MitS Napisano Marzec 27, 2006 Zgłoszenie Share Napisano Marzec 27, 2006 Witam! Mam drobniusi problem, a mianowicie taki: [root@ozyrys ekg2-20050418]# make make all-recursive make[1]: Entering directory `/home/mits/Desktop/ekg2-20050418' Making all in libltdl make[2]: Entering directory `/home/mits/Desktop/ekg2-20050418/libltdl' cd . && /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run aclocal-1.7 cd . && \ /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run automake-1.7 --foreign Makefile touch touchfile cd . && /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run autoconf make all-am make[3]: Entering directory `/home/mits/Desktop/ekg2-20050418/libltdl' cd . && /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run aclocal-1.7 cd . && \ /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run automake-1.7 --foreign Makefile touch touchfile cd . && /bin/sh /home/mits/Desktop/ekg2-20050418/libltdl/missing --run autoconf /bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -g -O2 -c -o ltdl.lo `test -f 'ltdl.c' || echo './'`ltdl.c mkdir .libs gcc -DHAVE_CONFIG_H -I. -I. -I. -g -O2 -c ltdl.c -fPIC -DPIC -o .libs/ltdl.o gcc -DHAVE_CONFIG_H -I. -I. -I. -g -O2 -c ltdl.c -o ltdl.o >/dev/null 2>&1 /bin/sh ./libtool --mode=link gcc -g -O2 -o libltdlc.la ltdl.lo -ldl ar cru .libs/libltdlc.a .libs/ltdl.o ranlib .libs/libltdlc.a creating libltdlc.la (cd .libs && rm -f libltdlc.la && ln -s ../libltdlc.la libltdlc.la) make[3]: Leaving directory `/home/mits/Desktop/ekg2-20050418/libltdl' make[2]: Leaving directory `/home/mits/Desktop/ekg2-20050418/libltdl' Making all in plugins make[2]: Entering directory `/home/mits/Desktop/ekg2-20050418/plugins' Making all in logs make[3]: Entering directory `/home/mits/Desktop/ekg2-20050418/plugins/logs' if /bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../libltdl -g -O2 -Wall -MT main.lo -MD -MP -MF ".deps/main.Tpo" \ -c -o main.lo `test -f 'main.c' || echo './'`main.c; \ then mv -f ".deps/main.Tpo" ".deps/main.Plo"; \ else rm -f ".deps/main.Tpo"; exit 1; \ fi mkdir .libs gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../libltdl -g -O2 -Wall -MT main.lo -MD -MP -MF .deps/main.Tpo -c main.c -fPIC -DPIC -o .libs/main.o In file included from main.c:46: ../../ekg/userlist.h:119: error: array type has incomplete element type main.c: In function 'logs_handler_newwin': main.c:326: warning: unused variable 'result' make[3]: *** [main.lo] Błąd 1 make[3]: Leaving directory `/home/mits/Desktop/ekg2-20050418/plugins/logs' make[2]: *** [all-recursive] Błąd 1 make[2]: Leaving directory `/home/mits/Desktop/ekg2-20050418/plugins' make[1]: *** [all-recursive] Błąd 1 make[1]: Leaving directory `/home/mits/Desktop/ekg2-20050418' make: *** [all] Błąd 2 [root@ozyrys ekg2-20050418]# Czemu nie chce się zrobić make ??? Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Marzec 27, 2006 Zgłoszenie Share Napisano Marzec 27, 2006 Właściwie to błąd wygląda jakby był spowodowany jakimś błędem w kodzie, a nie systemie... nie ma jakieś nowszej wersji ekg? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MitS Napisano Marzec 27, 2006 Autor Zgłoszenie Share Napisano Marzec 27, 2006 zaraz poszukam i sie okaże Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
