Walduch Napisano Styczeń 5, 2007 Zgłoszenie Share Napisano Styczeń 5, 2007 nie wiem ale chyba se scagne nowsza wersje bo chyba mam stara PS. sory nie wiedzialem ze to forum linuksa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
damianes Napisano Styczeń 15, 2007 Zgłoszenie Share Napisano Styczeń 15, 2007 ~]$ et ET 2.60 linux-i386 Mar 10 2005 ----- FS_Startup ----- Current search path: /home/admin/.etwolf/etmain /usr/local/games/enemy-territory/etmain/pak2.pk3 (22 files) /usr/local/games/enemy-territory/etmain/pak1.pk3 (10 files) /usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files) /usr/local/games/enemy-territory/etmain/mp_bin.pk3 (6 files) /usr/local/games/enemy-territory/etmain ---------------------- 3763 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec autoexec.cfg Hunk_Clear: reset the hunk ok ------- Input Initialization ------- Joystick is not active. ------------------------------------ Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- ...loading libGL.so.1: Initializing OpenGL display ...setting mode 4: 800 600 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 800x600 Using 8/8/8 Color bits, 16 depth, 0 stencil display. GL_RENDERER: Mesa GLX Indirect *********************************************************** You are using software Mesa (no hardware acceleration)! Driver DLL used: libGL.so.1 If this is intentional, add "+set r_allowSoftwareGL 1" to the command line when starting the game. *********************************************************** ...WARNING: could not set the given mode (4) Initializing OpenGL display ...setting mode 3: 640 480 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 640x480 Received signal 11, exiting... I co dalej? Zmiana całej rozdzielczości nie pomaga. Obraz wyskakuje na sekunde, widzę kratki i znika. Co zrobić? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 15, 2007 Zgłoszenie Share Napisano Styczeń 15, 2007 Zainstalowac poprawnie sterowniki do karty graficznej - nie masz sprzetowej akceleracji 3D. Ludziska, czy wy nie umiecie czytac?... *********************************************************** You are using software Mesa (no hardware acceleration)! Driver DLL used: libGL.so.1 If this is intentional, add "+set r_allowSoftwareGL 1" to the command line when starting the game. *********************************************************** Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzel154 Napisano Styczeń 22, 2007 Zgłoszenie Share Napisano Styczeń 22, 2007 witam! Mam taki problem gram W ET i nie mam w nim glosu wszystko inne chodzi mp3 itp. w konsoli mam taki error.. wiem ze tylko od głosu ale dalej nie wiem jak go sie pozbyć.. ------- sound initialization ------- /dev/dsp: Input/output error Could not mmap /dev/dsp Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Lukasz69 Napisano Styczeń 22, 2007 Zgłoszenie Share Napisano Styczeń 22, 2007 Zanim odpalisz gre wstukaj w konsoli artsshell suspend. Sprawdz czy dziala - jak nie to pomyslimy nad inna metoda. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzel154 Napisano Styczeń 23, 2007 Zgłoszenie Share Napisano Styczeń 23, 2007 nic nie pomogło dalej to samo:/ brak dźwieku Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Lukasz69 Napisano Styczeń 23, 2007 Zgłoszenie Share Napisano Styczeń 23, 2007 No to jako root wstukaj to: echo "et.x86 0 0 direct">/proc/asound/card0/pcm0p/oss Tylko zwroc uwage na et.x86 bo nie wiem czy u ciebie z tym samym bedzie chodzilo(trzeba podac nazwe pliku do uruchomienia ET) - ale ta komenda powinna pomoc. Aha jak to wstukasz to przed wlaczeniem gry daj artsshell tak jak wczesniej podalem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
orzel154 Napisano Styczeń 23, 2007 Zgłoszenie Share Napisano Styczeń 23, 2007 Dzieki Lukasz69 teraz działą.. jeszcze raz wielkie dzięki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Headshot Napisano Styczeń 25, 2007 Zgłoszenie Share Napisano Styczeń 25, 2007 Sciągnełem własnie patcha do et (2.60b) gamershell.com W środku były pliki "et.x86" i "etded.x86" ... no i własnie w tym momencie koniec, ktoś wie co dalej z tym zrobić żeby zainstalować odpowiednio patcha ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
veiovis Napisano Styczeń 25, 2007 Zgłoszenie Share Napisano Styczeń 25, 2007 Sciągnełem własnie patcha do et (2.60b) gamershell.com W środku były pliki "et.x86" i "etded.x86" ... no i własnie w tym momencie koniec, ktoś wie co dalej z tym zrobić żeby zainstalować odpowiednio patcha ? no tego patcha się nie instaluje poprostu podmieniasz plik et.x86 w katalogu z grą. Ten który masz po instalacji przekopiuj sobie gdzieś do innego katalogu i będziesz mógł żonglować tymi plikami łącząc się wedle uznania z serwerami które wymagają patcha lub nie. Pozdr, veiovis Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rider3 Napisano Luty 15, 2007 Zgłoszenie Share Napisano Luty 15, 2007 Ja mam pare problemow z ET. Podczas gry gdy naciskam CTRL+[liczba] to uzywane sa tak jakby skroty w grze, ktorych mimo to nie mam zapisanych w cfg, np. jak nacisne ctrl+3 to otwiera mi sie menu zamiast kucniecia i zmiany broni na smg. Ponadto jak wychodze z gry przez /quit to rozdzialka desktopa mi sie zmienia. Ostatnim z problemow jakie mam z ET jest to, ze nie wiem jak zrobic by etpro uruchomialo sie razem ze startem ET. Wie ktos moze jak pomoc ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Luty 24, 2007 Autor Zgłoszenie Share Napisano Luty 24, 2007 Ja mam inny problem... jak odinstalować ET? Bo po instalacji poprawnych sterow do grafiki, pierw troszku wariowalo a dzis(po 2 tygodniach) padło:/ Wiec chyba poprostu trzeba zainstalowac je od nowa:/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
BLo0dY Napisano Marzec 1, 2007 Zgłoszenie Share Napisano Marzec 1, 2007 witam. Zapraszam na publica. Stoi on na modzie ETPub // patch 2.60b IP : 62.181.0.214:27990 48h XP Save Wszelkie informacje na naszym forum : www.blitzkrieget.fora.pl Link do FTPka ze wszystimi plikami potrzebnymi, aby sie polaczyc na server jest nastepujacy: http://www.blitzkrieget.fora.pl/viewtopic.php?t=117 Pozdrawiam i zapraszam :D Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Lukasz69 Napisano Marzec 1, 2007 Zgłoszenie Share Napisano Marzec 1, 2007 Ja mam inny problem... jak odinstalować ET? Bo po instalacji poprawnych sterow do grafiki, pierw troszku wariowalo a dzis(po 2 tygodniach) padło:/ Wiec chyba poprostu trzeba zainstalowac je od nowa:/ W katalogu z ET nie ma skryptu usuwajacego wiec ja bym najprawdopodobniej usunal katalog z et i gdy by bylo potrzeba tez dowiazania. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Maj 27, 2007 Autor Zgłoszenie Share Napisano Maj 27, 2007 Witam! Mam teraz nowy problem z ET:/ Jak próbuję je włączyć, to filmik mi się tak tnie że właściwie wyświetlane są obrazki zmieniające się co 10s co powinno być w filmiku(tzn.wyświetla pojedyncze obrazki z filmiku co ok 10s). A jak nacisnę Escape to mi po jakiś kilku minutach czarnego ekranu wyskakuje menu Wolfensteina zaciemnione strasznie i na dodatek zacięte że trzeba resetować komputer... Co robić? Dodam że mam procesor 2,4GHz, Radeona 9600 Pro na którym wyciągam 1600-1700FPS`ów, 768 ramu i Wolfenstein wcześniej działał płynnie, ostatni tydzień się przycinał a wczoraj całkowicie padł.... Pozdrawiam Jasiek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
