Ati + Fc6 Temat Rzeka
lysyr
elo, moze juz ktos grzebal,
problem mam z radeonem 9100 ze gdy zainstlowalem z livny xorg-fglrx kmod-fglrx - wszystko przebieglo pomyslnie - wzorowalem sie na fc5faq
pozniej wylaczylem xy, odpalilem ati-fglrx-config-display enable, modul sie wgral
lecz gdy odpalilem xy - nagle monior przeszedl w stan uspienia (system nie zawiesil sie bo po kombinacj ctrl alt del przezedl w proces restartu)
oto log, a raczej jego koncowka:
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin, [s]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
        compiled for 7.1.1, module version = 0.1.0
        ABI class: X.Org Video Driver, version 1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DPMS"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
        compiled for 7.1.1, module version = 1.0.0
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(EE) fglrx(0): Chipset 0x514d is not recognized
(EE) fglrx(0): PreInitConfig failed
SetVBEMode failed
(EE) fglrx(0): PreInit failed
(II) fglrx(0): === [atiddxPreInit] === end
(II) UnloadModule: "fglrx"
(II) UnloadModule: "int10"
(II) Unloading /usr/lib/xorg/modules/libint10.so
(II) UnloadModule: "vgahw"
(II) Unloading /usr/lib/xorg/modules/libvgahw.so
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
# Xorg configuration created by system-config-display
Section "ServerLayout"
    Identifier     "single head configuration"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
#Section "Module"
#    Load  "glx"
#    Load  "dri"
#EndSection
Section "InputDevice"
    Identifier  "Keyboard0"
    Driver      "kbd"
    Option        "XkbModel" "pc105"
    Option        "XkbLayout" "us"
EndSection
Section "Monitor"
### Comment all HorizSync and VertSync values to use DDC:
    Identifier   "Monitor0"
    ModelName    "Monitor 1600x1200"
    HorizSync    64.0 - 94.0
    VertRefresh  90.0 - 90.0
    Option        "dpms"
EndSection
Section "Device"
    Identifier  "Videocard0"
    Driver      "fglrx"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Videocard0"
    Monitor    "Monitor0"
    DefaultDepth     24
    SubSection "Display"
        Viewport   0 0
        Depth     24
        Modes    "1280x1024"
    EndSubSection
EndSection
ja będę się dalej upierał
yum install xorg-drv-x11-ati
poza tym po co instalujesz fglrx skoro i tak masz w xorgu wyłączone dri i glx ?
kolejna sprawa
nie jestem tu ekspertem, ale wygląda na to że sterownik nie rozpoznaje twojego chipsetu. W ogóle przegrepuj pcałego loga przez EE i zobacz czy nie ma innych errorów
daj jeszcze co pokazuje
LIBGL_DEBUG=verbose glxinfo
jak i zajrzyj do tego wątku http://forum.fedora.pl/index.php?showtopic=10004
Mi po golej instalce fc6 glxgears wywala ~3300. Dziala przezroczystosc i cube. Czy stery do ati sa juz zawarte w instalce?
mam radka 9800 pro.
hmm a na moim Radku x1300pro po daniu yum install kmod-fglrx i konfigu aticonfig --initial glxgears daje w granichach 175fps;ów :o . Tak samo w gnomie żadne jakieś super efekty graficzne nie są widoczne, jedyne co to że mogę normalne odświerzanie i rozdzielczość ustawić
[darek@mass ~]$ glxgears
libGL warning: 3D driver claims to not support visual 0x4b
18519 frames in 5.0 seconds = 3703.745 FPS
20700 frames in 5.0 seconds = 4139.836 FPS
20697 frames in 5.0 seconds = 4139.323 FPS
20680 frames in 5.0 seconds = 4135.884 FPS
EndSection
        Driver      "kbd"
        Option      "XkbLayout" "pl"
EndSection
Section "Device"
        Driver      "radeon"
EndSection
Section "Screen"
        Device     "Videocard0"
        DefaultDepth     24
                Viewport   0 0
                Depth     24
                Modes    "1600x1200" "1600x1024" "1440x900" "1400x1050" "1280x1024" "1280x960" "1280x800" "1152x864" "1152x
864" "1152x768" "1152x768" "1024x768" "1024x768" "800x600" "800x600" "640x480" "640x480"
        EndSubSection
EndSection
mam radka 9800 pro.
masz zainstalowane standardowe stery do ati z mesy które sa oficjalnie wspierane przez fedore. W koncu ktos kto nie meczy na sile fglrx tylko korzysta z mesy, tak trzymac! :)
widzisz, problem w tym ze radeon nie obsluguje juz mojej karty, tzn karty z seri x1000 sa za nowe
ty niestety musisz sie meczyc ze sterownikiem z ati, musisz pobawic sie opcjami z xorg.conf, bo 175fps to jak naTwoja karte STRASZNIE malo.
