_format_suffixâ:
log.c:218: error: invalid lvalue in unary â&â
make[2]: *** [log.o] Error 1
make[2]: Leaving directory `/root/radius-1.3/radiusd'
make[1]: *** [install] Error 2
make[1]: Leaving directory `/root/radius-1.3/radiusd'
make: *** [install-recursive] Error 1
wkleiłem tylko koncówke w której własnie to pisze , no i jak widać radius sie nie instaluje sad.gif. Co jest przyczyną ??? może ktoś z Was miał podobnie ???
