Problemy Z Instalacją Ntfs
druidek
Witam, proszę o pomoc co jest nie tak
[root@lokalny ~]# yum install kmod-ntfs
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for kmod-ntfs to pack into transaction set.
kmod-ntfs-2.1.27-3.2.6.19 100% |=========================| 6.4 kB    00:00
---> Package kmod-ntfs.i686 0:2.1.27-3.2.6.19_1.2895.fc6 set to be installed
--> Running transaction check
--> Processing Dependency: kernel-i686 = 2.6.19-1.2895.fc6 for package: kmod-ntfs
--> Processing Dependency: ntfs-kmod-common >= 2.1.27 for package: kmod-ntfs
--> Restarting Dependency Resolution with new changes.
---> Downloading header for ntfs-kmod-common to pack into transaction set.
ntfs-kmod-common-2.1.27-2 100% |=========================| 4.9 kB    00:00
---> Package ntfs-kmod-common.noarch 0:2.1.27-2.lvn6 set to be updated
---> Downloading header for kernel to pack into transaction set.
kernel-2.6.19-1.2895.fc6. 100% |=========================| 211 kB    00:08
---> Package kernel.i686 0:2.6.19-1.2895.fc6 set to be installed
---> Package kernel.i586 0:2.6.18-1.2869.fc6 set to be erased
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Installing:
kmod-ntfs               i686       2.1.27-3.2.6.19_1.2895.fc6  livna             112 k
Removing:
kernel                  i586       2.6.18-1.2869.fc6  installed          43 M
Installing for dependencies:
kernel                  i686       2.6.19-1.2895.fc6  updates            16 M
ntfs-kmod-common        noarch     2.1.27-2.lvn6    livna              54 k
Transaction Summary
Install      3 Package(s)
Update       0 Package(s)
Remove       1 Package(s)
Total download size: 17 M
Is this ok [y/N]: y
Downloading Packages:
(1/3): ntfs-kmod-common-2 100% |=========================|  54 kB    00:02
(2/3): kmod-ntfs-2.1.27-3 100% |=========================| 112 kB    00:02
(3/3): kernel-2.6.19-1.28 100% |=========================|  16 MB    08:25
Running Transaction Test
Finished Transaction Test
Transaction Check Error:   package kernel-2.6.19-1.2895.fc6 is already installed
 file /boot/System.map-2.6.19-1.2895.fc6 from install of kernel-2.6.19-1.2895.fc6 conflicts with file from package kernel-2.6.19-1.2895.fc6
 file /boot/config-2.6.19-1.2895.fc6 from install of kernel-2.6.19-1.2895.fc6 conflicts with file from package kernel-2.6.19-1.2895.fc6
 file /boot/symvers-2.6.19-1.2895.fc6.gz from install of kernel-2.6.19-1.2895.fc6 conflicts with file from package kernel-2.6.19-1.2895.fc6
 file /boot/vmlinuz-2.6.19-1.2895.fc6 from install of kernel-2.6.19-1.2895.fc6 conflicts with file from package kernel-2.6.19-1.2895.fc6
z tego co ja rozumiem (na pewno błędnie) kernel-2.6.19-1.2895.fc6 jest w koflikcje z kernel-2.6.19-1.2895.fc6 a więc z samym sobą?.
oczywiście próba instalacji miała na celu możliwoscią dostępu do partycji ntfs z poziomu Fedory.
Było juz kilka razy. Szukaj postów exbrosa (chyba). Różnice między pakietami i586 oraz i686.
Na przyszłość przed napisaniem postu skorzystaj z wyszukiwarki.
Przy okazji: jeśli chcesz mieć dostęp odczyt/zapis do NTFS (a nie tylko odczyt jaki daje kmod-ntfs) to poszukaj postów o ntfs-3g.
