Problem Z Sdl
edas
aby zainstalować gierkę wormux potrzebny jest sdl. Przy instalacji fedorki 5 w standardzie jest SDL instalowane. No i robię takie coś w konsloi whereis sdl a tu nic! Tak samo jak odpalam instalator tej gierki wywala mi że nie ma SDL choć w yumie jest. Więc co tu jest nie tak? Dopiero co zainstalowane fc5 bo jak zobaczyłem że tak jest to reinstalnęłem system
# rpm -qa |grep SDL
SDL-1.2.9-5.2.1
a ./configure --prefix=/home/edas/wormux daje
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for shared library run path origin... /bin/sh: ./config.rpath: No such file or directory
done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking whether make sets $(MAKE)... (cached) yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... yes
checking CXXFLAGS for maximum warnings... -Wall
checking gcc version... 4.1.0
checking for sdl-config... no
checking for SDL - version >= 1.2.6... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
configure: error: *** SDL version 1.2.6 not found!
Potrzebujesz jeszcze paczek SDL_ttf, SDL_image, SDL_mixer i SDL_gfx. A jeśli po ich wgraniu się nie skompiluje to dogrywasz każdą z nich w postaci -devel, a do tego jeszcze SDL-devel, czyli najprawdopodobniej będziesz musiał wywołać komendę
yum install SDL-devel SDL_ttf SDL_ttf-devel SDL_image SDL_image-devel SDL_mixer SDL_mixer-devel SDL_gfx SDL_gfx-devel
Aha, i jeszcze jakbyś po skompilowaniu aplikacji miał problem "Naruszenie ochrony pamięci" to musisz konfigurację wykonać z parametrami:
./configure --with-gnu-ld --disable-rpath
Gość
