Crystal Pod Kde 3.5
TrAvIkK
Niestety tam szukałem, nie znlaazłem :/
(./configure oczywiście wychodzi dobrze)
(to wywala przy make)
make  all-recursive
make[1]: Entering directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0'
Making all in pics
make[2]: Entering directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/pics'
make[2]: Nie nic do roboty w `all'.
make[2]: Leaving directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/pics'
Making all in client
make[2]: Entering directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client'
Making all in config
make[3]: Entering directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client/config'
make[3]: Nie nic do roboty w `all'.
make[3]: Leaving directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client/config'
make[3]: Entering directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client'
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT crystalclient.lo -MD -MP -MF ".deps/crystalclient.Tpo" \
 -c -o crystalclient.lo `test -f 'crystalclient.cc' || echo './'`crystalclient.cc; \
then mv -f ".deps/crystalclient.Tpo" ".deps/crystalclient.Plo"; \
else rm -f ".deps/crystalclient.Tpo"; exit 1; \
fi
In file included from crystalclient.cc:36:
crystalclient.h:31:25: error: kdecoration.h: No such file or directory
crystalclient.h:32:32: error: kdecorationfactory.h: No such file or directory
crystalclient.cc:134:5: warning: "KDE_IS_VERSION" is not defined
crystalclient.cc:134:19: error: missing binary operator before token "("
crystalclient.cc:925:5: warning: "KDE_IS_VERSION" is not defined
crystalclient.cc:925:19: error: missing binary operator before token "("
/usr/lib/qt-3.3/include/qtooltip.h:86: warning: 'class QToolTip' has virtual functions but non-virtual destructor
crystalclient.h:101: error: expected class-name before '{' token
crystalclient.h:105: error: ISO C++ forbids declaration of 'KDecoration' with no type
crystalclient.h:105: error: 'KDecoration' declared as a 'virtual' field
crystalclient.h:105: error: expected ';' before '*' token
crystalclient.h:107: error: 'Ability' has not been declared
crystalclient.h:145: error: expected class-name before '{' token
crystalclient.h:148: error: expected `)' before '*' token
crystalclient.h:163: error: 'Position' does not name a type
crystalclient.cc:52: error: expected constructor, destructor, or type conversion before '*' token
crystalclient.cc:62: warning: 'class CCrystalTooltip' has virtual functions but non-virtual destructor
crystalclient.cc: In member function 'virtual void CCrystalTooltip::maybeTip(const QPoint&)':
crystalclient.cc:71: error: 'class CrystalClient' has no member named 'caption'
crystalclient.cc: At global scope:
crystalclient.cc:105: error: expected constructor, destructor, or type conversion before '*' token
crystalclient.cc:130: error: 'bool CrystalFactory::supports' is not a static member of 'class CrystalFactory'
crystalclient.cc:130: error: 'Ability' was not declared in this scope
crystalclient.cc:131: error: expected ',' or ';' before '{' token
make[3]: *** [crystalclient.lo] Błąd 1
make[3]: Leaving directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client'
make[2]: *** [all-recursive] Błąd 1
make[2]: Leaving directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0/client'
make[1]: *** [all-recursive] Błąd 1
make[1]: Leaving directory `/home/TrAvIkK/Desktop/13969-crystal-1.0.0/crystal-1.0.0'
make: *** [all] Błąd 2
mm dzięki, ale teraz mam coś takiego:
make  all-recursive
make[1]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0'
Making all in pics
make[2]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0/pics'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common  -MT embedtool.o -MD -MP -MF ".deps/embedtool.Tpo" \
 -c -o embedtool.o `test -f 'embedtool.cpp' || echo './'`embedtool.cpp; \
then mv -f ".deps/embedtool.Tpo" ".deps/embedtool.Po"; \
else rm -f ".deps/embedtool.Tpo"; exit 1; \
fi
/bin/sh ../libtool --silent --mode=link --tag=CXX g++  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common    -o embedtool -L/usr/lib/qt-3.3/lib -L/usr/lib    embedtool.o -lqt-mt  -lz -lpng -lz -lm -lXext -lX11  -lSM -lICE -lpthread
Generating Button Themes...
./embedtool vista/*.png aqua/*.png default/*.png handpainted/*.png knifty/*.png svg/*.png > tiles.h
vista/vista_above_hovered.png
vista/vista_above.png
vista/vista_above_pressed.png
vista/vista_below_hovered.png
vista/vista_below.png
vista/vista_below_pressed.png
vista/vista_close_hovered.png
vista/vista_close.png
vista/vista_close_pressed.png
vista/vista_help_hovered.png
vista/vista_help.png
vista/vista_help_pressed.png
vista/vista_max_hovered.png
vista/vista_max.png
vista/vista_max_pressed.png
vista/vista_min_hovered.png
vista/vista_min.png
vista/vista_min_pressed.png
vista/vista_restore_hovered.png
vista/vista_restore.png
vista/vista_restore_pressed.png
vista/vista_shade_hovered.png
vista/vista_shade.png
vista/vista_shade_pressed.png
vista/vista_sticky_hovered.png
vista/vista_sticky.png
vista/vista_sticky_pressed.png
vista/vista_un_above_hovered.png
vista/vista_un_above.png
vista/vista_un_above_pressed.png
vista/vista_un_below_hovered.png
vista/vista_un_below.png
vista/vista_un_below_pressed.png
vista/vista_un_shade_hovered.png
vista/vista_un_shade.png
vista/vista_un_shade_pressed.png
vista/vista_un_sticky_hovered.png
vista/vista_un_sticky.png
vista/vista_un_sticky_pressed.png
aqua/aqua_above.png
aqua/aqua_below.png
aqua/aqua_close.png
aqua/aqua_default.png
aqua/aqua_help.png
aqua/aqua_max.png
aqua/aqua_min.png
aqua/aqua_shade.png
aqua/aqua_sticky.png
aqua/aqua_un_sticky.png
default/crystal_above.png
default/crystal_below.png
default/crystal_close.png
default/crystal_help.png
default/crystal_max.png
default/crystal_min.png
default/crystal_restore.png
default/crystal_shade.png
default/crystal_sticky.png
default/crystal_unabove.png
default/crystal_unbelow.png
default/crystal_un_sticky.png
handpainted/handpainted_above.png
handpainted/handpainted_below.png
handpainted/handpainted_close.png
handpainted/handpainted_help.png
handpainted/handpainted_max.png
handpainted/handpainted_min.png
handpainted/handpainted_restore.png
handpainted/handpainted_shade.png
handpainted/handpainted_sticky.png
handpainted/handpainted_unabove.png
handpainted/handpainted_unbelow.png
handpainted/handpainted_un_shade.png
handpainted/handpainted_un_sticky.png
knifty/knifty_above.png
knifty/knifty_below.png
knifty/knifty_close.png
knifty/knifty_help.png
knifty/knifty_max.png
knifty/knifty_min.png
knifty/knifty_restore.png
knifty/knifty_shade.png
knifty/knifty_sticky.png
knifty/knifty_unabove.png
knifty/knifty_unbelow.png
knifty/knifty_un_sticky.png
svg/svg_above.png
svg/svg_below.png
svg/svg_close.png
svg/svg_help.png
svg/svg_max.png
svg/svg_min.png
svg/svg_restore.png
svg/svg_shade.png
svg/svg_sticky.png
svg/svg_unshade.png
svg/svg_unsticky.png
cp tiles.h ../client/tiles.h
make[2]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0/pics'
make[2]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client'
make[3]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client/config'
rm -rf configdialog.h;
/usr/lib/qt-3.3/bin/uic -L /usr/lib/kde3/plugins/designer -nounload ./configdialog.ui | /usr/bin/perl -pi -e "s,public QWizard,public KWizard,g; s,#include <qwizard.h>,#include <kwizard.h>,g" >> configdialog.h;
rm -rf infodialog.h;
/usr/lib/qt-3.3/bin/uic -L /usr/lib/kde3/plugins/designer -nounload ./infodialog.ui | /usr/bin/perl -pi -e "s,public QWizard,public KWizard,g; s,#include <qwizard.h>,#include <kwizard.h>,g" >> infodialog.h;
/usr/lib/qt-3.3/bin/moc ./crystalconfig.h -o crystalconfig.moc
if /bin/sh ../../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT crystalconfig.lo -MD -MP -MF ".deps/crystalconfig.Tpo" \
 -c -o crystalconfig.lo `test -f 'crystalconfig.cc' || echo './'`crystalconfig.cc; \
then mv -f ".deps/crystalconfig.Tpo" ".deps/crystalconfig.Plo"; \
else rm -f ".deps/crystalconfig.Tpo"; exit 1; \
fi
/usr/lib/qt-3.3/include/qnetworkprotocol.h:58: warning: 'class QNetworkProtocolFactoryBase' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/qfiledialog.h:78: warning: 'class QFilePreview' has virtual functions but non-virtual destructor
/usr/include/kde/keditlistbox.h:60: warning: 'class KEditListBox::CustomEditor' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:69: warning: 'struct QUBuffer' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:77: warning: 'struct QUType' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:104: warning: 'struct QUType_Null' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:287: warning: 'struct QUType_enum' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:307: warning: 'struct QUType_ptr' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:326: warning: 'struct QUType_iface' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:345: warning: 'struct QUType_idisp' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:364: warning: 'struct QUType_bool' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:383: warning: 'struct QUType_int' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:403: warning: 'struct QUType_double' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:423: warning: 'struct QUType_charstar' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucom_p.h:444: warning: 'struct QUType_QString' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucomextra_p.h:65: warning: 'struct QUType_QVariant' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/include/private/qucomextra_p.h:87: warning: 'struct QUType_varptr' has virtual functions but non-virtual destructor
/usr/lib/qt-3.3/bin/moc configdialog.h -o configdialog.moc
rm -f configdialog.cc
echo '#include <kdialog.h>' > configdialog.cc
echo '#include <klocale.h>' >> configdialog.cc
/usr/lib/qt-3.3/bin/uic -L /usr/lib/kde3/plugins/designer -nounload -tr tr2i18n -i configdialog.h ./configdialog.ui > configdialog.cc.temp; ret=$?; \
/usr/bin/perl -pe "s,tr2i18n( \"\" ),QString::null,g" configdialog.cc.temp | /usr/bin/perl -pe "s,tr2i18n( \"\"\, \"\" ),QString::null,g" | /usr/bin/perl -pe "s,image([0-9][0-9]*)_data,img\$1_configdialog,g" | /usr/bin/perl -pe "s,: QWizard\(,: KWizard(,g" >> configdialog.cc;\
rm -f configdialog.cc.temp;\
if test "$ret" = 0; then echo '#include "configdialog.moc"' >> configdialog.cc; else rm -f configdialog.cc; exit $ret; fi
if /bin/sh ../../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT configdialog.lo -MD -MP -MF ".deps/configdialog.Tpo" \
 -c -o configdialog.lo `test -f 'configdialog.cc' || echo './'`configdialog.cc; \
then mv -f ".deps/configdialog.Tpo" ".deps/configdialog.Plo"; \
else rm -f ".deps/configdialog.Tpo"; exit 1; \
fi
/usr/lib/qt-3.3/bin/moc infodialog.h -o infodialog.moc
rm -f infodialog.cc
echo '#include <kdialog.h>' > infodialog.cc
echo '#include <klocale.h>' >> infodialog.cc
/usr/lib/qt-3.3/bin/uic -L /usr/lib/kde3/plugins/designer -nounload -tr tr2i18n -i infodialog.h ./infodialog.ui > infodialog.cc.temp; ret=$?; \
/usr/bin/perl -pe "s,tr2i18n( \"\" ),QString::null,g" infodialog.cc.temp | /usr/bin/perl -pe "s,tr2i18n( \"\"\, \"\" ),QString::null,g" | /usr/bin/perl -pe "s,image([0-9][0-9]*)_data,img\$1_infodialog,g" | /usr/bin/perl -pe "s,: QWizard\(,: KWizard(,g" >> infodialog.cc;\
rm -f infodialog.cc.temp;\
if test "$ret" = 0; then echo '#include "infodialog.moc"' >> infodialog.cc; else rm -f infodialog.cc; exit $ret; fi
if /bin/sh ../../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.   -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT infodialog.lo -MD -MP -MF ".deps/infodialog.Tpo" \
 -c -o infodialog.lo `test -f 'infodialog.cc' || echo './'`infodialog.cc; \
then mv -f ".deps/infodialog.Tpo" ".deps/infodialog.Plo"; \
else rm -f ".deps/infodialog.Tpo"; exit 1; \
fi
/bin/sh ../../libtool --silent --mode=link --tag=CXX g++  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN   -o kwin_crystal_config.la -rpath /usr/lib/kde3 -module -L/usr/lib/qt-3.3/lib -L/usr/lib    -avoid-version -module -no-undefined -Wl,--no-undefined -Wl,--allow-shlib-undefined -R /usr/lib -R /usr/lib -R /usr/lib/qt-3.3/lib -R /usr/lib  -lkio crystalconfig.lo configdialog.lo infodialog.lo -lkdeui
make[3]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client/config'
make[3]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client'
/usr/lib/qt-3.3/bin/moc ./crystalclient.h -o crystalclient.moc
fi
/usr/include/kde/kdecoration.h:176: warning: 'class KDecorationProvides' has virtual functions but non-virtual destructor
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT myrootpixmap.lo -MD -MP -MF ".deps/myrootpixmap.Tpo" \
 -c -o myrootpixmap.lo `test -f 'myrootpixmap.cc' || echo './'`myrootpixmap.cc; \
then mv -f ".deps/myrootpixmap.Tpo" ".deps/myrootpixmap.Plo"; \
else rm -f ".deps/myrootpixmap.Tpo"; exit 1; \
fi
/usr/lib/qt-3.3/bin/moc ./crystalbutton.h -o crystalbutton.moc
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT crystalbutton.lo -MD -MP -MF ".deps/crystalbutton.Tpo" \
 -c -o crystalbutton.lo `test -f 'crystalbutton.cpp' || echo './'`crystalbutton.cpp; \
then mv -f ".deps/crystalbutton.Tpo" ".deps/crystalbutton.Plo"; \
else rm -f ".deps/crystalbutton.Tpo"; exit 1; \
fi
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT imageholder.lo -MD -MP -MF ".deps/imageholder.Tpo" \
 -c -o imageholder.lo `test -f 'imageholder.cpp' || echo './'`imageholder.cpp; \
then mv -f ".deps/imageholder.Tpo" ".deps/imageholder.Plo"; \
else rm -f ".deps/imageholder.Tpo"; exit 1; \
fi
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT buttonimage.lo -MD -MP -MF ".deps/buttonimage.Tpo" \
 -c -o buttonimage.lo `test -f 'buttonimage.cpp' || echo './'`buttonimage.cpp; \
then mv -f ".deps/buttonimage.Tpo" ".deps/buttonimage.Plo"; \
else rm -f ".deps/buttonimage.Tpo"; exit 1; \
fi
/usr/lib/qt-3.3/bin/moc ./myrootpixmap.h -o myrootpixmap.moc.cc
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT myrootpixmap.moc.lo -MD -MP -MF ".deps/myrootpixmap.moc.Tpo" \
 -c -o myrootpixmap.moc.lo `test -f 'myrootpixmap.moc.cc' || echo './'`myrootpixmap.moc.cc; \
then mv -f ".deps/myrootpixmap.moc.Tpo" ".deps/myrootpixmap.moc.Plo"; \
else rm -f ".deps/myrootpixmap.moc.Tpo"; exit 1; \
fi
/usr/lib/qt-3.3/bin/moc ./imageholder.h -o imageholder.moc.cc
if /bin/sh ../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -I/usr/include/kde/kwin  -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN -MT imageholder.moc.lo -MD -MP -MF ".deps/imageholder.moc.Tpo" \
 -c -o imageholder.moc.lo `test -f 'imageholder.moc.cc' || echo './'`imageholder.moc.cc; \
then mv -f ".deps/imageholder.moc.Tpo" ".deps/imageholder.moc.Plo"; \
else rm -f ".deps/imageholder.moc.Tpo"; exit 1; \
fi
/bin/sh ../libtool --silent --mode=link --tag=CXX g++  -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -DQT_PLUGIN   -o kwin3_crystal.la -rpath /usr/lib/kde3 -module -L/usr/lib/qt-3.3/lib -L/usr/lib    -avoid-version -module -no-undefined -Wl,--no-undefined -Wl,--allow-shlib-undefined -R /usr/lib -R /usr/lib -R /usr/lib/qt-3.3/lib -R /usr/lib  -lkdeui crystalclient.lo myrootpixmap.lo crystalbutton.lo imageholder.lo buttonimage.lo myrootpixmap.moc.lo imageholder.moc.lo  /usr/lib/libkdecorations.la
make[3]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client'
make[2]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0/client'
make[2]: Entering directory `/home/TrAvIkK/Desktop/crystal-1.0.0'
make[2]: Nie nic do roboty w `all-am'.
make[2]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0'
make[1]: Leaving directory `/home/TrAvIkK/Desktop/crystal-1.0.0'
Skoro temat o kompilacji to...
Teraz mam taki problem, przy kompilowaniu KCometen3
[TrAvIkK@konrad kcometen3-1.0]$ make
make  all-recursive
make[1]: Entering directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0'
Making all in pixmaps
make[2]: Entering directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/pixmaps'
make[2]: Leaving directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/pixmaps'
Making all in po
make[2]: Entering directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/po'
make[2]: Leaving directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/po'
Making all in src
make[2]: Entering directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/src'
source='kcometen3.cpp' object='kcometen3.o' libtool=no \
depfile='.deps/kcometen3.Po' tmpdepfile='.deps/kcometen3.TPo' \
depmode=gcc3 /bin/sh ../admin/depcomp \
g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I.  -UQT_NO_ASCII_CAST -DQT_THREAD_SUPPORT  -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -Wall -W -Wpointer-arith -Wwrite-strings -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common  -c -o kcometen3.o `test -f 'kcometen3.cpp' || echo './'`kcometen3.cpp
In file included from kglcometen3.h:24,
                from kcometen3.h:27,
                from kcometen3.cpp:33:
/usr/lib/qt-3.3/include/qgl.h:80:21: error: GL/glu.h: Nie ma takiego pliku ani katalogu
/usr/include/kde/keditlistbox.h:60: warning: ‘class KEditListBox::CustomEditor’ has virtual functions but non-virtual destructor
make[2]: *** [kcometen3.o] Błąd 1
make[2]: Leaving directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0/src'
make[1]: Leaving directory `/home/TrAvIkK/Pobieralnia/kcometen3-1.0'
