Matey Napisano Kwiecień 21, 2006 Zgłoszenie Share Napisano Kwiecień 21, 2006 Hej Mam problem z plikami RMVB w FC5, mianowicie kiedy chce go otworzyc stwierdza blad 0x30345652 czyli niezbyt wiadomo o co chodzi, ale obrazu nie ma.Rzecz jasna mam wszystkie kodeki w /usr/lib/win32. Dzwiek w tle leci... Opening audio decoder: [realaud] RealAudio decoder opening shared obj '/usr/lib/win32/cook.so' Audio codec: [24] 64 Kbps Stereo Music - RealAudio Audio bitrate: 64.083 kbit/s (8010 bps) AUDIO: 44100 Hz, 2 ch, s16le, 64.1 kbit/4.54% (ratio: 8010->176400) Selected audio codec: [ra10cook] afm:realaud (RealPlayer 10 COOK audio) ========================================================================== vo: X11 running at 1280x768 with depth 24 and 32 bpp (":0.0" => local display) ========================================================================== Opening video decoder: [realvid] RealVideo decoder opening shared obj '/usr/lib/win32/drvc.so' Error: /usr/lib/win32/drvc.so: cannot restore segment prot after reloc: Permission denied opening win32 dll 'drvc.so' Win32 LoadLibrary failed to load: drvc.so, /usr/lib/win32/drvc.so, /usr/local/lib/win32/drvc.so Error loading dll ERROR: Could not open required DirectShow codec drvc.so. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder opening shared obj '/usr/lib/win32/drv4.so.6.0' Error: /usr/lib/win32/drv4.so.6.0: cannot restore segment prot after reloc: Permission denied opening win32 dll 'drv4.so.6.0' Win32 LoadLibrary failed to load: drv4.so.6.0, /usr/lib/win32/drv4.so.6.0, /usr/local/lib/win32/drv4.so.6.0 Error loading dll ERROR: Could not open required DirectShow codec drv4.so.6.0. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder opening win32 dll 'drv43260.dll' Win32 LoadLibrary failed to load: drv43260.dll, /usr/lib/win32/drv43260.dll, /usr/local/lib/win32/drv43260.dll Error loading dll ERROR: Could not open required DirectShow codec drv43260.dll. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder opening shared obj '/usr/lib/win32/drvc.bundle/Contents/MacOS/drvc' Error: /usr/lib/win32/drvc.bundle/Contents/MacOS/drvc: cannot open shared object file: No such file or directory opening win32 dll 'drvc.bundle/Contents/MacOS/drvc' Win32 LoadLibrary failed to load: drvc.bundle/Contents/MacOS/drvc, /usr/lib/win32/drvc.bundle/Contents/MacOS/drvc, /usr/local/lib/win32/drvc.bundle/Contents/MacOS/drvc Error loading dll ERROR: Could not open required DirectShow codec drvc.bundle/Contents/MacOS/drvc. Read the RealVideo section of the DOCS! VDecoder init failed :( Cannot find codec matching selected -vo and video format 0x30345652. Read DOCS/HTML/en/codecs.html! ========================================================================== Checking audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le... AF_pre: 44100Hz/2ch/s16le [AO OSS] audio_setup: Can't open audio device /dev/dsp: Device or resource busy alsa-init: 1 soundcard found, using: default alsa: 44100 Hz/2 channels/4 bpf/60208 bytes buffer/Signed 16 bit Little Endian AO: [alsa] 44100Hz 2ch s16le (2 bps) Building audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le... Video: no video Starting playback... alsa-uninit: pcm closed Da sie cos z tym zrobic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
pawvic Napisano Kwiecień 21, 2006 Zgłoszenie Share Napisano Kwiecień 21, 2006 Proszę pobierz: rp9codecs-win32-20050115.tar.bz2 i zrób to samo, co z poprzednimi kodekami. W razie, gdy potem pojawi ci się jakiś błąd, to możesz przeczytać ten post. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Matey Napisano Kwiecień 22, 2006 Autor Zgłoszenie Share Napisano Kwiecień 22, 2006 Proszę pobierz: rp9codecs-win32-20050115.tar.bz2 i zrób to samo, co z poprzednimi kodekami. W razie, gdy potem pojawi ci się jakiś błąd, to możesz przeczytać ten post. No tak tez zrobilem, i dla odmiany : Opening audio decoder: [realaud] RealAudio decoder opening shared obj '/usr/lib/win32/cook.so' Audio codec: [24] 64 Kbps Stereo Music - RealAudio Audio bitrate: 64.083 kbit/s (8010 bps) AUDIO: 44100 Hz, 2 ch, s16le, 64.1 kbit/4.54% (ratio: 8010->176400) Selected audio codec: [ra10cook] afm:realaud (RealPlayer 10 COOK audio) ========================================================================== vo: X11 running at 1280x768 with depth 24 and 32 bpp (":0.0" => local display) ========================================================================== Opening video decoder: [realvid] RealVideo decoder opening shared obj '/usr/lib/win32/drvc.so' Error: /usr/lib/win32/drvc.so: cannot restore segment prot after reloc: Permission denied opening win32 dll 'drvc.so' Win32 LoadLibrary failed to load: drvc.so, /usr/lib/win32/drvc.so, /usr/local/lib/win32/drvc.so Error loading dll ERROR: Could not open required DirectShow codec drvc.so. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder opening shared obj '/usr/lib/win32/drv4.so.6.0' Error: /usr/lib/win32/drv4.so.6.0: cannot restore segment prot after reloc: Permission denied opening win32 dll 'drv4.so.6.0' Win32 LoadLibrary failed to load: drv4.so.6.0, /usr/lib/win32/drv4.so.6.0, /usr/local/lib/win32/drv4.so.6.0 Error loading dll ERROR: Could not open required DirectShow codec drv4.so.6.0. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder opening win32 dll 'drv43260.dll' Win32 LoadLibrary failed to load: PNCRT.dll, /usr/lib/win32/PNCRT.dll, /usr/local/lib/win32/PNCRT.dll MPlayer interrupted by signal 11 in module: init_video_codec - MPlayer crashed by bad usage of CPU/FPU/RAM. Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash. - MPlayer crashed. This shouldn't happen. It can be a bug in the MPlayer code _or_ in your drivers _or_ in your gcc version. If you think it's MPlayer's fault, please read DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and won't help unless you provide this information when reporting a possible bug. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
grs_84pl Napisano Kwiecień 22, 2006 Zgłoszenie Share Napisano Kwiecień 22, 2006 Win32 LoadLibrary failed to load: PNCRT.dll, /usr/lib/win32/PNCRT.dll, /usr/local/lib/win32/PNCRT.dll Masz w tym katalogu te pliki o które sie pulta ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
