Problem Z Instalacją Sieciówki - Fc6
razor
Po instalacji systemu, sterowniki nie zaladowaly sie automatycznie ...
kawalek lspci -v
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
        Subsystem: ASUSTeK Computer Inc. Unknown device 11f5
        Flags: bus master, fast devsel, latency 0, IRQ 5
        I/O ports at d800 [size=256]
        Memory at df6ff000 (64-bit, non-prefetchable) [size=4K]
        Expansion ROM at df6e0000 [disabled] [size=64K]
        Capabilities: [40] Power Management version 2
        Capabilities: [48] Vital Product Data
        Capabilities: [50] Message Signalled Interrupts: 64bit+ Queue=0/1 Enable-
        Capabilities: [60] Express Endpoint IRQ 0
        Capabilities: [84] Vendor Specific Information
Pobralem sterowniki z realtek.com.tw
na poczatku readme bylo :
Linux device driver for Realtek Ethernet controllers>
This is the Linux device driver released for RealTek Ethernet controllers, which are listed as following.
1. RTL8169S/SB/SC (Gigabit Ethernet with PCI interface)
2. RTL8168B (Gigabit Ethernet with PCI-Express interface)
3. RTL8101E (Fast Ethernet with PCI-Express interface)
<Requirements>
- kernel source tree (supported versions 2.4.x or 2.6.x)
- compiler/binutils for kernel compilation
<Quick install with proper kernel settings>
Unpack the tarball :
tar vzxf r1000_vX.YZ.tgz
Change to the directory:
cd r1000_vX.YZ
If you are running the target kernel, then you should be
able to do :
make clean modules (as root or with sudo)
make install
depmod -a
Kiedy robie make clean modules dostaje:
[root@localhost r1000_v1.04]# make clean modules
make -C src/ clean
make[1]: Wejscie do katalogu `/home/ja/Desktop/r1000_v1.04/src'
rm -f *.o *.ko *~ core* .dep* .*.d .*.cmd *.mod.c *.a *.s .*.flags
make[1]: Opuszczenie katalogu `/home/ja/Desktop/r1000_v1.04/src'
make -C src/ modules
make -C /lib/modules/2.6.18-1.2798.fc6/build SUBDIRS=/home/ja/Desktop/r1000_v1.04/src modules
make[2]: Wejscie do katalogu `/usr/src/kernels/2.6.18-1.2798.fc6-i686'
  CC [M]  /home/ja/Desktop/r1000_v1.04/src/r1000_n.o
/home/ja/Desktop/r1000_v1.04/src/r1000_n.c:51: error: expected ‘)’ before string constant
/home/ja/Desktop/r1000_v1.04/src/r1000_n.c:52: error: expected ‘)’ before string constant
/home/ja/Desktop/r1000_v1.04/src/r1000_n.c:53: error: expected ‘)’ before string constant
make[3]: *** [/home/ja/Desktop/r1000_v1.04/src/r1000_n.o] Blad 1
make[2]: *** [_module_/home/ja/Desktop/r1000_v1.04/src] Blad 2
make[2]: Opuszczenie katalogu `/usr/src/kernels/2.6.18-1.2798.fc6-i686'
make[1]: *** [modules] Blad 2
make: *** [modules] Blad 2
System FC6. Laptop ASUS. W Windowsie karte widac jako: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC.
Wie ktos co z tym da sie zrobic :> ?
make -C src/ clean
make[1]: Wejście do katalogu `/home/ja/Desktop/r1000_v1.04/src'
make[2]: Wejście do katalogu `/usr/src/kernels/2.6.18-1.2798.fc6-i686'
make[3]: *** [/home/ja/Desktop/r1000_v1.04/src/r1000_n.o] Błąd 1
make[2]: *** [_module_/home/ja/Desktop/r1000_v1.04/src] Błąd 2
make[1]: *** [modules] Błąd 2
make: *** [modules] Błąd 2
System FC6. Laptop ASUS. W Windowsie kartę widać jako: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC.
Wie ktoś co z tym da się zrobić :> ?
Jest pewien błąd w src sterownika, który udało mi się poprawić i karta (moduł) śmiga.
W linijkach, w których wyskakuje błąd masz coś takiego:
MODULE_PARM (speed, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM (duplex, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM (autoneg, "1-" __MODULE_STRING(MAX_UNITS) "i");
Zmień to na:
MODULE_PARM_DESC (speed, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM_DESC (duplex, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM_DESC (autoneg, "1-" __MODULE_STRING(MAX_UNITS) "i");
skompiluj moduł, załaduj i w ifconfig -a powinieneś widzieć juz karte - innymi słowy powinna śmigać (mi na gentoo działa). :-)
Dziękuje sterownik skompilował się :) Tylko jak teraz skonfigurwać sieć ? Da się zrobić tak żeby można było skonfugrować sieć za pomocą system-config-network ?
Bo tam ta karta nie pokazuje sie na liście sterowników :P
Nie rozumiesz :P
Laduje modul i nic, tzn moze cos sie dzieje, ale ja nie wiem co dalej :P. W system-config-network nadal nie ma mojej karty. Nie bardzo widze sens zakladania nowego tematu :P wiec jesli mozesz to napisz tutaj jesli cos wiesz ...
Jednak dziala :P W system-config-network dalem jakas inna karte realteka i smiga:p
  • 2 months later...
Witajcie mam podobny problem, właściwie to trochę inny ale sprzęt ten sam. W noteboku Asus F3jp jest własnie ta karta. W zasadzie działa, tj pod kubuntu działała, pod fedorą 6 skompilowana ze sterownika 1.0.5 co pare min zrywa połączenie, pomaga tylko restart sieci (/etc/init.d/network restart) po czym znów działa kolejnych pare minut. Najgorsze jest jednak to ż po zmianie adresu mac karty (chory wymóg isp) karta wstaje dostaje adres i tyle żadnego pakietu już nie wypuszcza. Czy ktoś z was sie z czymś takim spotkał?
Jest pewien blad w src sterownika, który udalo mi sie poprawic i karta (modul) smiga.
W linijkach, w których wyskakuje blad masz cos takiego:
Zmien to na:
skompiluj modul, zaladuj i w ifconfig -a powinienes widziec juz karte - innymi slowy powinna smigac (mi na gentoo dziala). :-)
Borykam sie z podobnym problemem i po znalezieniu tego tematu na forum próbowalem zainstalowac sieciówke u siebie.
Niestety nie jestem dobry w te klocki.
Mój problem wyglada nieco inaczej :
[root@localhost r1000_v1.05]# make clean modules
make -C src/ clean
make[1]: Wejscie do katalogu `/home/darek/r1000_v1.05/src'
rm -rf *.o *.ko *~ core* .dep* .*.d .*.cmd *.mod.c *.a *.s .*.flags .tmp_versions
make[1]: Opuszczenie katalogu `/home/darek/r1000_v1.05/src'
make -C /lib/modules/2.6.18-1.2798.fc6/build SUBDIRS=/home/darek/r1000_v1.05/src modules
make: Wejscie do nieznanego katalogu
make: *** /lib/modules/2.6.18-1.2798.fc6/build: Nie ma takiego pliku ani katalogu. Stop.
make: Opuszczenie nieznanego katalogu
Prosze o podpowiedz.
[root@localhost darek]# rpm -qa | grep kernel*
kernel-headers-2.6.19-1.2895.fc6
kernel-devel-2.6.18-1.2869.fc6
kernel-2.6.18-1.2798.fc6
kernel-devel-2.6.19-1.2895.fc6
Wcześniej były pakiety z tymi samymi numerkami lecz po twojej sugestii pociągnąłem nowe i zainstalowałem.
Niestety nie przyniosło to zmian.
Pozdro.
hej
mam pytanie czy sterowniki w wersji 1.0.5 działają wam poprawnie? mi z tą wersją oprócz tego co pisałem wcześniej na temat zmiany adresu mac strasznie zrywa połączenie,
działa przez pare min a potem przestaje po dłuższej chwili z powrotem zaczyna. Problem ten rozwiazałem zauważając że z ubuntu się tak nie działo, okazało się że w ubuntu w kernelu 2.6.17 jest wersja 1.0.2 tego sterownika która działa poprawnie, dodam że tylko tam udało mi się go znaleźć googlanie umożliwia znalezienie tylko wersji 1.0.5
Nie wiem jak Ty to instalowales, ale nadal pracujesz na starym kernelu (kernel + kernel-devel w wersji 2.6.18-1.2798) pozostale 2 pakiety (headers i drugi devel) masz do najnowszego kernela 2.6.19-1.2895...
Powinienes zaktualizowac kernel do wersji 2.6.19-1.2895 (devel i headers juz masz, wiec dalej powinno pojsc...)
Dopoki tego nie uporzadkujesz to marne szanse ze cokolwiek skompilujesz ;)
Powodzenia
Zgodnie z sugestią doprowadziłem do sytuacji gdy pakiety mają tęsamą numerację:
[root@localhost ~]# rpm -qa | grep kernel*
kernel-devel-2.6.18-1.2798.fc6
kernel-headers-2.6.18-1.2798.fc6
Przyniosło to pewne zmiany lecz wciąż nie zadowalające:
make -C src/ clean
make[1]: Wejście do katalogu `/home/darek/r1000_v1.05/src'
make[2]: gcc: Polecenie nie znalezione
make[2]: Wejście do katalogu `/usr/src/kernels/2.6.18-1.2798.fc6-x86_64'
CC [M] /home/darek/r1000_v1.05/src/r1000_n.o
/bin/sh: gcc: command not found
make[3]: *** [/home/darek/r1000_v1.05/src/r1000_n.o] Błąd 127
make[2]: *** [_module_/home/darek/r1000_v1.05/src] Błąd 2
make[2]: Opuszczenie katalogu `/usr/src/kernels/2.6.18-1.2798.fc6-x86_64'
Podejrzewam znowu jakieś braki ???
[1] sciagnales zrodelka w wersji 64bit, a kernela masz 32bit...
[2] chyba nie masz gcc - poszukaj na plytce gcc-4.1.1-30.i386.rpm i zainstaluj przy uzyciu rpm (rpm -Uvh gcc-*.rpm). Prawdopodobnie bedzie sie darl o zaleznosci (dodatkowe pakiety) - wtedy najprosciej jest kopiowac je do tego samego katalogu (na dysku twardym) w ktorym jest gcc-*.rpm i probowac zainstalowac na raz (rpm -Uvh *.rpm)
Powodzenia
