Matju Napisano Listopad 9, 2006 Zgłoszenie Share Napisano Listopad 9, 2006 Zainstalowałem wszystko zgodnie z opisem w doklejonym temacie czytałem faq, nie poradziłem sobie: fglrxinfo daje: Xlib: extension "XFree86-DRI" missing on display ":0.0". display: :0.0 screen: 0 OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.4.2) Jakieś subestie ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Listopad 9, 2006 Zgłoszenie Share Napisano Listopad 9, 2006 Jakieś logi ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Matju Napisano Listopad 9, 2006 Autor Zgłoszenie Share Napisano Listopad 9, 2006 Najpierw z yuma ładnie się all zainstalowało # aticonfig --initial Found fglrx primary device section Nothing to do, terminating. tutaj wklejam zawartość xorg.conf: # XFree86 4 configuration created by pyxf86config Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # Multiple FontPath entries are allowed (they are concatenated together) # By default, a font server independent of the X server is # used to render fonts. FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "L1732S" DisplaySize 340 270 ### Comment all HorizSync and VertSync values to use DDC: HorizSync 30.0 - 83.0 VertRefresh 56.0 - 75.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" VendorName "Videocard vendor" BoardName "ATI Technologies Inc RV350 AS [Radeon 9550]" Option "VideoOverlay" "on" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1280x1024" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Section "Extensions" Option "Composite" "Enable" EndSection fglrxinfo Xlib: extension "XFree86-DRI" missing on display ":0.0". display: :0.0 screen: 0 OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.4.2) glxgears Xlib: extension "XFree86-DRI" missing on display ":0.0". 695 frames in 5.4 seconds = 129.840 FPS Wersja kernela: 2.6.18-1.2200.fc5 i686 kmode: kmod-fglrx-8.29.6-1.2.6.18_1.2200.fc5 Karta Gigabyte Radeon 9550 system zaktualizowany Mam nadzieje że ktoś pomoże, dzięki i pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Matju Napisano Listopad 9, 2006 Autor Zgłoszenie Share Napisano Listopad 9, 2006 ok dodałem Load "dri" i zamieniłem Section "Extensions" Option "Composite" "Enable" EndSection na Section "Extensions" Option "Composite" "Disable" EndSection teraz mam: # fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9550 Generic OpenGL version string: 2.0.6065 (8.29.6) Ale wyniki bardzo słabe i nie wiem dlaczego # glxgears 1242 frames in 5.0 seconds = 248.359 FPS Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
limp Napisano Listopad 12, 2006 Zgłoszenie Share Napisano Listopad 12, 2006 Też mam bardzo podobny problem z wydajnością - wygląda na to że wszystko działa tylko osiągi są raczej żenujące [limp@snova ~]$ uname -a Linux snova 2.6.18-1.2200.fc5 #1 Sat Oct 14 16:59:26 EDT 2006 i686 athlon i386 GNU/Linux [limp@snova ~]$ rpm -qa kmod-fglrx* kmod-fglrx-8.29.6-1.2.6.18_1.2200.fc5 [limp@snova ~]$ fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9600 XT Generic OpenGL version string: 2.0.6065 (8.29.6) [limp@snova ~]$ glxgears 1214 frames in 5.0 seconds = 242.769 FPS 1215 frames in 5.0 seconds = 242.988 FPS 877 frames in 5.0 seconds = 175.390 FPS 611 frames in 5.0 seconds = 122.194 FPS 877 frames in 5.0 seconds = 175.392 FPS 1026 frames in 5.0 seconds = 205.189 FPS [limp@snova ~]$ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Listopad 13, 2006 Zgłoszenie Share Napisano Listopad 13, 2006 OpenGL vendor string: Tungsten Graphics, Inc. OpenGL renderer string: Mesa DRI R300 20060815 AGP 4x x86/MMX+/3DNow!+ TCL OpenGL version string: 1.3 Mesa 6.5.1 $ glxgears 5619 frames in 5.0 seconds = 1123.760 FPS 5615 frames in 5.0 seconds = 1122.920 FPS 5612 frames in 5.0 seconds = 1122.369 FPS 5613 frames in 5.0 seconds = 1122.567 FPS 5583 frames in 5.0 seconds = 1116.585 FPS # lspci |grep ati 01:00.0 VGA compatible controller: ATI Technologies Inc RV350 AS [Radeon 9550] $ pokaz mesa mesa-libGL-6.5.1-7.fc6 mesa-libGL-devel-6.5.1-7.fc6 $ pokaz ati xorg-x11-drv-ati-6.6.2-4.fc6 I po co sobie było d*pę zawracać fglrx? Do tego nie mam żadnych problemów z compizem na sterach mesy. A z tego co pamiętam to właśnie 8.29.6 są zwalone i powodują problemy z wydajnością. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Listopad 13, 2006 Zgłoszenie Share Napisano Listopad 13, 2006 to może jeszcze ja OpenGL vendor string: Tungsten Graphics, Inc. OpenGL renderer string: Mesa DRI R200 20060602 AGP 8x x86/MMX+/3DNow!+/SSE TCL OpenGL version string: 1.3 Mesa 6.5.1 $ glxgears 7722 frames in 5.0 seconds = 1544.321 FPS 7754 frames in 5.0 seconds = 1550.612 FPS 7717 frames in 5.0 seconds = 1543.372 FPS 7734 frames in 5.0 seconds = 1546.739 FPS 7674 frames in 5.0 seconds = 1534.750 FPS Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
