Instalacja Zend Enterprise Z Pliku .bin
asterix1983
cd <katalog, w którym masz ten plik>
chmod +rx nazwapliku.bin
./nazwapliku.bin
no i powinno się odpalić
Orkan
zrobiłem tak jak powiedziałeś i efekt:
./ZendStudio-5_0_0.bin
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
awk: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
dirname: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
/bin/ls: error while loading shared libraries: librt.so.1: cannot open shared object file: No such file or directory
basename: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
hostname: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
Launching installer...
grep: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
/tmp/install.dir.3915/Linux/resource/jre/bin/java: error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
I teraz nie wiem czy ja mam coś źle w systemie czy plik jest uszkodzony. Co mam zrobić?
Pozdrawiam i przepraszam za głupie pytania
