Fc5: Flashplayer
magic
1. Czy dał radę ktoś to zainstalować?
Podczas instalacji (prosty skrypt kopiujacy dwa pliki to wybranego katalogu + '/plugins') wywala info ze potrzebuje czcionki (nie wiem, moze to jest powod ze nie dziala):
[root@m install_flash_player_7_linux]# ./flashplayer-install*
Copyright(C) 2002-2003 Macromedia, Inc.  All rights reserved.
Macromedia Flash Player 7 for Linux
Macromedia Flash Player 7 will be installed on this machine.
You are running the Macromedia Flash Player installer as the "root" user.
Macromedia Flash Player 7 will be installed system-wide.
Support is available at http://www.macromedia.com/support/flashplayer/
To install Macromedia Flash Player 7 now, press ENTER.
To cancel the installation at any time, press Control-C.
NOTE: Macromedia Flash Player requires two font packages
     to be installed, ttfonts and urw-fonts.
Press ENTER to continue...
NOTE: Please exit any browsers you may have running.
Please enter the installation path of the Mozilla, Netscape,
or Opera browser (i.e., /usr/lib/mozilla): /usr/lib/firefox-1.5.0.1
WARNING: An older version of the Macromedia Flash Player has been detected in
        /usr/lib/firefox-1.5.0.1/plugins.
        The installer will overwrite this existing binary.
----------- Install Action Summary -----------
Macromedia Flash Player 7 will be installed in the following directory:
Browser installation directory = /usr/lib/firefox-1.5.0.1
Proceed with the installation? (y/n/q): y
Installation complete.
Perform another installation? (y/n): n
Please log out of this session and log in for the changes to take effect.
The Macromedia Flash Player installation is complete.
Plugin jest, no bo:
[root@m install_flash_player_7_linux]# ls /usr/lib/firefox-1.5.0.1/plugins -all
total 2180
drwxr-xr-x  2 root root    4096 Mar 22 18:42 .
drwxr-xr-x 13 root root    4096 Mar 22 18:44 ..
-rwxr-xr-x  1 root root     856 Mar 22 19:07 flashplayer.xpt
-rwxr-xr-x  1 root root 2154768 Mar 22 19:07 libflashplayer.so
-rwxr-xr-x  1 root root   18472 Mar 13 16:29 libnullplugin.so
-rwxr-xr-x  1 root root   10756 Mar 13 16:29 libunixprintplugin.so
Jeszcze wrzucilem go do mojego /home - czyli:
[root@m install_flash_player_7_linux]# ls /home/m/.mozilla/plugins -all
total 2140
drwxr-xr-x 2 m m    4096 Mar 22 18:22 .
drwx------ 4 m m    4096 Mar 21 21:46 ..
-rwxr-xr-x 1 m m     856 Mar 22 18:28 flashplayer.xpt
-rwxr-xr-x 1 m m 2154768 Mar 22 18:28 libflashplayer.so
A pod FC4 nie bylo problemow...Jeszcze do Javy nie doszedlem a tu na Flashu stanalem :-)
Log out, log in - i w cholere - nie działa. Ma ktoś podobny problem? (PS Probowalem tez z mozilla, itp - to samo.)
Oczywiście że tak
Fedora/1.5.0.1-9 Firefox
normalnie wszedłem na www.nvidia.com i zainstalowałem wtyczkę z firefoxa
po chwili zobaczyłem piekny zielony flash reklamowy wink.gif nvidii .
Działa
Pozdro
PS.
ls -la .mozilla/plugins
856 maj 20 2004 flashplayer.xpt
2096844 maj 20 2004 libflashplayer.so
Jesli chodzi o flash-playera to nawet nie trzeba sciagac paczki. Wystarczy wejsc na jkas strone na ktorej jest animacja flash i automatycznie wyskoczy instalacja flasha. Tylko ze nie dziala bo przeszkadza mu w tym SELinux. A wiec robimy tak:
- #/usr/bin/system-config-securitylevel
- Wchodzimy w: SELinux > Zmien Polityke SELinuxa > Zgodnosc
- Zaznaczamy druga opcje od gory czyli: "Pozwol na korzystanie ze wspoldzielonych biliotek z Text Relocation"
Po tej modyfikacji flash-plugin bedzie dzialal nawet po zainstalowaniu go z poziomu Firefoxa.
A co w przypadku x86_64. Flash player zadziała? Narazie ściągnąłem polecaną paczkę i flashe nie działają. Ręcznie kopiowałem pliki xpt i so do plugins i też nic. W ogóle jest wersja pod 64?
FC4 miałem i386 i nie było problemu.
Ok znalazłem odpowiedź:
Where is Flash for PowerPC or x86-64 Linux?
  It does not exist probably because Macromedia management feel there is no demand.
  Contact Macromedia and express your opinion if you truly care about this.
Ale porażka! Zawiodłem się.
generalnie jak macie problemy to radzę przełączyć selinux w tryb permissive i popatrzeć w logi co by się dzialo gdyby wink.gif
w pliku /etc/selinux/config
zmienić na
SELINUX=permissive
reboot
jesli problem zniknie poszukać w logach jaka polityka selinux blokuje i co , ustawić odpowienie permissions i włączyć selinux w tryb enforcing
reboot
Należy uważać na selinux robiąc np. kopię.
star -xattr -H=exustar -c -f kopia.star ./co
Pozdro
Wielkie dzieki smile.gif Nie wiem komu, bo pewno wszystkie metody dobre, wykorzystałem ta z SELnuxem - działa smile.gif
PPS Swoja drogą dziwne ze snake'owi zadziałało od razu - chyba ze mieszałeś w SELinuxie od razu po instalce smile.gif
U mnie zadziałało ponieważ miałem selinux w trybie permissive .
Zawsze tak robię na początku żeby uniknąć niepotrzebnych frustracji wink.gif
Potem można poustawiać i włączyć jeśli rzeczywiście jest Wam potrzebny .
Na stacji roboczej selinux (generalnie zawsze ma sens) nie jest tak bardzo potrzebny jak na serwerze więc mozna go przełaczyć w tryb permissive (nie blokuje lecz loguje biggrin.gif ).
Pozdro
  • 8 months later...
Mam podobny probem do zalozyciela tematu - probuje zainstalowac flasha ale sie nie udaje. Sciagnalem go z adobe.com, wypakowalem, wrzucilem tego jednego plugina do firefox-1.5.0.7/plugins, zainstalowalem i niby instalacja sie zakonczyla ale dalej nie dzialalo pod Firefoxem. Niestety odpowiedzi, które sie tutaj pojawiaja niewiele mi mowia, poniewaz jestem calkowicie nowy w tym systemie i nawet nie wiem jak sie tutaj instaluje cokolowiek^^ Bardzo prosze o wyrozumialosc i oczywiscie - o pomoc.
PS. nie wiem, czy to cos zmienia, ale mam Fedore Core 6.
robiy coś takiego.
logujemy sie na roota
su -
hasło:
wklejamy to po przejsciu na roota:
gedit /etc/yum.repos.d/macromedia.repo
w nowym oknie wpisujemy cos takiego:
[macromedia]
name=Macromedia for i386 Linux
baseurl=http://macromedia.rediris.es/rpm/
enabled=1
gpgcheck=1
gpgkey=http://macromedia.mplug.org/FEDORA-GPG-KEY
zapisujemy i wklepujemy polecenie:
yum -y install flash-plugin
Gość
