Amule
Gość PhockouS
Gość PhockouS
dokladnie tak . dzieje sie to podczas zamkniecia zakladki w oknie szukaj . czy mial juz ktos taki problem ? reinstalka z nowym konfigiem nie podzialala :/
EDIT :
zalaczam loga -
Initialising aMule
Checking if there is an instance already running...
No other instances are running.
HTTP download thread started
Loading temp files from /home/PhockouS/.aMule/Temp.
Loading PartFile 19 of 19
All PartFiles Loaded.
ListenSocket: Ok.
External connections disabled in config file
*** Server UDP socket (TCP+3) at 0.0.0.0:4665
*** TCP socket (TCP) listening on 0.0.0.0:4662
*** Client UDP socket (extended eMule) at 0.0.0.0:4672
Adding file /home/PhockouS/.aMule/Temp/023.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/020.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/019.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/018.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/015.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/014.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/010.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/008.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/007.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/003.part.met to shares
Adding file /home/PhockouS/.aMule/Temp/002.part.met to shares
Empty dir /home/PhockouS/Filmy/ shared
Host: amule.sourceforge.net:80
URL: http://amule.sourceforge.net/lastversion
Response: 200 (Error: 0)
Download size: 6
HTTP download thread ended
Launch Command: opera --newpage 'http://www.filehash.com/search.html?pattern=Saw 3&submit=Find'
ERROR: ld.so: object 'libjvm.so' from LD_PRELOAD cannot be preloaded: ignored.
ERROR: ld.so: object 'libawt.so' from LD_PRELOAD cannot be preloaded: ignored.
(amule:3678): Gtk-CRITICAL **: gtk_container_remove: assertion `GTK_IS_TOOLBAR (container) || widget->parent == GTK_WIDGET (container)' failed
Gtk-ERROR **: file gtkcontainer.c: line 2447 (gtk_container_propagate_expose): assertion failed: (child->parent == GTK_WIDGET (container))
aborting...
Przerwane
Gość
