Style I Windeco Dla Kde - Rpm
Livio™
Próbowałem na 2 sposoby, po instalacji buildsys-build, ~-macros i reszty.
[root@livio-desktop polyester-0.9.3]# CC=gcc32 CXX=gcc32 CCX=gcc32 ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
/bin/sh: /home/livio/Dokumenty/Pobrane: No such file or directory
configure: WARNING: `missing' script is too old or missing
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for kde-config... /usr/bin/kde-config
checking where to install... /usr (as returned by kde-config)
checking for style of include used by make... GNU
checking for gcc... gcc32
checking for C compiler default output file name... configure: error: C compiler                                             cannot create executables
See `config.log' for more details.
[root@livio-desktop polyester-0.9.3]# ./configure
checking build system type... i686-pc-linux-gnulibc1
checking host system type... i686-pc-linux-gnulibc1
checking target system type... i686-pc-linux-gnulibc1
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... /lib/cpp
configure: error: C preprocessor "/lib/cpp" fails sanity check
[root@livio-desktop polyester-0.9.3]# CC=gcc32 ./configure
Bez Cc= bla bla bla ./configure zwraca mi to samo "/lib/cpp fails sanity check".
PS: To nowa instalka Fedory, bo testowałem Kubuntu.
Config.log?
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59.  Invocation command line was
 $ ./configure
## Platform. ##
hostname = livio-desktop
uname -m = i686
uname -r = 2.6.15-1.2054_FC5
uname -s = Linux
uname -v = #1 Tue Mar 14 15:48:33 EST 2006
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = i686
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
hostinfo               = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/kerberos/sbin
PATH: /usr/kerberos/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /home/livio/bin
## Core tests. ##
configure:1566: checking build system type
configure:1584: result: i686-pc-linux-gnu
configure:1592: checking host system type
configure:1606: result: i686-pc-linux-gnu
configure:1614: checking target system type
configure:1628: result: i686-pc-linux-gnu
configure:1675: checking for a BSD-compatible install
configure:1730: result: /usr/bin/install -c
configure:1745: checking for -p flag to install
configure:1758: result: yes
configure:1769: checking whether build environment is sane
configure:1812: result: yes
configure:1823: WARNING: `missing' script is too old or missing
configure:1864: checking for gawk
configure:1880: found /usr/bin/gawk
configure:1890: result: gawk
configure:1900: checking whether make sets $(MAKE)
configure:1920: result: yes
configure:2088: checking whether to enable maintainer-specific portions of Makefiles
configure:2097: result: no
configure:2131: checking for kde-config
configure:2193: result: /usr/bin/kde-config
configure:2289: checking where to install
configure:2293: result: /usr (as returned by kde-config)
configure:2348: checking for style of include used by make
configure:2376: result: GNU
configure:2524: checking for gcc
configure:2550: result: gcc32
configure:2794: checking for C compiler version
configure:2797: gcc32 --version </dev/null >&5
./configure: line 2798: gcc32: command not found
configure:2800: $? = 127
configure:2802: gcc32 -v </dev/null >&5
./configure: line 2803: gcc32: command not found
configure:2805: $? = 127
configure:2807: gcc32 -V </dev/null >&5
./configure: line 2808: gcc32: command not found
configure:2810: $? = 127
configure:2833: checking for C compiler default output file name
configure:2836: gcc32     conftest.c  >&5
./configure: line 2837: gcc32: command not found
configure:2839: $? = 127
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE "polyester"
| #define VERSION "0.9.3"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:2878: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnu
ac_cv_build_alias=i686-pc-linux-gnu
ac_cv_env_CC_set=set
ac_cv_env_CC_value=gcc32
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnu
ac_cv_host_alias=i686-pc-linux-gnu
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc32
ac_cv_prog_make_make_set=yes
ac_cv_target=i686-pc-linux-gnu
ac_cv_target_alias=i686-pc-linux-gnu
kde_cv_path=/usr/bin/kde-config
kde_cv_path_kde_config=/usr/bin/kde-config
## Output variables. ##
ACLOCAL='aclocal-1.9'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='tar'
AR=''
ARTSCCONFIG=''
AUTOCONF='autoconf'
AUTODIRS=''
AUTOHEADER='autoheader'
AUTOMAKE='automake-1.9'
AWK='gawk'
CC='gcc32'
CCDEPMODE=''
CFLAGS=' '
CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in'
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DCOPIDL2CPP=''
DCOPIDL=''
DCOPIDLNG=''
DCOP_DEPENDENCIES=''
DEFS=''
DEPDIR='.deps'
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_PERMISSIVE_FLAG=''
EXEEXT=''
F77=''
FFLAGS=''
FRAMEWORK_COREAUDIO=''
GMSGFMT=''
HAVE_GCC_VISIBILITY=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
KCFG_DEPENDENCIES=''
KCONFIG_COMPILER=''
KDECONFIG='/usr/bin/kde-config'
KDE_CHECK_PLUGIN=''
KDE_EXTRA_RPATH=''
KDE_INCLUDES=''
KDE_LDFLAGS=''
KDE_MT_LDFLAGS=''
KDE_MT_LIBS=''
KDE_NO_UNDEFINED=''
KDE_PLUGIN=''
KDE_RPATH=''
KDE_USE_CLOSURE_FALSE=''
KDE_USE_CLOSURE_TRUE=''
KDE_USE_FINAL_FALSE=''
KDE_USE_FINAL_TRUE=''
KDE_USE_FPIE=''
KDE_USE_NMCHECK_FALSE=''
KDE_USE_NMCHECK_TRUE=''
KDE_USE_PIE=''
KDE_XSL_STYLESHEET=''
LDFLAGS=''
LDFLAGS_AS_NEEDED=''
LDFLAGS_NEW_DTAGS=''
LIBCOMPAT=''
LIBCRYPT=''
LIBDL=''
LIBJPEG=''
LIBOBJS=''
LIBPNG=''
LIBPTHREAD=''
LIBRESOLV=''
LIBS=''
LIBSM=''
LIBSOCKET=''
LIBTOOL=''
LIBUCB=''
LIBUTIL=''
LIBZ=''
LIB_KAB=''
LIB_KABC=''
LIB_KDECORE=''
LIB_KDED=''
LIB_KDEPIM=''
LIB_KDEPRINT=''
LIB_KDEUI=''
LIB_KDNSSD=''
LIB_KFILE=''
LIB_KFM=''
LIB_KHTML=''
LIB_KIMPROXY=''
LIB_KIO=''
LIB_KJS=''
LIB_KNEWSTUFF=''
LIB_KPARTS=''
LIB_KSPELL=''
LIB_KSYCOCA=''
LIB_KUNITTEST=''
LIB_KUTILS=''
LIB_POLL=''
LIB_QPE=''
LIB_QT=''
LIB_SMB=''
LIB_X11=''
LIB_XEXT=''
LIB_XRENDER=''
LN_S=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='makeinfo'
MAKEKDEWIDGETS=''
MCOPIDL=''
MEINPROC=''
MOC=''
MSGFMT=''
NOOPT_CFLAGS=''
NOOPT_CXXFLAGS=''
OBJEXT=''
PACKAGE='polyester'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
QTE_NORTTI=''
QT_INCLUDES=''
QT_LDFLAGS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TOPSUBDIRS=''
UIC=''
UIC_TR=''
USER_INCLUDES=''
USER_LDFLAGS=''
USE_EXCEPTIONS=''
USE_RTTI=''
USE_THREADS=''
VERSION='0.9.3'
WOVERLOADED_VIRTUAL=''
XGETTEXT=''
XMLLINT=''
X_EXTRA_LIBS=''
X_INCLUDES=''
X_LDFLAGS=''
X_PRE_LIBS=''
X_RPATH=''
ac_ct_AR=''
ac_ct_CC='gcc32'
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
all_includes=''
all_libraries=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include='include'
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnu'
build_alias=''
build_cpu='i686'
build_os='linux-gnu'
build_vendor='pc'
datadir='${prefix}/share'
exec_prefix='NONE'
host='i686-pc-linux-gnu'
host_alias=''
host_cpu='i686'
host_os='linux-gnu'
host_vendor='pc'
include_ARTS_FALSE=''
include_ARTS_TRUE=''
include_x11_FALSE=''
include_x11_TRUE=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/livio/Dokumenty/Pobrane pliki/polyester-0.9.3/polyester-0.9.3/admin/install-sh'
kde_appsdir=''
kde_bindir=''
kde_confdir=''
kde_datadir=''
kde_htmldir=''
kde_icondir=''
kde_includes=''
kde_kcfgdir=''
kde_libraries=''
kde_libs_htmldir='/usr/share/doc/HTML'
kde_libs_prefix='/usr'
kde_locale=''
kde_mimedir=''
kde_moduledir=''
kde_qtver=''
kde_servicesdir=''
kde_servicetypesdir=''
kde_sounddir=''
kde_styledir=''
kde_templatesdir=''
kde_wallpaperdir=''
kde_widgetdir=''
kdeinitdir=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
prefix='/usr'
program_transform_name='s,x,x,'
qt_includes=''
qt_libraries=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='i686-pc-linux-gnu'
target_alias=''
target_cpu='i686'
target_os='linux-gnu'
target_vendor='pc'
unsermake_enable_pch_FALSE=''
unsermake_enable_pch_TRUE=''
x_includes='NONE'
x_libraries='NONE'
xdg_appsdir=''
xdg_directorydir=''
xdg_menudir=''
## confdefs.h. ##
configure: exit 77
  • Odpowiedzi 79
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
W takim razie pokaż config.log, ale nie jak próbujesz z gcc32, tylko z gcc. Bo jak sam widzisz, przy próbie z gcc32 w config.log znajdują się linie typu:
W związku z tym zrób ./configure normalnie i pokaż tamten config.log.
Ok. Mam mysl! /lib/cpp fails sanity check moze byc powodowane tym, ze jest to dowiazanie symboliczne, chociaz czy tak czy siak powinno dzialac :/.
 $ ./configure
## Platform. ##
uname -m = i686
uname -s = Linux
/bin/arch              = i686
hostinfo               = unknown
PATH: /usr/bin
PATH: /bin
## Core tests. ##
configure:1584: result: i686-pc-linux-gnulibc1
configure:1606: result: i686-pc-linux-gnulibc1
configure:1628: result: i686-pc-linux-gnulibc1
configure:2540: found /usr/bin/gcc
configure:2797: gcc --version </dev/null >&5
gcc (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1)
Copyright Š 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2800: $? = 0
configure:2802: gcc -v </dev/null >&5
Using built-in specs.
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=i386-redhat-linux
Thread model: posix
gcc version 4.1.1 20060525 (Red Hat 4.1.1-1)
configure:2805: $? = 0
configure:2807: gcc -V </dev/null >&5
gcc: '-V' option must have argument
configure:2836: gcc     conftest.c  >&5
configure:2839: $? = 0
configure:2885: result: a.out
configure:2890: checking whether the C compiler works
configure:2896: ./a.out
configure:2899: $? = 0
configure:2916: result: yes
configure:2923: checking whether we are cross compiling
configure:2925: result: no
configure:2928: checking for suffix of executables
configure:2930: gcc -o conftest     conftest.c  >&5
configure:2933: $? = 0
configure:2958: result:
configure:2964: checking for suffix of object files
configure:2985: gcc -c    conftest.c >&5
configure:2988: $? = 0
configure:3010: result: o
configure:3014: checking whether we are using the GNU C compiler
configure:3038: gcc -c    conftest.c >&5
configure:3044: $? = 0
configure:3048: test -z
		 || test ! -s conftest.err
configure:3051: $? = 0
configure:3054: test -s conftest.o
configure:3057: $? = 0
configure:3070: result: yes
configure:3076: checking whether gcc accepts -g
configure:3097: gcc -c -g  conftest.c >&5
configure:3103: $? = 0
configure:3107: test -z
configure:3110: $? = 0
configure:3113: test -s conftest.o
configure:3116: $? = 0
configure:3127: result: yes
configure:3144: checking for gcc option to accept ANSI C
configure:3214: gcc  -c    conftest.c >&5
conftest.c:12:19: error: stdio.h: No such file or directory
conftest.c:13:23: error: sys/types.h: No such file or directory
conftest.c:14:22: error: sys/stat.h: No such file or directory
conftest.c:17: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
conftest.c:46: error: expected declaration specifiers or '...' before 'FILE'
configure:3220: $? = 1
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
| #include <sys/types.h>
| #include <sys/stat.h>
| /* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
| struct buf { int x; };
| FILE * (*rcsopen) (struct buf *, struct stat *, int);
| static char *e (p, i)
|      char **p;
|      int i;
|   return p[i];
| static char *f (char * (*g) (char **, int), char **p, ...)
|   char *s;
|   va_list v;
|   va_start (v,p);
|   s = g (p, va_arg (v,int));
|   va_end (v);
|   return s;
| /* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
|    function prototypes and stuff, but not '\xHH' hex character constants.
|    These don't provoke an error unfortunately, instead are silently treated
|    as 'x'.  The following induces an error, until -std1 is added to get
|    proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
|    array size at least.  It's necessary to write '\x00'==0 to get something
|    that's true only with -std1.  */
| int osf4_cc_array ['\x00' == 0 ? 1 : -1];
| int test (int i, double x);
| struct s1 {int (*f) (int a);};
| struct s2 {int (*f) (double a);};
| int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
| int argc;
| char **argv;
| int
| main ()
| return f (e, argv, 0) != argv[0]  ||  f (e, argv, 1) != argv[1];
|   return 0;
configure:3214: gcc -qlanglvl=ansi -c    conftest.c >&5
gcc: unrecognized option '-qlanglvl=ansi'
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|   return p[i];
|   char *s;
|   va_list v;
|   va_start (v,p);
|   va_end (v);
|   return s;
| int argc;
| char **argv;
| int
| main ()
|   return 0;
configure:3214: gcc -std1 -c    conftest.c >&5
cc1: error: unrecognized command line option "-std1"
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|   return p[i];
|   char *s;
|   va_list v;
|   va_start (v,p);
|   va_end (v);
|   return s;
| int argc;
| char **argv;
| int
| main ()
|   return 0;
configure:3214: gcc -Ae -c    conftest.c >&5
<command line>:1:2: error: missing '(' after predicate
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|   return p[i];
|   char *s;
|   va_list v;
|   va_start (v,p);
|   va_end (v);
|   return s;
| int argc;
| char **argv;
| int
| main ()
|   return 0;
configure:3214: gcc -Aa -D_HPUX_SOURCE -c    conftest.c >&5
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|   return p[i];
|   char *s;
|   va_list v;
|   va_start (v,p);
|   va_end (v);
|   return s;
| int argc;
| char **argv;
| int
| main ()
|   return 0;
configure:3214: gcc -Xc -D__EXTENSIONS__ -c    conftest.c >&5
gcc: unrecognized option '-Xc'
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|   return p[i];
|   char *s;
|   va_list v;
|   va_start (v,p);
|   va_end (v);
|   return s;
| int argc;
| char **argv;
| int
| main ()
|   return 0;
configure:3251: result: none needed
configure:3269: gcc -c    conftest.c >&5
conftest.c:2: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'me'
configure:3275: $? = 1
| #ifndef __cplusplus
|   choke me
| #endif
configure:3410: checking dependency style of gcc
configure:3500: result: gcc3
configure:3523: checking how to run the C preprocessor
configure:3558: gcc -E  conftest.c
In file included from /usr/lib/gcc/i386-redhat-linux/4.1.1/include/syslimits.h:7,
                from /usr/lib/gcc/i386-redhat-linux/4.1.1/include/limits.h:11,
                from conftest.c:12:
/usr/lib/gcc/i386-redhat-linux/4.1.1/include/limits.h:122:61: error: limits.h: No such file or directory
configure:3564: $? = 1
| /* confdefs.h.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| 		     Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
configure:3558: gcc -E -traditional-cpp  conftest.c
conftest.c:14: error: assert.h: No such file or directory
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
configure:3558: /lib/cpp  conftest.c
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
configure:3641: result: /lib/cpp
configure:3665: /lib/cpp  conftest.c
                from conftest.c:12:
configure:3671: $? = 1
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
| 		     Syntax error
configure:3740: error: C preprocessor "/lib/cpp" fails sanity check
ac_cv_build=i686-pc-linux-gnulibc1
ac_cv_build_alias=i686-pc-linux-gnulibc1
ac_cv_c_compiler_gnu=yes
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CPP_set=
ac_cv_env_CXX_set=
ac_cv_env_F77_set=
ac_cv_exeext=
ac_cv_host=i686-pc-linux-gnulibc1
ac_cv_host_alias=i686-pc-linux-gnulibc1
ac_cv_objext=o
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP=/lib/cpp
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_stdc=no
ac_cv_target=i686-pc-linux-gnulibc1
ac_cv_target_alias=i686-pc-linux-gnulibc1
am_cv_CC_dependencies_compiler_type=gcc3
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='tar'
AR=''
ARTSCCONFIG=''
AUTOCONF='autoconf'
AUTODIRS=''
AWK='gawk'
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS=' '
CPP='/lib/cpp'
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DCOPIDL2CPP=''
DCOPIDL=''
DCOPIDLNG=''
DEFS=''
DEPDIR='.deps'
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
F77=''
FFLAGS=''
GMSGFMT=''
KCONFIG_COMPILER=''
KDE_CHECK_PLUGIN=''
KDE_EXTRA_RPATH=''
KDE_INCLUDES=''
KDE_LDFLAGS=''
KDE_MT_LDFLAGS=''
KDE_MT_LIBS=''
KDE_NO_UNDEFINED=''
KDE_PLUGIN=''
KDE_RPATH=''
KDE_USE_FPIE=''
KDE_USE_PIE=''
LDFLAGS=''
LIBCOMPAT=''
LIBCRYPT=''
LIBDL=''
LIBJPEG=''
LIBOBJS=''
LIBPNG=''
LIBPTHREAD=''
LIBRESOLV=''
LIBS=''
LIBSM=''
LIBSOCKET=''
LIBTOOL=''
LIBUCB=''
LIBUTIL=''
LIBZ=''
LIB_KAB=''
LIB_KABC=''
LIB_KDECORE=''
LIB_KDED=''
LIB_KDEPIM=''
LIB_KDEPRINT=''
LIB_KDEUI=''
LIB_KDNSSD=''
LIB_KFILE=''
LIB_KFM=''
LIB_KHTML=''
LIB_KIMPROXY=''
LIB_KIO=''
LIB_KJS=''
LIB_KNEWSTUFF=''
LIB_KPARTS=''
LIB_KSPELL=''
LIB_KSYCOCA=''
LIB_KUNITTEST=''
LIB_KUTILS=''
LIB_POLL=''
LIB_QPE=''
LIB_QT=''
LIB_SMB=''
LIB_X11=''
LIB_XEXT=''
LIB_XRENDER=''
LN_S=''
LTLIBOBJS=''
MAINT='#'
MAKEINFO='makeinfo'
MAKEKDEWIDGETS=''
MCOPIDL=''
MEINPROC=''
MOC=''
MSGFMT=''
NOOPT_CFLAGS=''
NOOPT_CXXFLAGS=''
OBJEXT='o'
PACKAGE='polyester'
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
QTE_NORTTI=''
QT_INCLUDES=''
QT_LDFLAGS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TOPSUBDIRS=''
UIC=''
UIC_TR=''
USER_INCLUDES=''
USER_LDFLAGS=''
USE_EXCEPTIONS=''
USE_RTTI=''
USE_THREADS=''
VERSION='0.9.3'
XGETTEXT=''
XMLLINT=''
X_EXTRA_LIBS=''
X_INCLUDES=''
X_LDFLAGS=''
X_PRE_LIBS=''
X_RPATH=''
ac_ct_AR=''
ac_ct_CC='gcc'
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
all_includes=''
all_libraries=''
am__fastdepCC_FALSE='#'
am__leading_dot='.'
am__quote=''
build='i686-pc-linux-gnulibc1'
build_alias=''
build_cpu='i686'
build_os='linux-gnulibc1'
build_vendor='pc'
exec_prefix='NONE'
host='i686-pc-linux-gnulibc1'
host_alias=''
host_cpu='i686'
host_os='linux-gnulibc1'
host_vendor='pc'
include_x11_TRUE=''
kde_appsdir=''
kde_bindir=''
kde_confdir=''
kde_datadir=''
kde_htmldir=''
kde_icondir=''
kde_includes=''
kde_kcfgdir=''
kde_libraries=''
kde_locale=''
kde_mimedir=''
kde_moduledir=''
kde_qtver=''
kde_servicesdir=''
kde_sounddir=''
kde_styledir=''
kde_templatesdir=''
kde_wallpaperdir=''
kde_widgetdir=''
kdeinitdir=''
prefix='/usr'
qt_includes=''
qt_libraries=''
target='i686-pc-linux-gnulibc1'
target_alias=''
target_cpu='i686'
target_os='linux-gnulibc1'
target_vendor='pc'
x_includes='NONE'
x_libraries='NONE'
xdg_appsdir=''
xdg_directorydir=''
xdg_menudir=''
## confdefs.h. ##
configure: exit 1
Syntax error? Dziwne...
Aha: jedyny RPM jaki mi teraz potrzebny to właśnie Polyester.
SuSE2, DeKorator, Tasty Menu itepe użyłem dla Madrivy. Ładnie śmigają.
Mam myśl! /lib/cpp fails sanity check może być powodowane tym, że jest to dowiązanie symboliczne
Absolutnie nie, u każdego to jest dowiązanie symboliczne ;)
Ja bym zwrócił uwagę na linie:
$ rpm -qf /usr/include/stdio.h /usr/include/sys/types.h /usr/include/sys/stat.h
glibc-headers-2.4-8
glibc-headers-2.4-8
glibc-headers-2.4-8
Jak widać, wszystkie trzy brakujące pliki należą do pakietu glibc-headers. Więc najprawdopodobniej jest on u Ciebie niewgrany. Sprobuj zainstalować i zobacz czy pomoże.
On się nie instalował z buildsys-build.
A to dziwne, bo powinien... inaczej żaden pakiet, który np. jest dostępny w Extras nie miałby racji bytu (bo tam środowisko do kompilowania tworzy się właśnie z buildsysa).
Wiesz, niezły jesteś w te klocki
Wystarczy umieć czytać logi i wyciągać wnioski z logów... wtedy kompilacja żadnego programu niestraszna ;)
checking for X... configure: error: Can't find X includes. Please check your installation and add the correct paths!
Szlag mnie zarz trafi. Przeleciał i nie było, że fails sanity check. Dzięki za tę podowiedź :).
Wiesz, kompilacja nie jest straszna, ale tylko z libtlen mi się kiedyś powiodła :/.
Brakuje Ci któregoś pakietu -devel związanego z X-ami. Strzelam, że chodzi o libX11-devel. A tak w ogóle, ten polyester, jeśli to jest coś związanego z KDE, to od razu radzę wgrać kdelibs-devel, co powinno uzupełnić bardzo dużo zależności.
A co jeśli kdelibs-devel będzie chciało zaktualizować mi całe KDE ? Raz mi się cała Fedora posypała...
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Installing:
libX11-devel            i386       1.0.0-3.FC5.0    updates           662 k
Installing for dependencies:
libXau-devel            i386       1.0.0-2.2        core               11 k
libXdmcp-devel          i386       1.0.0-2.2        core              7.1 k
mesa-libGL-devel        i386       6.4.2-6.FC5.3    updates           116 k
xorg-x11-proto-devel    i386       7.0-6            core              263 k
Updating for dependencies:
libX11                  i386       1.0.0-3.FC5.0    updates           759 k
mesa-libGL              i386       6.4.2-6.FC5.3    updates           6.4 M
Transaction Summary
Install      5 Package(s)
Update       2 Package(s)
Remove       0 Package(s)
Total download size: 8.2 M
Is this ok [y/N]:
Nie. Nie rozpierdzielę sobie po raz kolejny systemu.
Installing:
kdelibs-devel           i386       6:3.5.1-2.3      core              1.4 M
alsa-lib-devel          i386       1.0.11-3.rc2.2   core              1.4 M
arts-devel              i386       8:1.5.1-1.2      core              218 k
audiofile-devel         i386       1:0.2.6-2.2.1    core               91 k
bzip2-devel             i386       1.0.3-2.2.1      core               38 k
e2fsprogs-devel         i386       1.38-12          core              544 k
esound-devel            i386       1:0.2.36-2.2.1   core               32 k
fontconfig-devel        i386       2.3.94-1         core              168 k
freetype-devel          i386       2.1.10-5.2.1     core              576 k
gamin-devel             i386       0.1.7-1.2.1      core               34 k
glib2-devel             i386       2.10.1-1         core              1.2 M
krb5-devel              i386       1.4.3-4.1        core              957 k
libICE-devel            i386       1.0.0-2.2        core               13 k
libSM-devel             i386       1.0.0-2.2        core              9.3 k
libX11-devel            i386       1.0.0-3          core              677 k
libXcursor-devel        i386       1.1.5.2-2.2      core               14 k
libXext-devel           i386       1.0.0-3.2        core               58 k
libXft-devel            i386       2.1.8.2-3.2      core               16 k
libXinerama-devel       i386       1.0.1-1.2        core              5.0 k
libXrandr-devel         i386       1.1.0.2-2.2      core               15 k
libXrender-devel        i386       0.9.0.2-3.2      core              8.6 k
libXt-devel             i386       1.0.0-2.2        core              338 k
libacl-devel            i386       2.2.34-1.2       core               82 k
libart_lgpl-devel       i386       2.3.17-2.2.1     core               72 k
libattr-devel           i386       2.4.28-1.2       core               33 k
libgcrypt-devel         i386       1.2.2-1.2.1      core              270 k
libgpg-error-devel      i386       1.1-1.2.1        core               15 k
libidn-devel            i386       0.6.2-1.1        core              229 k
libjpeg-devel           i386       6b-36.2.1        core              106 k
libmng-devel            i386       1.0.9-3.2.1      core               53 k
libogg-devel            i386       2:1.1.3-1.2      core               80 k
libpng-devel            i386       2:1.2.8-2.2.1    core              180 k
libtiff-devel           i386       3.7.4-3.2.1      core              483 k
libvorbis-devel         i386       1:1.1.2-1.2      core              563 k
libxml2-devel           i386       2.6.23-1.2       core              2.1 M
libxslt-devel           i386       1.1.15-1.2.1     core              284 k
mesa-libGL-devel        i386       6.4.2-6          core              116 k
openssl-devel           i386       0.9.8a-5.2       core              1.9 M
pcre-devel              i386       6.3-1.2.1        core              195 k
pkgconfig               i386       1:0.20-2.2.1     core               58 k
qt-devel                i386       1:3.3.5-13       core               14 M
zlib-devel              i386       1.2.3-1.2.1      core              101 k
Transaction Summary
Install     45 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 29 M
Is this ok [y/N]:
Jeszcze lepiej...
Widze, ze u Ciebie repo sie nazywa updates. Czyli:
yum install libX11-devel --disablerepo=updates
A tak w ogóle radze od razu wgrac kdelibs-devel. W wyniku zaleznosci libX11-devel i tak zostanie zainstalowany.
EDIT: Sorka, nie widzialem tej edycji. No niestety, tak to jest z kompilacja... ale jak nie chcesz sciagac 29 MB i masz plyte to mozna zrobic, zeby to wgrac z plyty :)
Tu nie chodzi o płytę. Jak zaktualizuję kdelibs-devel i libX11-devel mogę zepsuć system.
I jeszcze 43 pakiety.
29Mb to mało dla mnie. Szybko się pobierze.
Nie sądzę. Pakiety -devel to tylko biblioteki, które nie mają ŻADNEGO wpływu na działanie systemu. Zresztą - jak widać, bez nich system sobie dobrze radził :) One są wykorzystywane tylko i wyłącznie przy kompilacjach.
Mam nadzieję, że masz rację, jak w poprzednich przypadkach :).
Nie chcę zepsuć tego systemu. Jest bardzo dobry.
A nie muszę nic zamykać? Yum chce zaktualizować libpng, libjpeg, libogg i inne...
Jedyna aplikacja bez -devel to: pkgconfig.
Ona ścieżki chyba definiuje.
Słusznie masz poziom "Ekspert" :).
