Format Mp4 W Mplayer
sq6elc
Witam
Proszę o pomoc, jaki kodek będzie działał w mplayer do odtwarzania MP4? Gdzie go można znaleść?
Na stronie mplayera jest napisane że jeden z kodeków umieszczonych w bibliotece ALL... . BIZ odtwarza ten format, jednak u mnie pojawia się informacja:
MPlayer 1.0pre5-RPM-3.3.3 © 2000-2004 MPlayer Team
CPU: Advanced Micro Devices Athlon MP/XP Thoroughbred 1469 MHz (Family: 6, Stepping: 1)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection - WARNING - this is not optimal!
To get best performance, recompile MPlayer with --disable-runtime-cpudetection.
Reading config file /etc/mplayer/mplayer.conf
Reading config file /root/.mplayer/config
Reading /root/.mplayer/codecs.conf: Reading /etc/mplayer/codecs.conf: 73 audio & 180 video codecs
font: can't open file: /root/.mplayer/font/font.desc
font: can't open file: /usr/share/mplayer/font/font.desc
Using Linux hardware RTC timing (1024Hz).
Input config file /etc/mplayer/input.conf parsed: 53 binds
Playing Pink Panter.DVDRiP.mp4.
QuickTime/MOV file format detected.
MOV track #0: 10589 chunks, 148239 samples
MOV: Found unknown movie atom avcC (47)!
MOV: Found unknown movie atom btrt (20)!
Image size: 576 x 416 (24 bpp)
Display size: 576 x 416
Fourcc: avc1 Codec: ''
MOV track #1: 10590 chunks, 115929 samples
Audio bits: 16 chans: 2 rate: 24000
MOV: Found MPEG4 audio Elementary Stream Descriptor atom (39)!
Fourcc: mp4a
MOV: longest streams: A: #1 (115929 samples) V: #0 (148239 samples)
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
AUDIO: 48000 Hz, 2 ch, 16 bit (0x10), ratio: 16000->192000 (128,0 kbit)
Selected audio codec: [faad] afm:faad (FAAD AAC (MPEG2/MPEG4 Audio) decoder)
vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display)
Read DOCS/HTML/en/codecs.html!
Checking audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
AF_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
AF_pre: 48000Hz 2ch Signed 16-bit (Little-Endian)
AO: [oss] 48000Hz 2ch Signed 16-bit (Little-Endian) (2 bps)
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Video: no video
Starting playback...
...i mam odtwarzane jedynie AUDIO
RPMy pobrałem z www.sourceforge.net i tylko ta wersja MPLAYER-a (nie jest najnowsza) zadziałała bez większych problemów z moim MENCODERem.
Inne (nowsze lub starsze wersje obu aplikacji) nie zadziałały na mojej FC4.
Do tej pory z żadnym z formatów nie miałem problemów (wszystkie wypisane w liście kodeków na stronie głównej MPLAYERa działały bez zarzutów). Pewnie któryś z kodeków wymaga uzupełnienia, lecz nie wiem gdzie go mogę znaleść!
SQ6ELC
A skąd instalowałeś tego MPlayera?
Jest taka strona - http://rpm.livna.org/configuration.html.
Należy postępować zgodnie ze wskazówkami zawartymi nan niej.
Ja z tego zainstalowałem sobie MPlayera. Kaffeine itp.
I co najważniejsze filmy grają.
Instalacja przez Yum-a lub menu/system/ Add/remove software. cool.gifcool.gif
