alpin19 Napisano Wrzesień 11, 2006 Zgłoszenie Share Napisano Wrzesień 11, 2006 Witam Na podstawie alsowego tutoriala napisałem prostego player'a: #include <stdio.h> #include <stdlib.h> #include <alsa/asoundlib.h> main (int argc, char *argv[]) { int i; int err; short buf[128]; snd_pcm_t *playback_handle; snd_pcm_hw_params_t *hw_params; if ((err = snd_pcm_open (&playback_handle, argv[1], SND_PCM_STREAM_PLAYBACK, 0)) < 0) { fprintf (stderr, "cannot open audio device %s (%s)\n", argv[1], snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_malloc (&hw_params)) < 0) { fprintf (stderr, "cannot allocate hardware parameter structure (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_any (playback_handle, hw_params)) < 0) { fprintf (stderr, "cannot initialize hardware parameter structure (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_set_access (playback_handle, hw_params, SND_PCM_ACCESS_RW_INTERLEAVED)) < 0) { fprintf (stderr, "cannot set access type (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_set_format (playback_handle, hw_params, SND_PCM_FORMAT_S16_LE)) < 0) { fprintf (stderr, "cannot set sample format (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_set_rate_near (playback_handle, hw_params, 44100, 0)) < 0) { fprintf (stderr, "cannot set sample rate (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params_set_channels (playback_handle, hw_params, 2)) < 0) { fprintf (stderr, "cannot set channel count (%s)\n", snd_strerror (err)); exit (1); } if ((err = snd_pcm_hw_params (playback_handle, hw_params)) < 0) { fprintf (stderr, "cannot set parameters (%s)\n", snd_strerror (err)); exit (1); } snd_pcm_hw_params_free (hw_params); if ((err = snd_pcm_prepare (playback_handle)) < 0) { fprintf (stderr, "cannot prepare audio interface for use (%s)\n", snd_strerror (err)); exit (1); } for (i = 0; i < 10; ++i) { if ((err = snd_pcm_writei (playback_handle, buf, 128)) != 128) { fprintf (stderr, "write to audio interface failed (%s)\n", snd_strerror (err)); exit (1); } } snd_pcm_close (playback_handle); exit (0); } Kiedy próbuję go kompilować dostaję taki wynik: [root@zanegi mpeeg]# g++ player.cpp -o player player.cpp:69:2: warning: no newline at end of file player.cpp: In function ‘int main(int, char**)’: player.cpp:13: error: expected initializer before ‘if’ player.cpp:19: error: ‘hw_params’ was not declared in this scope player.cpp:24: error: ‘hw_params’ was not declared in this scope player.cpp:29: error: ‘hw_params’ was not declared in this scope player.cpp:32: error: expected `;' before ‘exit’ player.cpp:34: error: ‘hw_params’ was not declared in this scope player.cpp:39: error: ‘hw_params’ was not declared in this scope player.cpp:44: error: ‘hw_params’ was not declared in this scope player.cpp:50: error: ‘hw_params’ was not declared in this scope player.cpp:66: error: expected `;' before numeric constant player.cpp:66: warning: statement is a reference, not call, to function ‘exit’ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Daniello Napisano Wrzesień 11, 2006 Zgłoszenie Share Napisano Wrzesień 11, 2006 Popraw błędy w tych linijkach co ci kompilator zapodał, a poza tym to masz warna za tak długi listing. Używa się do tak długich listingów Codeboxa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Wrzesień 11, 2006 Zgłoszenie Share Napisano Wrzesień 11, 2006 To nie jest C++, nie nadawaj mylących tytułów swoim wątkom. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość amdfanatyk Napisano Wrzesień 12, 2006 Zgłoszenie Share Napisano Wrzesień 12, 2006 ogolnie jest taka przykra sprawa bo nie ma czegos jak main(int argc, char ** argv). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Wrzesień 12, 2006 Zgłoszenie Share Napisano Wrzesień 12, 2006 Musisz dołączyć odpowiednią bibliotekę przy kompilacji. Zapodaj linka do tego kursu, tam powinno być. Do tego zmień main na int main, w linii 44 zamień 44100 na (unsigned int*)44100. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość amdfanatyk Napisano Wrzesień 12, 2006 Zgłoszenie Share Napisano Wrzesień 12, 2006 w linii 44 zamień 44100 na (unsigned int*)44100. co to by mialo byc? z tego co wiem nie ma zmiennych o nazwach liczbowych, zatem dlaczego 44100 chcesz rzutowac na wskazanie na uint? chyba, ze 44100 to adres jest. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Wrzesień 12, 2006 Zgłoszenie Share Napisano Wrzesień 12, 2006 invalid conversion from int to unsigned int* Pluje się przy 3-cim argumencie funkcji snd_pcm_hw_params_set_rate_near() Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość amdfanatyk Napisano Wrzesień 12, 2006 Zgłoszenie Share Napisano Wrzesień 12, 2006 ludzie wezcie sobie jakis program najpierw napiszcie bo takie pierdoly jak tu wypisujecie to sie plakac chce i rece opadaja, jakies podstawy c/c++ by sie przydaly, wiedziec co to wskazanie, referencja; unsigned int var = 1234; unsigned int * pVar = &var; Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
