alpin19 Napisano Sierpień 14, 2006 Zgłoszenie Share Napisano Sierpień 14, 2006 Witam Zainstalowałem zaledwie kilka pakietów i chciałem pracować dalej... Chciałem, ale sypią mi się biblioteki Zainstalowałem takie pakiety: [root@localhost log]# cat yum.log Aug 14 14:55:40 Installed: libsndfile.i386 1.0.15-1.fc5 Aug 14 14:55:45 Installed: kadu.i386 0.5.0-0.7.20060808svn.fc5 Aug 14 14:56:56 Installed: cvs.i386 1.11.21-3.2 Aug 14 14:56:57 Installed: lincvs.i386 1.4.4-1.fc5 Aug 14 15:11:47 Installed: smb4k.i386 0.7.1-1.fc5 Aug 14 17:29:18 Installed: newt-perl.i386 1.08-9.2.1 Aug 14 17:29:18 Installed: crypto-utils.i386 2.2-9.2.1 Aug 14 17:41:52 Installed: mc.i386 1:4.6.1a-14.fc5 Aug 14 15:53:14 Installed: mikmod.i386 3.1.6-36.2.1 Aug 14 15:53:15 Installed: xmms-libs.i386 1:1.2.10-25.fc5 Aug 14 15:53:16 Installed: xmms.i386 1:1.2.10-25.fc5 Aug 14 15:53:33 Installed: xmms-mp3.i386 1.2.10-3.lvn5 Aug 14 15:56:02 Installed: SDL_net.i386 1.2.5-8.fc5 Aug 14 15:56:02 Installed: dosbox.i386 0.65-2.fc5 Aug 14 16:04:16 Updated: libgcj.i386 4.1.1-1.fc5 Aug 14 16:10:56 Updated: java-1.4.2-gcj-compat.i386 1.4.2.0-40jpp_83rh.1 Aug 14 16:17:46 Installed: wine-core.i386 0.9.17-1.fc5 Aug 14 16:17:47 Installed: wine-cms.i386 0.9.17-1.fc5 Aug 14 16:17:47 Installed: wine-ldap.i386 0.9.17-1.fc5 Aug 14 16:17:47 Installed: wine-nas.i386 0.9.17-1.fc5 Aug 14 16:17:47 Installed: wine-capi.i386 0.9.17-1.fc5 Aug 14 16:17:48 Installed: wine-tools.i386 0.9.17-1.fc5 Aug 14 16:17:48 Installed: wine-twain.i386 0.9.17-1.fc5 Aug 14 16:17:49 Installed: wine-esd.i386 0.9.17-1.fc5 Aug 14 16:17:50 Installed: wine-jack.i386 0.9.17-1.fc5 Aug 14 16:17:50 Installed: wine.i386 0.9.17-1.fc5 Aug 14 16:22:24 Installed: qemu.i386 0.8.1-3.fc5 ...a dzieje się tak: [root@localhost log]# yum There was a problem importing one of the Python modules required to run yum. The error leading to this problem was: /usr/lib/libsqlite3.so.0: undefined symbol: sqlite3FrgeX Please install a package which provides this module, or verify that the module is installed correctly. It's possible that the above module doesn't match the current version of Python, which is: 2.4.2 (#1, Feb 12 2006, 03:59:46) [GCC 4.1.0 20060210 (Red Hat 4.1.0-0.24)] If you cannot solve this problem yourself, please go to the yum faq at: http://wiki.linux.duke.edu/YumFaq [root@localhost log]# ..oraz tak: [root@localhost log]# rpm rpm: symbol lookup error: /usr/lib/libsqlite3.so.0: undefined symbol: sqlite3FrgeX [root@localhost log]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Sierpień 15, 2006 Zgłoszenie Share Napisano Sierpień 15, 2006 sprawdz czy masz plik ls /usr/lib|grep libsqlite jakby co to masz tu moje pliki z libsqlite w nazie w tym katalogu http://rapidshare.de/files/29518303/libssqlite.tar.gz.html [uosiu@uosiumen ~]$ rpm -qf /usr/lib/libsqlite3.so.0 sqlite-3.3.3-1.2 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 15, 2006 Zgłoszenie Share Napisano Sierpień 15, 2006 rpm -qf /usr/lib/libsqlite3.so.0 A nie lepiej po prostu yum provides libsqlite3.so.0 Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
siekiera Napisano Sierpień 15, 2006 Zgłoszenie Share Napisano Sierpień 15, 2006 Przecie yum się wywala. No chyba, że u uosia... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alpin19 Napisano Sierpień 16, 2006 Autor Zgłoszenie Share Napisano Sierpień 16, 2006 wszystkim dziękuję za udzieloną pomoc. Dzięki plikom nadesłanym przez 'uosiu' zaradziłem problemowi Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Sierpień 16, 2006 Zgłoszenie Share Napisano Sierpień 16, 2006 poza tym yum to i tak nakladka i rozwiazywacz zaleznosci na rpm Go to the source, Neo.... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
