Beryl-kde Problem
MC'
Witam,
Tak jak w temacie mam zainstalowane stery kmod-nvidia
$ uname -r
2.6.19-1.2895.fc6
$ rpm -qa |grep nvidia
kmod-nvidia-1.0.9746-1.2.6.19_1.2895.fc6
xorg-x11-drv-nvidia-1.0.9746-7.lvn6
i xorg.conf
# Xorg configuration created by pyxf86config
Section "ServerLayout"
        Identifier     "Default Layout"
        Screen      0  "Screen0" 0 0
        InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
        ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
        ModulePath   "/usr/lib/xorg/modules"
EndSection
Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "kbd"
        Option      "XkbModel" "pc105"
        Option      "XkbLayout" "pl"
EndSection
Section "Device"
        Identifier  "Videocard0"
        Driver      "nvidia"
        Option      "AddARGBGLXVisuals" "True"
EndSection
Section "Screen"
        Identifier "Screen0"
        Device     "Videocard0"
        DefaultDepth     24
        SubSection "Display"
                Viewport   0 0
                Depth     24
        EndSubSection
EndSection
Zainstalowalem yum install beryl-kde. Po odpaleniu beryl-menagera dostalem kompletna zwieche tj nic nie moza bylo na pulpicie przeciagnac dolny pasek KDE (kicker) zniknal podobnie jak dekoracje okien.
Po przeskoczeniu na Ctrl+Alt+F1 dalem ps -aux| grep beryl i dostalem dwa procesy beryl-menager i beryl --skip-gl-yield
Po zkilowaniu tego drugiego i przejsciu na konsole 7 czyli x'y zobaczylem taki wpis w terminalu
$ beryl-manager
* Beryl system compatiblity check                            *
Detected xserver                                : NVIDIA
Checking Display :0 ...
Checking for XComposite extension               : passed (v0.3)
Checking for XDamage extension                  : passed
Checking for RandR extension                    : passed
Checking for XSync extension                    : passed
Checking Screen 0 ...
Checking for GLX_SGIX_fbconfig                  : passed
Checking for GLX_EXT_texture_from_pixmap        : passed
Checking for non power of two texture support   : passed
Checking maximum texture size                   : passed (8192x8192)
Relaunching beryl with __GL_YIELD="NOTHING"
Reloading options
[iPCS]: Unable to change values during paint operations!
.... <duzo tych linii;)>
i ostatecznie wszystko sie odwiesilo. najciekawsze to, ze proces beryl-menager dalej sobie dziala.
Co jest nie tak? Chcialbym jednak sie troszke pobawic tym berylem.
Z góry dziekuje za wszelkie sugestie i podpowiedzi :)
Pozdr
P.S.
Niby interface beryla mam tray'u i moge wejsc do okna menagera ale Ctrl+Alt + button1 nie dziala mimo ze jest tak ustawiony w Pulpit->obróc kostke ->Shortcuts->bindings->initiaterotation Ctrl+Alt+Button1 (Przy keyboard mam Disabled)
Dopisz do xorg.conf dwie sekcje:
Section "Module"
    Load  "glx"
    Load  "extmod"
EndSection
oraz
Section "Extensions"
    Option        "Composite"
EndSection
Następnie przeładuj X-y i spróbuj znowu rurchomić beryl-manager.
A na przyszłość poszukaj dobrze na forum - tematów o berylu jest od groma...
Tylko, ze to nie rozwiazuje problemu.A wlasciwie to rozwiazuje go czesciowo bo dalej np kostki nie mam. Jest to co opisalem tylko bez zwiechy. Po odpaleniu z konsoli dostje komunikaty typu
$ beryl-manager
Sending reload event...
A po uruchomieniu menagera z tacki dostalem na konsoli (_root'a_ → roota) ORT cosik takiego:
Ostrzezenie menedzera okien: Utracono polaczenie z ekranem ":0".
Prawdopodobnie przestal funkcjonowac serwer X lub przerwano dzialanie menedzera okien.
[Edit] Ok wróc ! nic nie poprawilo dalej jest to samo. Ikonka beryla jest w trayu ale jako menadzer okien jest metacity a nie beryl jak daje beryla to nadal sie wszystko wykrzacza w taki sam sposób jak to mialo miejsce poprzednio.
Niestety, nie zadziałało ;( Ja instalowałem beryla przez yum install beryl-kde i mam
$ rpm -qa |grep beryl
beryl-plugins-0.1.9999.1-1.fc6
beryl-kde-0.1.9999.1-3.fc6
beryl-settings-simple-0.1.9999.1-4.fc6
beryl-settings-0.1.9999.1-4.fc6
beryl-manager-0.1.9999.1-2.fc6
beryl-core-0.1.9999.1-3.fc6
Może czegoś nie zainstalowałem jeszcze. Chociaż według wiki beryla dla fc to powinno wystarczyć.
[EDIT]:
Dziwna sprawa jak włączę z PPM->Menadger okien to wybrany mam metacity dal gmone mimo że siedzę na kde :blink: Jak włączę np Compi'a to nie ma tylko dekoracji okien ale mam kostkę natomiast w ten sam sposób zmiana z metacity na beryla powoduje zwiechę taką że tylko resent z obudowy działa.
[EDIT2]:
Przy próbie natomiast przeładowania menadgera okien dostaję taki komunikat
$ Reloading...
(emerald:9453): Gdk-CRITICAL **: gdk_drawable_unref: assertion `GDK_IS_DRAWABLE (drawable)' failed
Reloading...
X connection to :0.0 broken (explicit kill or server shutdown).
A może powinienem doinstalować beryla do tego co mam przez yum install beryl?
P.S.
Jakoś nie widze u siebie w xorg.conf wpisu o dri. Czy to ma coś do rzeczy? Wiem, że to są otwarte sterowniki. Ja mam te z livny. Może w tym jest problem?
A moze problem jest w tych liniach:
Option      "AllowGLXWithComposite" "True"
Option      "RenderAccel" "True"
Ja nie mam ich w swoim xorg.conf, a Beryl dziala znakomicie, przelaczanie miedzy nim a Kwin tez, z akceleracja równiez nic zlego sie nie dzieje - z zadna aplikacja ani gra nie mam problemu (Celestia, Stellarium, K3D, PPRacer, Foobillard, Cube, Sauerbraten, Hexen 2). Co prawda glxgears przy Berylu pokazuje tylko jakies 500 - 600 FPS, ale to wystarcza...
EDIT:
Aha, mam wylaczone wszystkie efekty z KDE (przezroczystosc, wylanianie menu, itp.), bo sie gryza z Berylem i Compizem...
