piotrekkr Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 witma zainstalowalem stery nvidii i mam cos takiego ze jak otwiera sie np mplyer to ikonka przy korsorze ta co skacze jest bardzo brzydka ma jakas ramke z kolorowych pixeli dookola. Poza tym dookola okienak mplayera jest czarny prostokat i wokolo innych okien tez nie lepiej :/ i jeszcze dziwnie miga mi kursor jak cos "mysli" znaczy jak sie pojawia dookola kursora te niebiekie kropki. Nie wiem co sie stalo mam fc6 :/ prosze o pomoc aha jesli to cos pomoze xorg.comf: # nvidia-xconfig: X configuration file generated by nvidia-xconfig # nvidia-xconfig: version 1.0 (buildmeister@builder3) Mon Oct 16 22:13:07 PDT 2006 # Xorg configuration created by system-config-display Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules/extensions/nvidia" ModulePath "/usr/lib/xorg/modules" EndSection Section "Module" Load "glx" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "Monitor" ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: Identifier "Monitor0" ModelName "LCD Panel 1280x1024" ### Comment all HorizSync and VertSync values to use DDC: HorizSync 31.5 - 67.0 VertRefresh 50.0 - 75.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 Modes "1280x1024" "1280x960" "1280x800" "1152x864" "1152x768" "1024x768" "800x600" "640x480" EndSubSection EndSection Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kamillys Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 sterowniki musza byc aktywne: [kamillys@localhost ~]$ glxinfo | grep direct direct rendering: Yes Jak masz inaczej to pisz. ==EDIT== A i jaka masz konkretnie karte. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Amos Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 W Section "Module" dopisz: Load "extmod" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotrekkr Napisano Październik 31, 2006 Autor Zgłoszenie Share Napisano Październik 31, 2006 mam GF7600 GS ale nie wiem bo sie zdenerwowalem i fc5 zainstalowalem i nie moge narazie zainstallowac sterow do nvidii bo mi transfer spadl (mam neostrade :/) i strasznnie wolno sie wszytsko ciagnie :/ ale jutro napisze czy pomoglo dzieki za zainteresowanie // edit no i dziala dzieki wielkie pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
