sid_s Napisano Lipiec 29, 2006 Zgłoszenie Share Napisano Lipiec 29, 2006 (edytowane) Od kilku dni wojuje z uruchomieniem neta na fc5. Mam plyte K8F4-4 delux asusa. Nie wiem czemu ale system rozpoznaje siecowke niestety przy probie aktywaci wyskakuje Nie znaleziono urządzenia eth0 forcedeth opóźnienie inicjowania. Chce zainstalowac stery nvidi ale podczas instalacji wyskakuje blad mozecie mi powiedziec co mam zrobic. nforce-installer log file '/var/log/nvidia-nforce-installer.log' creation time: Sat Jul 29 11:37:34 2006 option status: license pre-accepted : false expert : false uninstall : false driver info : false no precompiled interface : false no ncurses color : false no questions : false silent : false Installer install prefix : /usr kernel source path : (not specified) net kernel install path : (not specified) audio kernel install path : (not specified) proc mount point : /proc ui : (not specified) tmpdir : /tmp Using: nvidia-installer ncurses user interface -> Found package NVIDIA network driver for Linux-x86_64 -> Found package NVIDIA audio driver for Linux-x86_64 -> Please select packages for installation: Selections: NVIDIA network driver for Linux-x86_64 (1.0-12) NVIDIA audio driver for Linux-x86_64 (1.0-6) -> Starting install of NVIDIA network driver for Linux-x86_64 -> Checking for loaded module nvnet -> Checking for loaded module forcedeth -> Trying to remove loaded module forcedeth -> License accepted. -> Skipping check for conflicting rpms. -> /proc/version is Linux version 2.6.17-1.2157_FC5 ([email protected]) (gcc version 4.1.1 20060525 (Red Hat 4.1.1-1)) #1 SMP Tue Jul 11 22:53:56 EDT 2006 -> No precompiled kernel interface was found to match your kernel; this means that the installer will need to compile a new kernel interface. -> Kernel source path: '/lib/modules/2.6.17-1.2157_FC5/source' -> Kernel output path: '/lib/modules/2.6.17-1.2157_FC5/build' -> Performing cc_version_check with CC="cc". -> running command /bin/grep "^PATCHLEVEL =" /lib/modules/2.6.17-1.2157_FC5/source/Makefile | /bin/cut -d " " -f 3 -> Kernel module filename is nvnet.ko Cleaning kernel module build directory. executing: 'cd ./nvnet; make clean'... rm -f *.ko *mod.* *.cmd nvenet.o nvenetif.o nvnet.o *~ core -> Building kernel module: executing: 'cd ./nvnet; make module SYSSRC=/lib/modules/2.6.17-1.2157_FC5/so urce SYSOUT=/lib/modules/2.6.17-1.2157_FC5/build'... make -C /lib/modules/2.6.17-1.2157_FC5/build \ KBUILD_SRC=/usr/src/kernels/2.6.17-1.2157_FC5-x86_64 \ KBUILD_EXTMOD="/tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet" -f / usr/src/kernels/2.6.17-1.2157_FC5-x86_64/Makefile modules mkdir -p /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/.tmp_versio ns rm -f /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/.tmp_versions/ * make -f /usr/src/kernels/2.6.17-1.2157_FC5-x86_64/scripts/Makefile.build obj =/tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet cc -Wp,-MD,/tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/.nvenet .o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.1.0/include -D__ KERNEL__ -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.17-1.2157_FC5-x86_64/in clude -include include/linux/autoconf.h -I/tmp/selfgz2532/NFORCE-Linux-x86 _64-1.0-0306-pkg1/nvnet -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fn o-strict-aliasing -fno-common -Wstrict-prototypes -Wundef -Werror-implicit-f unction-declaration -Os -fomit-frame-poin ter -fasynchronous-unwind-tables -g -mtune=generic -m64 -mno-red-zone -mcmod el=kernel -pipe -ffunction-sections -fno-reorder-blocks -Wno-sign-compare -f unit-at-a-time -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wdeclaration-after-st atement -Wno-pointer-sign -DDRIVERVER=\"9999\" -I/tmp/selfgz2532/NFORCE-Lin ux-x86_64-1.0-0306-pkg1/nvnet -Wall -Wimplicit -Wreturn-type -Wswitch -Wform at -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multichar -Werror -O -MD -Wno-cast-qual -Wno-error -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENA ME=KBUILD_STR(nvenet)" -D"KBUILD_MODNAME=KBUILD_STR(nvnet)" -c -o /tmp/self gz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/.tmp_nvenet.o /tmp/selfgz2532 /NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c In file included from include/linux/list.h:7, from include/linux/wait.h:23, from include/asm/semaphore.h:42, from include/linux/sched.h:20, from include/linux/module.h:10, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.h:20, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.c:22: include/linux/prefetch.h: In function ‘prefetch_range’: include/linux/prefetch.h:62: warning: pointer of type ‘void *’ used in a rithmetic In file included from include/asm/elf.h:11, from include/linux/elf.h:6, from include/linux/module.h:17, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.h:20, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.c:22: include/asm/compat.h: In function ‘compat_alloc_user_space’: include/asm/compat.h:202: warning: pointer of type ‘void *’ used in arit hmetic In file included from include/linux/dmapool.h:14, from include/linux/pci.h:559, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.h:32, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.c:22: include/asm/io.h: In function ‘check_signature’: include/asm/io.h:276: warning: wrong type argument to increment In file included from include/asm/pci.h:93, from include/linux/pci.h:685, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.h:32, from /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t/nvenet.c:22: include/asm-generic/pci-dma-compat.h: In function ‘pci_map_page’: include/asm-generic/pci-dma-compat.h:49: warning: pointer of type ‘void *â €™ used in arithmetic /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c: At top lev el: /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:217: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:220: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:223: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:226: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:229: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:232: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:235: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:238: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:241: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:244: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:247: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:250: error: expected ‘)’ before string constant /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:336: warnin g: initialization from incompatible pointer type /tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet.c:1226:5: war ning: "SKB_GSO_TCPV4" is not defined make[4]: *** [/tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvnet/nvenet .o] Błąd 1 make[3]: *** [_module_/tmp/selfgz2532/NFORCE-Linux-x86_64-1.0-0306-pkg1/nvne t] Błąd 2 make[2]: *** [modules] Błąd 2 -> Error. ERROR: The NVIDIA kernel module was not created. ERROR: Installation of the network driver has failed. Please see the file '/var/log/nvidia-nforce-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com. -> Starting install of NVIDIA audio driver for Linux-x86_64 -> Checking for loaded module nvsound -> Checking for loaded module nvaudio -> License not accepted, aborting installation of audio driver. Z gory dzieki za pomoc. Pozdrawiam Edytowane Lipiec 29, 2006 przez lszk Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SebOOl Napisano Lipiec 31, 2006 Zgłoszenie Share Napisano Lipiec 31, 2006 Witaj Wklej zwartość pliku /var/log/nvidia-nforce-installer.log Ja róniez mam płytę na nForce4 i u mnie wszystko działa prawidowo, tyle że mam inne nazwy kart sieciowych. BTW czemu nie spróbujesz zainstalować FC5 :?: Pozdrawiam SebOOl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
