Nvidia + Fc5 = Brak Akceleracji
scooter
Witam
Stery do karty GeForce 6600 GT zainstalowalem tak:
yum install kmod-nvidia
i niby zainstalowane. Przy uruchamianiu kompa pokazuje sie na chwile logo nvidia. Mam juz rozdzielczosc i odswiezanie tak jak powinno byc. Ale czulem ze cos jest nie tak. Wygaszacza opengl nie moge wlaczyc. Chcialem sprawdzic co jest i oto wynik:
[marcin@localhost ~]$ glxgears
Xlib:  extension "GLX" missing on display ":0.0".
Error: couldn't get an RGB, Double-buffered visual
[marcin@localhost ~]$ glxinfo
name of display: :0.0
Error: couldn't find RGB GLX visual
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
0x22 24 dc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
Moj plik xorg.conf wyglada tak:
# Xorg configuration created by system-config-display
Section "ServerLayout"
Identifier     "single head configuration"
Screen      0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, a font server independent of the X server is
# used to render fonts.
ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
ModulePath   "/usr/lib/xorg/modules"
FontPath     "unix/:7100"
EndSection
Section "Module"
Load  "dbe"
Load  "extmod"
Load  "fbdevhw"
Load  "record"
Load  "freetype"
Load  "type1"
Load  "glx"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#	Option	"Xleds"  "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#	Option	"XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#	Option	"XkbModel"	"pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#	Option	"XkbModel"	"microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#	Option	"XkbLayout"	"de"
# or:
#	Option	"XkbVariant"	"nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#	Option	"XkbOptions"	"ctrl:swapcaps"
# Or if you just want both to be control, use:
#	Option	"XkbOptions"	"ctrl:nocaps"
Identifier  "Keyboard0"
Driver      "kbd"
Option     "XkbModel" "pc105"
Option     "XkbLayout" "pl"
EndSection
Identifier  "Mouse0"
Driver      "mouse"
Option     "Protocol" "IMPS/2"
Option     "Device" "/dev/input/mice"
Option     "ZAxisMapping" "4 5"
Option     "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
### Comment all HorizSync and VertSync values to use DDC:
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "Samsung SyncMaster 957p"
DisplaySize  360	270
HorizSync    30.0 - 96.0
VertRefresh  50.0 - 160.0
Option     "dpms"
EndSection
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
VendorName  "Videocard vendor"
BoardName   "nVidia Corporation NV43 [GeForce 6600/GeForce 6600 GT]"
EndSection
Section "Screen"
Identifier "Screen0"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     24
SubSection "Display"
 Viewport   0 0
 Depth     16
 Modes    "800x600" "640x480"
EndSubSection
 Viewport   0 0
 Depth     24
 Modes    "1280x1024"
EndSubSection
EndSection
Section "DRI"
Group        0
Mode         0666
EndSection
Co mam zrobic zeby miec akceleracje? Moze trzeba cos zmienic w ustawieniach w xorg.conf? Jak u mnie jest zle to moze ktos wklei swoj config.
Ciekawe jaki masz kernel .. sprawdź poleceniem uname -r . Nie znam się na Nvidia, bo mam ATI, ale jak masz kernel 2.6.15 to nei podziałasz wiele (tak mi się wydaje), musisz mieć 2.6.16, jeżeli nie masz uaktualnij (yum update).
Spróbuj w Section "Device" dopisać następujące linijki:
        Option "RenderAccel"                       "true"
       Option "NoDDC"                             "false"
       Option "Coolbits"                          "true"
       Option "UseEdidDPI"                        "true"
       Option "UseEdidFreqs"                      "true"
       Option "NvAGP"                             "1"
A moze jest to wina SELinux, jak u mnie bylo.
Trzeba popatrzec czy w logach (audit lub messages) nie pisze cos o zablokowaniu dostepu do plikow ze sterownikow nvidia.
Nastepnie zrobic cos w stylu:
chcon -t texrel_shlib_t /usr/lib/xorg/modules/drivers/nvidia_drv.so
chcon -t texrel_shlib_t /usr/lib/xorg/modules/extensions/nvidia/libglx.so*
chcon -t texrel_shlib_t /usr/lib/xorg/modules/extensions/libglx.so
Tez mialem problem z AcrobatReaderem 7.0 : nie chcial sie otworzyc przez to. Teraz sie otwiera ale pisze ze plagiow nie mogl uruchomic, a pod konsola nic nie pisze sad.gif
ecik__
Wpisalem ale nie pomoglo. Dzieki za pomoc.
Soruk
W logach widze ze tez jest o flash playerze i dlatego nie dzialal mi w firefoksie. Teraz znam przyczyne. Dziala juz nawet flash. smile.gif
A co dopisac do xorg.conf zebym mial tv-out?
Mógłbyś to zgłosić w bugzilli (komponent selinux-policy - najlepiej wraz ze zgłoszeniami AVC)? Ja ostanio nie mam za bardzo czasu :/ Po przejściu na modularne X-y pozmieniały się ściezki, ale nie zaktualizowali zasad bezpieczeństwa.
Załóż sobie konto → https://bugzilla.redhat.com/bugzilla/ Potem "New" → Dystrybucja Fedora Core → FC5 → komponent selinux-policy
Możesz kleić tam odpowiednie zgłoszenia AVC (są w /var/log/messages). Najlepiej podać listę plików, które mają mieć nadany kontekst texrel_shlib_t:
- wylistuj biblioteki z paczki:
rpm -ql xorg-x11-drv-nvidia | grep lib
- sprawdź które pliki posiadają relokacje w segmencie programu:
eu-readelf -d /sciezka/do/biblioteki/plik | grep TEXTREL
Jeśli coś wypisze, to jest to kandydat do zgłoszenia.
- sprawdź kontekst pliku:
ls -Z /sciezka/do/biblioteki/plik
Jeśli typ będzie inny niż texrel_shlib_t, a plik ma relokacje w segmencie programu, to należy o tym napisać w zgłoszeniu.
W przypadku sterowników ATI też wypadałoby coś takiego zrobić (ktoś chętny?).
Ja robilem tak :
1. Instalacje jadra 2.6.16-1.2080_FC5 ( ja osobisicie wybralem 2.6.16-1.2080_FC5smp - o ile wiem uzywa sie go to procesorow P4HT)
2. Wgralem sobie "yumex"a wpisalem w szukaj "nvidia" i zainstalowalem wersje pasujaca do mojego kernela.
Potem restart i wyrzuca blad startu X. Uruchomilem ze chce zobaczyc bledy jako root. Potem wpisalem haslo root i kazalem uaktualnic ustawienia. Potem mialem ustawienia podstawowe ktore bez proeblemu zmienilem na wlasciewe. Potem restart i jest ok. America's Army dziala ale co dziwne gdy wpisze "glxgears" w konsoli to straszeni tnie ... W kazdym razie sprobuj tak.
P.S.
Jesli masz procesor uzywajacy "smp" to wgraj najpier normalne jadra i odpal na nim grafike a nastepnie jadra smp i dopiero wlasciwy do niego "kmod"
Ja robilem tak :
P.S.
Dla osob ktore nie korzystaja z yumex a maja kernel smp:
yum install kmod-nvidia-smp
WITAM
Podpinam sie pod temat TEZ BRAKUJE MI AKCELERACJU sad.gif(((((
karta-GF FX 5700
kernel-smp 1.0.8756-1.2.6.16_1.2080_FC5
kmod-nvidia-smp 1.0.8756-1.2.6.16_1.2080_FC5
Niestety ,moduly jadra laduja sie przy starcie systemu wszystko prawidlowo Z WYJATKIEM WSPARCIA 3D sad.gif(((
Testowalem rozwiazania proponowane na forum bez efektu sad.gif(
Testowalem z jadrem bez wsparcia dla wieloprocesorowosci sad.gif(
A ponadto mam jakis problem z czcionkami BRAK POLSKICH OGONKOW sad.gif(
PS-Chyba okazuje sie ,ze FC-5 jest jakos niedopracowana w porownaniu z FC-4
Szkoda bo chyba chlopcy od SuSE 10.0 bardziej sie przylozyli do tematu
pozdrawiam Robert.
  • 3 months later...
A co mam zrobić, jeżeli po wpisaniu w konsole (jako root)
Po co jako root?
glxgears lub glxinfo otrzymuję odpowiedź command not found ??
Doinstalować odpowiedni pakiet:
[root@X ~]# yum provides glxgears
Loading "installonlyn" plugin
Searching Packages:
Setting up repositories
livna        [1/5]
updates                                                              [2/5]
core        [3/5]
updates-testing                                                      [4/5]
extras                                                               [5/5]
Importing additional filelist information
glx-utils.i386                           6.4.2-6.FC5.3          updates
Matched from:
/usr/bin/glxgears
glx-utils.i386                           6.4.2-6                core
Matched from:
/usr/bin/glxgears
glx-utils.i386                           6.4.2-6.FC5.3          installed
Matched from:
/usr/bin/glxgears
[root@X ~]#
http://wiki.fedora.pl/Administracja/YumProvides
